Installing quarter glass - Chevelle Tech
Auto Insurance
Body Shop Paint & Body Forum
Old Mar 1st, 09, 4:25 PM
Finally Finally is offline
Hank
Default Installing quarter glass
I posted a few weeks ago how to remove the quarter glass. Well I just finished reinstalling the passenger side glass and thought I'd let you know how that went. Took about an hour, not sure exactly as that d*** Ray called while I was right in the middle of it.
First I'll go back a week when I installed the chrome trim on the front edge of the glass. Searched the internet and called several glass shops, no luck finding the 'glass tape' originally used. The other option was urethane, the kind used for setting windshields. Napa carries it, about $20 for a caulk gun tube. Beware, unless you have an electric or air powered caulk gun this stuff is like trying to squeeze a rock through the gun. Also make sure the tube fits in your gun before you open it up. The tip screws on and the end is wider than most tubes of caulk. I have 3 guns and it only fit in one because of the wider end.
Basically just filled the chrome rail about half way with urethane then set the glass in. Don't worry too much about the mess if and when the urethane squeezes out. Once it's dried just use a cutter along the edge of the chrome and a razor paint scraper to peel it off the window. Any small bits left can be rubbed off the chrome and glass with your finger nail or rag. The top edge of the strip is open between the two sides, glass side and rubber seal side. The urethane will squeeze through to the rubber side where you don't want it. Make sure you cut it out of there before you install the window and insert the rubber seal. I left the rubber seal out until after I installed the window, just gives you a little more room while setting the glass down in the panel.
Now for installing the glass, first I taped the edges of the glass and the chrome strip so I wouldn't scratch them or the car. Oh, almost forgot, I scrubbed the guide rail down with Simple Green to remove all the old grease. Made it lot nicer during the install, didn't get grease all over my hands and the window.
Set the guide rail, the one you cleaned all the grease off of, down inside the body panel. Slide the window down into the panel a few inches. While holding the window lift the rail on to the nylon rollers. Now you need to hold the glass and rail with one hand, if you removed the jamb vent you can slide your hand in there. With the other hand you need to position the regulator lift arm to the correct spot and lift or drop or rotate glass and rail until the arm goes into the track.
Now while still trying to hold all of this mess with one hand, install the guide rail bottom bracket. Doesn't have to be tight, just enough to hold things up. Then install the bracket to the top of the panel, the one the top of the guide rail bolts to, then install bolts through bracket into guide rail.
Now you have to get things aligned so the window is straight with the front glass and the gap is correct. First start by getting the two windows in line with each other, top to bottom. Slide the bottom guide rail bracket towards the front or rear of car to get the vertical alignment then lightly snug it down. The washers have teeth so it won't move easily. Next slide the top of guide rail to the front or rear until you get the proper gap between the two windows. You may have to adjust the bottom again as the vertical alignment may have changed a little. Then of course you may have to fine tune the gap again. Last step is to adjust the bottom guide rail bracket so the window slides into the upper seal. Loosen the bolt inside the body panel that holds the guide rail to the bracket. Push the rail out or in so the window slides up into the seal properly. Install the upper window stop so you can't drive the window too far into the seal. Tighten everything down, remove tape, install rubber seal in chrome strip. Lube up the slides and you're done.
My wife is out of town and she has our camera. I'll try to find my son's camera and see if I can take some pics of the adjustment points. I expected the job to take a lot longer but it really wasn't bad at all. I should have done the other one too but it's pretty cold in the garage. Decided to have a beer and type this instead.
Found it. First pic is driver's side guide rail, top of rail on left. Fixed nylon guide on window, the one that does not turn slides down the center slot of guide rail from the top.
Second pic is bolt holding bottom of guide rail to panel. Slide this front or rear to align windows vertically.
Third pic is top guide rail adjusting bolts. Slide these front or rear to obtain proper gap between the windows.
Fourth pic is the finished job. Well almost finished, need to get out the Windex and clean the windows. It's not the best pic but gap is uniform top to bottom.
