Brake Bleeding Issues: Passenger Side Rear Brake will not bleed - Chevelle Tech
Auto Insurance
Brakes, Suspension & Steering Conversion questions & more.
Old Apr 30th, 09, 8:19 PM
LilRed LilRed is offline
Michael
Unhappy Brake Bleeding Issues: Passenger Side Rear Brake will not bleed
Hi Everyone,
I'm working on a 71 Chevelle with factory front disc/rear drums.
I was bleeding my brakes after noticing they were feeling very mushy and would go to the floor from time to time.
I started in the right rear and no fluid came out when I loosened the bleeder valve.
Then I moved to the left rear and that one would bleed, so I did the rest, minus the right rear.
I hopped in the car and the pedal goes almost to the floor before engaging the brakes. I checked the master cylinder and there was a gunky build up in it. I'm assuming the rear line is clogged, but I'm not 100% sure. What can one do to unclog a brake line?
Also, before this procedure, it seemed like the rear passenger wheel would stick when braking for speed bumps. Thanks for your help.
Old Apr 30th, 09, 10:18 PM
zeke67 zeke67 is offline
Default Re: Brake Bleeding Issues: Passenger Side Rear Brake will not bleed
Try bleeding it at the line before the wheel cylinder and if that wont work, try it at the distribution block at the rear axle. This will get some air out and build enough pressure to push the gunk through.
Zeke
67 Chevelle
64 Chevelle
69 AMX
TC# 3094 ACES# 7297
Old Apr 30th, 09, 10:22 PM
dgwar dgwar is offline
Don
original rubber hose over the axle? it is probably coming apart inside. remove the rear lines and blow them out.
Old May 1st, 09, 10:36 AM
JWagner JWagner is offline
Gold Member
If the left rear bleeds ok , then the rubber line is ok. Have you removed the bleeder screw and cleared the crud out of the passages in it? Also, you might poke a wire into the hole in the wheel cylinder to clear it out, too.
Old May 1st, 09, 5:29 PM
LeoP LeoP is offline
leo
and if that doesn't work, you should replace the wheel cylinders and the hose if it is old. Good luck with your repairs.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
progress has little to do with speed, but lots to do with direction
www.mdchevelleclub.com
email: paughpa@verizon.net
  #6
Old May 1st, 09, 7:22 PM
TXCR13 TXCR13 is offline
Steve
Yep, check to make sure the bleeder isn't blocked with rust.
TXCR13
1966 Chevelle 300 2dr Sedan
385, Flat Top Hypers, Performer RPM, S.M.I. 750 Q-Jet, 72cc Dart Platinum 200cc runners, U.D. Harold 223/233 112 LSA Cam, 700-R4, PS, Manual Disc Brakes, AC, Hedman headers with 2-1/2" exhaust.
1946 Studebaker Champion Business Coupe- next year project.
  #7
Old May 2nd, 09, 3:35 PM
Michael
Thanks for all the advice. I'll pull the bleeder, make sure its clean and get back to you guys.
You may not post new threads
You may not post replies
