Cutting larger round holes in sheet metal, what tool? - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old Apr 14th, 09, 12:25 AM
Rich-L79 Rich-L79 is offline
Super Mod
Rich
Default Cutting larger round holes in sheet metal, what tool?
I had new floor pans put in the wagon and as such I lost a few holes in the toe board/firewall along the way. I need to cut/drill a couple of good sized holes for the back up lights harness and the speedometer cable grommet. Is there a single reasonably priced tool I can buy that will let me drill relatively large sized holes of various sizes? I hate to drop serious cash for monstro drill bits I'll only use once. I have a few hole saws, but they are made for wood not metal, do they make hole saws for metal and if so can I get them at a typical hardware store?
NCOA member #220
ACES member #1670
Team Chevelle #998
1965 Malibu SS L79 Restoration Page
1965 Two-Door Wagon Project Progress Page
2006 Pontiac GTO Preservation Project
Rich Cummings
Old Apr 14th, 09, 12:47 AM
Derek69SS Derek69SS is online now
"The Stig"
Default Re: Cutting larger round holes in sheet metal, what tool?
Uni-bit or stepped drill bits work great for getting perfectly round clean holes in sheetmetal.
http://www.irwin.com/irwin/consumer/...rwinProd240001
Derek Kiefer, member of Minnesota's Northstar Chevelle Club
69 Malibu Pro-Touring stroker LS1-383/T56 - 69 Chevelle SS396 325/3spd
Old Apr 14th, 09, 12:54 AM
gearheads78 gearheads78 is offline
what you are taking about would still be a pretty small hole. Just us a metal hole saw in the size you need. Home Depot and the like will have what you need.
Richard
66' Cutlass 330 TKO 600 C6 brakes ect (see it come together here) comming soon 455
If only the damn trees weren't so addicted to that poisonous gas Carbon Dioxide.
Old Apr 14th, 09, 1:16 AM
floyd66 floyd66 is online now
Tom Lloyd
another vote for uni bit. It is the only sheet metal drill I would use.
Tom Lloyd
my 66
take my advice, I'm not using it.
Old Apr 14th, 09, 1:37 AM
troposcuba troposcuba is offline
Sean
depends on how big a hole you are talking about, but there is a technique they tought us (I am an aircraft structural repair guy) called chain drilling. if you are talking about a hole the size of your fist or odd shaped, this works pretty well. all you do is use a normal drill bit (.125 or so) and drill a series of holes right next to each other (like a chain) INSIDE of your scribed line. then use a rotary bit or file or other method to clean it up the edge to your scribe line. easy as that.
Sean
'65SS, 385ci, AFR 195's, Comp XR 288HR, Forged bottom end, TKO600, 3.73/12 Bolt
Now in our new home in Tucson AZ
http://spotted.stripes.com/galleries....php?id=337573
"Aint no fun 'till somethin gets broke!"
  #6
Old Apr 14th, 09, 2:38 AM
MikeMalibu MikeMalibu is offline
Team Member
Mike
Low cost step drills work well up to about 1.25 inch. The largest I have is about 2.5 inch, but it cost about $75. I recommend a hole saw for the speedo cable grommet on your 65 wagon. You can find metal versions at Home Depot for a reasonable price.
  #7
Old Apr 14th, 09, 11:04 AM
jpr95 jpr95 is offline
Jimmy
Rich, since you are close to me, stop by my welding/fab shop and grab what you need... you are more then welcome to any thing you need to finish up your project..
Jimmy
DONE!
http://i248.photobucket.com/albums/g...g?t=1229752308
http://i248.photobucket.com/albums/g...g?t=1259179197
1970 chevelle, Shadow Grey Restomod
Mark Jones 505 BBC
666 HP
670 TQ
Th 400, 2800 stall, 331 gear
  #8
Old Apr 14th, 09, 3:31 PM
goldburg goldburg is offline
Team Member
Daryl
I could not lurk any longer, after gaining years and years of all of you guys experience in only a short time, I had to contribute. If you know an electrician- ask if you can borrow his "greenlee punch". Or more accurately, his knockout punches. It is a very simple hand operated tool that will punch a nice, clean hole in any flat surface up to around 16ga mild steel. It leaves no flash, no sharp edge. Very nice and easy to use. Hope this helps.
  #9
Old Apr 14th, 09, 7:02 PM
Scotch Scotch is offline
Scott
I used a Unibit step drill to drill the holes for my hood pins, and it was clean and painless. Another vote for Unibit!
See my Pro Touring '67 Chevelle Wagon at:
http://www.flickr.com/photos/1192966...7594110671642/
Winner- 2011 Car Craft "Real Street Eliminator" competition
  #10
Old Apr 14th, 09, 7:19 PM
JNorton JNorton is offline
Team Member
John
I agree, Unibits are great until the hole gets big. Use a punch for bigger holes. I will bet that you could rent a punch set at a U-Rent-Um type of place. Or, like Daryl said, find a sparky that will let you use his.
1972 Malibu: Under construction. Visit the progreess here http://s844.photobucket.com/home/72Chevelle/allalbums
  #11
Old Apr 14th, 09, 7:29 PM
langss langss is offline
Lang
I think Sears still sells a Circle Cutter.Its for holes 7/8" to 4".It says on the box for Brass,Wood,or Plastic, but I have used it on thin sheet steel and all different thickness of Aluminum.Its basically a Drill in a Fitting with an adjustable arbor with a cutting bit on the end.You adjust the arbor to what ever diameter hole you want.The P/N was 3645 if its still available.
  #12
Old Apr 14th, 09, 8:43 PM
Super Mod
Rich
I like the idea of the punch, but how do I punch such holes if I can only access one side of the metal at a time (inside the car or outside the car)?
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
  #13
Old Apr 15th, 09, 11:23 AM
Team Member
Mike
Yes, Rich, with a punch you need access to both sides of the hole.
Chevelle Tech > Information Exchange > Chevelle Tech      Current Topic: Cutting larger round holes in sheet metal, what tool?
Human Verification