Click image for larger version
ID:	19360   Click image for larger version
ID:	19361   Click image for larger version
ID:	19362   Click image for larger version
Hank
70 Chevelle SS396(454), M20, 3.73
My Chevelle
Old Mar 1st, 09, 5:23 PM
von von is online now
Lifetime Founding Member
Von
Default Re: Installing quarter glass
I installed my '69 windows basically the same with the following exceptions: I loosely installed the lower bracket to the guide rail before lowering the guide rail into the body, leaving the guide rail unbolted to the body. I guided the window rollers onto the guide rail as I lowered the window glass into the body, then raised the rail as required to bolt it to the body. Having the Astro vent out of the jamb is almost a necessity IMO.
von '69 300 Dlx SS '69 Malibu TC #15 ACES #1575 HSCA #5
http://www.chevelles.com/showroom/da...m/DSCN1135.JPG
[img]
http://www.chevelles.com/showroom/da...m/DSCN1397.JPG
Old Mar 1st, 09, 6:30 PM
Mike72ss Mike72ss is online now
Team Member
Mike
Looks great Hank!
Good write up too.
I'm ready to start my door and quarter glass install soon.
Do you do house calls?
Mike
Old Mar 1st, 09, 7:11 PM
Hank
Originally Posted by Mike72ss View Post
Looks great Hank!
Good write up too.
Mike
Maybe, sounds like you might be close. Really isn't that bad. Don't take off more or loosen more than you have to. See my post on removing the quarter windows.
Hank
My Chevelle
Old Mar 1st, 09, 7:17 PM
1badss396 1badss396 is offline
Bad Brad
Location: NSB Or Daytona Beach Shark Bite Capitol of the World
Hank it sounds great, I might just take my windows out in my vert and have you install them for me so I can sit and drink beer and watch you, hehe
I started with Nothing and still have All of Nothing!
Bad Brads 1969 Convertible SS
TC # 2747 ACES # 7166
2009 AACA 1st Place National Junior Award
2009 AACA National Senior Award
ACES Chevellabration Top 3
2010 AACA First Place Grand National Award
  #6
Old Mar 1st, 09, 7:20 PM
john5469 john5469 is offline
John
Nice work Hank. Do a video of glass install, i like pictures, cause words are harder to transfer from my eye balls to brain in my head.
Do you know the best place for new glass parts?
'69 Chevelle ss402/300,red,M20 M20 by Wally
'54 Chev 210, black, frame off
'69 Chevelle rusty
'69 4 DR 350 w/pg
http://www.cheeseandburger.com/
  #7
Old Mar 1st, 09, 7:25 PM
Team Member
Mike
Heck, mine's already out, Send me the beer and I'll watch him for you!
Mike
  #8
Old Mar 1st, 09, 8:16 PM
Hank
Thank's, don't think I mentioned that but I did basically the same. I installed the lower bracket to guide rail after it was in the panel then lowered the window in. Same result but a good point.
Hank
My Chevelle
  #9
Old Mar 1st, 09, 8:21 PM
Hank
Those videos Tom did on rearend bushing are great. I can't believe how fast he knocked those bushings out and installed new ones. Unfortunately I'm usually by myself when I'm working on the car and I'm no where as good as Tom.
I installed used glass, don't know where to go for new.
Hank
My Chevelle
  #10
Old Mar 1st, 09, 8:24 PM
Hank
Better yet, I'll be in FL in a couple weeks. How 'bout I sit and drink beer and watch while you mow your lower 40? Oh, and I don't do verts, I'm sure it's totally different.
Hank
My Chevelle
  #11
Old Mar 1st, 09, 9:22 PM
Bad Brad
Hank I have an extra mower with your name on it ready for ya....
Chevelle Tech > General Tech Area > Body Shop      Current Topic: Installing quarter glass
Location
*REQUIRED*
Insurance
First Name
Human Verification
