thumper cams - Chevelle Tech
Auto Insurance
Old Apr 14th, 09, 9:06 PM
ragtop69ss ragtop69ss is offline
alvin
Default thumper cams
any body used one yet good or bad thanks
Old Apr 14th, 09, 10:03 PM
zeke67 zeke67 is offline
Default Re: thumper cams
From what I've read here, not the best. From the magazines, awesome stuff.
Zeke
67 Chevelle
64 Chevelle
69 AMX
TC# 3094 ACES# 7297
Old Apr 14th, 09, 10:57 PM
ABAD72 ABAD72 is offline
Angry Re: thumper cams
no matter what the tech guys at jeggs or sumitt will say,, the thumper cam is a cast iron grind, dont even think about it unless you order a steel one rite from comp.. I got 2 bad ones rite out the box, from sumitt... azz far azz performance goes -I cant tell a seat of the pants different from the stock zz4 cam i took out of my zz4,, I havent ran a 1/4 with it yet to tell if it is faster,,, but it does sound like a beast... here is a link video of the second bad one I got... comp actually eneded up makin me a steel one after the problems I had with sumitt bad cast ones..If I hadnt already had the matching valve train components in my heads already I would of went a different way..
http://s192.photobucket.com/albums/z...2_11_40_11.flv
Old Apr 14th, 09, 10:58 PM
blown70 blown70 is offline
Travis
A buddy of mine is building a sbc with a big mutha thumper roller.I can keep you posted on the dyno results.
Don't let fear and common sense stand in the way of MORE POWER!
Travis
1970 Chevelle, 8-71 blown/nitrous 460 BBC,
I do NOT condone street racing…Burn-outs are different!
Dyno run on pump gas.1072hp!
Old Apr 15th, 09, 1:32 AM
Tom Mobley Tom Mobley is online now
mod since about forever, old now :)
TerribleTom II
marketing innovation, but under the hype is a cast iron roller cam. not recommended.
Tom
  #6
Old Apr 15th, 09, 5:40 AM
BillyGman BillyGman is online now
Holy COW!!!!! I've purchased and installed cast iron cams before (not roller ones though) and I've never seen one like that! That's a very revealing video. That is downright freaky. Ofcourse shouldn't have anything to do with it being a Thumpr cam though.
70 Chevelle SS clone (632 CI powered).
  #7
Old Apr 15th, 09, 6:25 AM
TerribleTom II
Has to do with it being a CC cast iron roller though.
Tom
  #8
Old Apr 15th, 09, 7:55 AM
In light of what's been shared, it's difficult for me to argue with you on that point. So are we to conclude that this could've just as easily happened with a cast flat tappet cam? CC or otherwise? I'm thinking that the answer to that would be "yes". because if not, then what would be the difference? After all, the cam in question here was not even installed. All is I know, is I've had flat tappet cams from 3 different aftermarket cam companies, including CC, and I've never seen one like that. That's just plain weird.
  #9
Old Apr 15th, 09, 7:58 AM
66 BRONZE 66 BRONZE is offline
Eric
It's pretty sad when ANY cam company will let something like that go out their door.
1966 Chevelle 300 Deluxe Post, 327cu AFR180CC Street Eliminator, Voodoo, Harland Sharp 1.6 RR, Weiand Stealth Airstrike, 650cfm avs, MSD 4spd 355 posi
http://i183.photobucket.com/albums/x...2/P1010428.jpg
http://i183.photobucket.com/albums/x...2/P1010429.jpg
  #10
Old Apr 15th, 09, 1:57 PM
TerribleTom II
yes it is.
google on cast iron roller, see what comes up.
Tom
  #11
Old Apr 15th, 09, 3:06 PM
kirkwoodken kirkwoodken is offline
Ken
With sand cast parts, which it looks like cast-iron cams still are, sand can imbed itself in the outside of the metal. When those parts are ground, the sand will be knocked out, leaving a hole. It's what happens constantly when maximum productivity/profit are the goal. The cores will be made with less metal to grind off, leaving a surface that may have more flaws. It's what any of us would do if we were in business. The problem is not catching it before it goes out the door.
What I also see on that cam is an indication that the grinding coolant is not well maintained, which leaves 'dirt' in the ground finish. Grinding coolants are cleaned by magnetic and settling tank methods, and sometimes with filtering methods: another labor intensive process that appears to make no profit. In my opinion, one of the things that set Isky apart from early cam grinders was the finish on their roller cams: almost mirror-like. No dirt there. You could tell by the finish you had a first class product.
kirkwoodken
406 SB, Original Bill Thomas '63 Rochester FI
AFR 210, Lunati 501C2LUN, 255/263@.050", .628"
10:1, TH400, 3.31's, 4400 SS
"Life is too short to not run a solid roller cam."
"Nothing is impossible; if you don't know what you're talking about."
Kirkwoodken
  #12
Old Apr 15th, 09, 6:13 PM
And that was the SECOND!!!!!!!!!!!!1 one they sent me like that.
  #13
Old Apr 15th, 09, 6:21 PM
72sbc427 72sbc427 is offline
So those aren't suppose to be "wear indicators" like tires have? sad, so very sad
Wheres that money tree hiding and who forgot to water it?
  #14
Old Apr 20th, 09, 7:48 PM
Almost hate to ask....how many cams like that do you think get installed by builders or DIY that don't care or don't know any better.
Zeke
67 Chevelle
64 Chevelle
69 AMX
TC# 3094 ACES# 7297
  #15
Old Aug 18th, 09, 7:22 PM
Farock72 Farock72 is offline
Chris
I installed a Mutha Thumpr in my 396 and all the lifters wore out in 45 minuts and i did all the recommendations with addatives and oil.Wore a grove staright through the lifter one had no bottom at all.Started it to break it in 5 minutes later started to tap bad.readjusted thought I made a mistake started again did the same thing started to tap.adjusted again and then ran for 20 min and wouldn't stay running due to the valves not openeing on cylinders 1 and 6.This was a hyd flat tappet.Now I have to remove entire engine and rebuild since there are tons of metal floating around my engine.Can't wait to see what other damage it done.Why don't they give us the option in paying for a billet cam?I e-mailed comp cams and guess what I am still waiting for a reply.
Chevelle Tech > General Tech Area > Performance      Current Topic: thumper cams
Human Verification
