How do you repair the clear coat on aluminum rims. - Chevelle Tech
Auto Insurance
Body Shop Paint & Body Forum
Old Apr 8th, 09, 7:05 PM
james a larson james a larson is offline
Question How do you repair the clear coat on aluminum rims.
Some water has gotten under the finish and caused some discoloration on a couple of my aluminum rims on my 2004 Chevy Silvarado. Is there a way that I can clean that up and refinish the rims in the garage rather than take them to the body shop? Thanks.
Old Apr 8th, 09, 8:57 PM
Dave Birdwell Dave Birdwell is offline
Chevelle Doctor
Send a message via ICQ to Dave Birdwell Send a message via Yahoo to Dave Birdwell
Default Re: How do you repair the clear coat on aluminum rims.
Not easy to do, James. We have a company around here that takes the wheel, strips it, repairs any needed areas, refinishes them like new, and they last better than new, for like $180 a wheel. Our local place is called Transwheel.
Owner of Daves' Restoration, The cure for the common hoopty.
70 Chevelle L78/M21
00 Chevy Silverado 1500 4x4
06 Equinox
Wanted-1976 Nova SS.
Old Apr 9th, 09, 9:32 AM
67shovel 67shovel is offline
Roger
You would have to strip it to get off the remaining clear coat. Then buff the oxidation off the machined surfaces, clean up your cast areas and reclear.
Old Apr 10th, 09, 9:33 AM
$180 is kind of out of the question for me Dave. Would rather spend the $$'s on the Chevelle. Is there an easy way to strip the clear? Do you just use a paint stripper? After buffing the oxidation what about reparing the rim so that the clear adhears good?
Old Apr 10th, 09, 9:40 AM
figbash figbash is offline
Tom
It's a BIG job.
You'll need to strip the clear and it's probably powder coat so paint stripper won't work. It'll need to be sanded off. Once the clear is off you'll need to clean up all of the oxidation and polish the rims. Then you'll need to get the rims super clean so the clear will stick with wax and grease remover followed with Alumiprep. Finally you'll need to clear the rims with a urethane clear coat. After all that work, the urethane clear won't hold up as well as the original powder coat and you'll likely have to do it all over in a couple years.
I would just live with it or find some different wheels.
Tom
1972 CHEVELLE SS
  #6
Old Apr 10th, 09, 6:12 PM
SSTodd SSTodd is offline
Todd
Send a message via AIM to SSTodd
Check this out from POR 15: http://www.por15.com/WHEEL-RESTORATI...oductinfo/WPK/ Not sure how this works but I was thinking about using this kit for some s-10 wheels I had.
  #7
Old Apr 10th, 09, 11:04 PM
Chevelle Doctor
Originally Posted by figbash View Post
It's a BIG job.
Tom
By the time you get them stripped, cleaned, prepped, etched, and painted, you'll have more than $180 a wheel in them. Good clearcoat alone is over $300 a gallon sprayable. Acid etch prep is $50 a gallon. Figure $20 a wheel to get them strippped....not to mention the 3 or 4 hours it'll consume......see where I'm going with this, James??
You might be able to clean the area up well enough to brush some activated clear onto the wheel, and that might hold you for a while.
70 Chevelle L78/M21
06 Equinox
  #8
Old Apr 10th, 09, 11:19 PM
davis95 davis95 is offline
Doug Davis
E-Bay what you have and buy new. You'll come out cheaper with much less legwork.
66 Chevelle
350/400 Turbo
12 Bolt Eaton Posi w/3:73's
Team Chevelle Member # 3540
  #9
Old Apr 10th, 09, 11:41 PM
fishhead fishhead is offline
Shane
X2
Ebay...perhaps you can get a whole set for $180...
If youíre incompetent, you canít know youíre incompetent. [Ö] the skills you need to produce a right answer are exactly the skills you need to recognize what a right answer is.
óDavid Dunning
  #10
Old Apr 11th, 09, 10:16 AM
Well I guess that project is crossed of the list. Thanks for the information.
Chevelle Tech > General Tech Area > Body Shop      Current Topic: How do you repair the clear coat on aluminum rims.
Location
*REQUIRED*
Insurance
First Name
Human Verification
