Lucas gear oil and posi additive?? - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Apr 2nd, 09, 9:16 PM
slvrchvllss slvrchvllss is offline
Tom
Default Lucas gear oil and posi additive??
Just got back from the auto store. Bought 2 bottles of Lucas Gear Oil 80-90 for my rear differential 70 Chevelle SS with 3:31 posi). It says on the bottle that the the posi additive is not necessary. Looking for thoughts on this. The guy behind the counter at Advance said it won't hurt anything to add it. I want to add it anyway. Just wanted to hear from people who may have run into this situation before. Thanks in advance. Tom.
Old Apr 2nd, 09, 10:27 PM
Lionel-n-Chevelles Lionel-n-Chevelles is offline
Gold Founding Member
Default Re: Lucas gear oil and posi additive??
I used the Kendall 80-90 Gear Oil with the Posi Additive. I still went to the dealership and purchased the Posi Additive. It will not hurt anything.
Tory
ACES Member #1890
Team Chevelle Gold #288
1964 Malibu SS Unrestored 36,000 Mile Survivor
1964 Malibu SS Hardtop
1966 Chevelle SS 396 Unrestored 76,000 Mile Survivor
1968 Malibu L-79, 1 of 4082 - SOLD
1955 Chevrolet Bel Air Unrestored 15,000 Mile Survivor
1955 Chevrolet Nomad
1984 Hurst Olds w/ Factory Sunroof, 1 of 99
1985 442 White / Grey w/ Factory Sunroof - SOLD
BowtieAaron BowtieAaron is offline
Aaron
Send a message via AIM to BowtieAaron
i just dumped 1.75 pints into the 7.5 in my dd ta.
posi still works, but ive only got about 300 miles on since then. it said it meets the gm number.
aaron
71 chevelle
355 10.3:1cr, brodix ik180 heads, voodoo hyd roller, holley efi intake, eMS-PRO, 60lbs dekas, ls tb, 700r4, 3.55 gears
Soon to be 7875 turbocharged!
368rwhp 383rwtq n/a with carb
12.23 @ 110 1.68 60ft
Dyno video NA
http://youtu.be/PvZ7tDVyryw
Old Apr 5th, 09, 9:14 AM
Tom
Can you even find a name brand gear oil without the additive in it? I just don't want "too much" additive in the rear end if there is such a thing. I would like to use the GM additive since I already have it, and I am willing to get different gear oil if there is even a small concern. Thanks again. Tom.
Old Apr 5th, 09, 2:09 PM
JJ'65 JJ'65 is offline
Wink Re: Lucas gear oil and posi additive??
You can find gear lube "without the additive". It is API GL-4. More likely to find it in a hardware or farm supply store. Supposedly the "additive" makes it more likely that the oil will attack copper/zinc alloys brass bronze etc. like maybe synchromesh components in a transmission. I wouldn't for instance use GL-5 in my roto-tiller because it has a bronze gear in the transmission.
In any case, some good quality API GL-5 gear lube will be fine for limited slip differentials including "Positraction". See here for some words and specs and applications.
If it was me, I'd take the Lucas and additives back, and check some Pennzoil or Quaker State or other brand name GL-5 spec and see if it covers limited-slip. If it does I'd run it, and use some additive only if I had any grabbing or chattering like I did with my '65 after 90,000 miles. I replaced the stock fill with Sta-Lube GL-5 90 wt., and its been OK since, w/o any additives.
Just my $0.02
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: Lucas gear oil and posi additive??
Human Verification
