Big Block Chevy Small Journal Crank/Rods - Chevelle Tech
Auto Insurance
Old Mar 16th, 09, 12:39 PM
mc71454 mc71454 is offline
Tom
Send a message via AIM to mc71454
Default Big Block Chevy Small Journal Crank/Rods
Can someone give me their opinion on why and when a Small Journal (2.10") rod and crank would be used in lieu of the standard 2.20" ? I have a set of Oliver Rods that are small journal.
Tom B
'71 540 Street/Strip Monte Carlo 10.310, @ 129.86, Pump Gas, Full Exhaust
'70 Chevelle, 462, 3.42's, 12.35, 1.66 60', 107.0 4020 lbs. Full exhaust Pump Gas
'87 Regal Limited Turbo T, Chip & Dual exhaust - 13.08, 1.78 60'
'75 Chevelle S3, 454, Auto (Son's Car)
'07 Tundra TRD 5.7 V8 4WD, 3" Lift
2015 Tundra TRD Pro - (On order)
Old Mar 16th, 09, 12:50 PM
trmnatr trmnatr is offline
Banned
Butch
Default Re: Big Block Chevy Small Journal Crank/Rods
high rpm
In my opinion 7,500rpm and up but you may want to check with Mike AKA Wolfplace, Carl AKA CNCBlocks, Mark Jones AKA VORTECPRO and Tom AKA 3VPerformance
In small blocks above 7,500rpm i prefer the smaller rod journals (2" and less) over the larger rod journals (2.1").
With a good crank i dont see no durability issues however it may be a little different in a rat engine than a mouse engine - Check with those guys
Hope this helps
Old Mar 16th, 09, 1:17 PM
GRN69CHV GRN69CHV is offline
Team Member
Joe
I thought they used those to offset grind the crank throws for either a stroker or de-stroke application.
Status: Car-Less
http://www.chevelles.com/showroom/sh...2/limit/recent
Old Mar 16th, 09, 5:55 PM
oldtimr oldtimr is offline
Team Member
Tim Smith
'Bearing speed'
a 2" journal has a circumference of about 6.28, and at 7000 rpm the bearing sees (7000*6.28) inches of surface contact or 43,960" per minute.
a 2.1 has a circumf of 6.59, at 7000 rpm the contact is against 46,158"/minute.
about 5% less wear on the smaller of those 2.
Tim Smith
Old Mar 16th, 09, 6:42 PM
BillsCamino BillsCamino is online now
Gold Founding Member
"Wild Bill"
Send a message via AIM to BillsCamino
Originally Posted by oldtimr View Post
'Bearing speed'
That's the way I understand it. Common in NASCAR.
1972 GMC Sprint
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
  #6
Old Mar 16th, 09, 10:07 PM
engineguy engineguy is online now
Bill R
Main reason for small journal cranks is reduced bearing speed. Current BBC Pro Stock and Comp Eliminator cars are utilizing very small (Honda & Olds Quad 4) rod journals and 2.500 diameter mains (DCRE III block).
Another reason to use small rod journals is to enable the crank to be offset ground to either stroke or destroke the engine, as someone has pointed out in a previous post.
Bill
64 Chevelle Malibu Sport Coupe (original owner) car now has 427" BB, Jerico 5-spd. trans., Dana 60 rear end.
SAE Member (20+ years)
ASE Master Certified Engine Machinist
AERA Certified Professional Engine Machinist
  #7
Old Mar 17th, 09, 1:41 PM
Tom
Thanks !!!
Tom B
Chevelle Tech > General Tech Area > Performance      Current Topic: Big Block Chevy Small Journal Crank/Rods
Location
*REQUIRED*
Insurance
First Name
Human Verification
