Kinked brake line - Chevelle Tech
Chevelle Parts at
GROUND UP &
Auto Insurance is the premier Chevrolet Chevelle Forum on the internet. Registered Users do not see the above ads.
Brakes, Suspension & Steering Conversion questions & more.
Old Apr 4th, 09, 9:02 PM
JeffN JeffN is offline
Default Kinked brake line
I was going to change the rear flex line at the diff and started to turn the nut on the hard line, but noticed that the line turned with it. I immediately turned it back and it straightened out somewhat but is still a little flatened. I sprayed with PB Blaster before I wrenched, but still happened. How much narrowing of the line as a result of kinking can it take before it starts impeding brake operation? If fluid comes out during bleeding of the rear brakes, is that good enough? Am I destined to put a new hard line on? Thanks.
Old Apr 4th, 09, 10:15 PM
Bryan59EC Bryan59EC is offline
Default Re: Kinked brake line
Probably should just go ahead and order a new line for it.
If you get a stainless steel line, you may have trouble getting to seal (I had a hell of a time getting all my leaky connections to stop leaking on the 59-----went with the standard steel line on the 66---that car not done yet)
I don't think it will be much of a problem getting a new line in. I cannot remember which line gave me fits on the 66--fuel or brake---and the body was off the frame!!!
I think it was the fuel line----the brake line did not have to go thru any holes in the frame.
Bryan's toyz
59 ElCamino 454/TKO 5spd--(daddy)
66 ElCamino 3oh7/TKO 5spd (mousey) Almost done On the street now!!!
65 Ranchero v8/4-spd, that my uncle bought new
Old Apr 4th, 09, 10:46 PM
Racing Racing is offline
I had a couple of hard lines turn with the nuts. Penetrating oil didn't touch them. I used an acetylene torch with a pin point tip to heat the nuts. The flame was concentrated on the nut. Just a few seconds of heat and the nuts were free from twisting the tubing.
Dan's 70 Chevelle
Spencer's 72 Chevelle
Old Apr 4th, 09, 11:17 PM
brians65 brians65 is offline
working with the brakes why take the chance of an accident if you ride with family a few bucks is well worth the peace of mind knowing its good (brian)
Chevelle Tech > Mechanical > Brakes, Suspension & Steering      Current Topic: Kinked brake line
First Name
Human Verification
