Best fit Header for 67' bbc Chevelle ????? - Chevelle Tech
Auto Insurance
Old Mar 21st, 09, 4:05 AM
blownnalky1 blownnalky1 is offline
Send a message via AIM to blownnalky1 Send a message via Yahoo to blownnalky1
Cool Best fit Header for 67' bbc Chevelle ?????
Ok Guys im trying to find out the best fit header for my 1967 Chevelle with a BBC in it. It does have power steering as well, Ive tried 3 different headers and everyone of them require that i unbolt the engine from the drivers side motor mount just to get it in. not to mention it still fits pretty snug against the steering rod. Ive thought about going to the shorty headers, has anyone tried those? please let me know. Ive herd headman has a good set, but have no idea what the part number is. so if anyone can help please do. thanks
Scott
Old Mar 21st, 09, 7:11 AM
427L88 427L88 is offline
Gold Member
Gene
Default Re: Best fit Header for 67' bbc Chevelle ?????
All I can say about shorties is that they dont do much more than manifolds.
Unbolt the engine, yeah, for sure, and usually have to raise the enigne a couple of inches to get it in there, for any brand of header. No avoiding it. With the 2" Hooker # 5 tube should be clearanced a bit with a socket.
Gene
ACES 3112/Team Chevelle Gold #62
Be big, be a 'builder'!
Old Mar 21st, 09, 11:13 AM
MikeyB MikeyB is offline
mike
I had 2" hooker comps and had to beat tube 3 to clear the steering shaft. Went with the 1 3/4" headman elite form jet hot and they fit fine without any hammering. And, oDdly enough, the hp and torque went up slightly on the dyno!
Old Mar 21st, 09, 11:30 AM
carcia carcia is offline
Chris
Seen a lot of previous posts talk highly about the Hedman Elites for this application.
I have a '66 block going into a '67 with headers (unknown brand - though they worked well with the 454 I pulled) --- My concern has been more of access to the oil filter. With the 454 in, I had to loosen the driver's side header at the engine so I could swing it out just a bit to allow enough room for the oil filter to slide out/in. Any comments on this would be appreciated as well.
Chris
Old Mar 21st, 09, 1:55 PM
mike
Chris, I've had no problems accessing the oil filter. I wrap a piece of alum. foil around the header, in case I spill oil from the filter(trying to keep that jet hot coating clean!), but I get the old filter out and the new one in with no probs.
  #6
Old Mar 21st, 09, 2:51 PM
hey mikey any idea what the part number is on your headman headers
Scott
  #7
Old Mar 21st, 09, 3:11 PM
R66SS427 R66SS427 is offline
Team Member
Larry
Just put 2" Hedmans on my 66 part #66002 for the coated. See my post in performance about the fit. I'd stick with the 1 3/4 if I had it to do again.
67 chevelle, 496/400/12bolt.
red/black int.
"Sure, I can make that slower for ya."
ACES member # 9266
Can-Am Chevelle member# 276
Team Chevelle member # 4917
  #8
Old Mar 22nd, 09, 11:14 AM
mike
Scott, the part number from jet hot is HD68198 1 3/4" x 3". Mike
  #9
Old Mar 22nd, 09, 12:15 PM
Thanks mikey b
Scott
  #10
Old Apr 5th, 09, 8:41 PM
littlehop littlehop is offline
Keith
[QUOTE=427L88 With the 2" Hooker # 5 tube should be clearanced a bit with a socket]
did you have to heat the header first before bending/denting with a socket,and by heating the header will it damage the coating?
Keith
TC # 1802 MCC #515
67 Chevelle
496 CI,Brodix RR,Erson Cam,Hooker Headers
40 series Flowmaster,TH400,3:73
email: littlehop@verizon.net
http://s817.photobucket.com/albums/zz91/littlehop/
  #11
Old Apr 5th, 09, 9:23 PM
Paul-ish Paul-ish is offline
Team Member
Paul
Talking Re: Best fit Header for 67' bbc Chevelle ?????
Last summer i bought the Flowtech ceramic coated ones.
I had to lift the motor a little. Then after scratching the crap out of them i figured out the passenger side would not fit (the front tube hit the crossmember) So i cut 3/4 of an inch out of it warmed it up, bent it together and weldid it. Worked out fine and all the ugly stuff is on the bottom. I think they were less then $250( I got a real good deal from my local speed shop when i demanded a refund) So if your up for a little labor they look great in the engine compartment.
LOL
Paul
454/T400/9" in a 67 Beaumont
  #12
Old Oct 13th, 10, 1:21 AM
Blk04SR Blk04SR is offline
What about a 502 bbc in a 66 chevelle you guys still think the 1-3/4 will be okay? I wanna go a 2" but will fitment be an issue?
  #13
Old Oct 13th, 10, 3:31 AM
67RAT 67RAT is offline
I run hooker super comps 2 1/8 tubes,some close areas,but no clearance problems,oil filter goes right up in,I dont/will not dent header tubes to make them fit...
rth
My Showroom
  #14
Old Oct 13th, 10, 7:37 AM
forcd ind forcd ind is offline
if the header hits the steering, sometimes you can shim the steering box, it will swing the shaft towards the fender well just enough-also there is a little wiggle room where the shaft goes thru the firewall
since their a tight fit, if the body is off a little on the frame, can cause steering interference
i prefer not to dent any pipes, cut and move them, but sometimes a little "tap" is needed, lol
when your credit cards are maxed, have the limits raised
  #15
Old Oct 13th, 10, 10:31 AM
rth
I was thinking of a 2" primary tubes...maybe even stepped if they dont cost an arm and a leg.
Part number? what about headman?
i hear you
Chevelle Tech > Mechanical > Engine      Current Topic: Best fit Header for 67' bbc Chevelle ?????
Human Verification
