| Chevelle Tech Current Topic: 12 bolt rear end codes? | ||
| Register | Photo Ads | FAQ | User List | Social Groups | Calendar | Chat | Search | Today's Posts | Mark Forums Read | Insurance | Auto Loans | Auto Escrow |
| Transmission & Driveline Transmissions and Differentials |
I have a 12 bolt rearend that im rebuilding and converting to a possi. I have sand blasted it removed all the bearings and gears. The codes on the rearend are CKD 0826B, GM52, 3969278NF, H48, CON1, E stamp under cover, 1234567890. I have surched the Internet and the 3969278NF is supposed to be a 71-72 but date code dosent match. Please help make sense of this because im confused.
Thanks John |
| Sponsored Links | ||
Advertisement | ||
#2
Appears to be from a '70 per the info I've got.
The 3969278NF was used '70-'72. Your code CKD was '70. Possible that the 8 in the H48 is a 0 ?? |
That casting nimber was used from 70-72 but chevellestuff.com shows that your rear is a 1970, because that is the only year that shows a CKD code. Meaning it was a 2:73 ratio.
08 means the 8th month, 26 is the date and B means it was built at the buffalo plant
Terry ACES # 5021 Experience is something you don't get until just after you need it. |
i think its a 9 the 8 9 look close alike but not a 0 diffently
| Sponsored Links | |
Advertisement | |
| Display Modes | |
