I just finished up my 496 build and wondered what type of numbers you guys thought it might put up. The build consists of the following:
1. Pro Gram splayed capped GM block
2. Eagle LW 4.25 stroke crank
3. Eagle 6.385 H-beam rods
4. SRP pistons with 43cc dome
5. Dart fully ported 325 Pro 1s. Combustion chamber is 109.2cc measured. Manly severe duty 2.25 and 1.88 valves
6. Comp Cams 11-749-14. Duration @50- 276/284. Lobe center 110. Lift- .792/.756
7. Comp Cams Hi-Tech Stainless Roller Rocker Arms with a 1.8 ratio.
8. Compression is 14.3 to 1
9. Intake is a Victor-R with a 2 inch adapter with a fully modified 850 Holley that flows over 1020cfm
10. B and B oil pan with crank scraper and windage tray
Dropping it off tomorrow and hopefully dynoing within the next week. Once I have the numbers, I will post them up.
