555" BBC 'pump gas' build - Chevelle Tech
Auto Insurance
Old Feb 1st, 09, 12:14 AM
helicoil helicoil is offline
Default 555" BBC 'pump gas' build
This seems to be best '540 BBC' build forum on the net that I can find so what better place is there to add another one. I was led to this site in a search for some info on my 555" one day and have been stuck to it ever since. I am not a Chevelle owner but it seems many are not either. I will post the progresss of my 555" build going together, my dyno results, and then the track times in the car, which BTW is early shoebox Nova.
I have been acquiring parts for several years now for this and many are left over from a blown alcohol 509 BBC effort for a rear engine dragster that I have since sold. I am a little more liberal than most when it comes to what I can street drive. My car does not have P.S. or P.B. and is quite a bit lighter than many so I can get by with some more radical parts, at least IMO. The goal is mid 9's on motor and mid 8's on the N20.
I will try to add lots of pics of my progress starting with these.
Comments or suggestions welcome.
00 Camaro SS 9.80 et, 3800#, 20+MPG/pump gas
00 Firehawk 28x10.5's, LS6, D1SC, TH400 - 9.20's
66 Nova SS 9.60's, 406/N20, 26x10 ET Streets
66 Outlaw 10.5 Nova 8.0's (2001) 400" 14-71/Inj
555" BBC pump gas - 1234HP
Old Feb 1st, 09, 12:17 AM
cuisinartvette cuisinartvette is offline
Sheepster. BAH!
Default Re: 555" BBC 'pump gas' build
Pffft! Whats up with the low-budget stuff man?
Just kiddin, VERY nice pieces you have there. The last pic looks fantastic.
You planning on grinding the stud down where it hangs or leaving as is ?
Keep us posted with more pics!!
This post is a duplicate of a post that you have posted in the last five minutes.
Old Feb 1st, 09, 12:21 AM
Jebchevelle Jebchevelle is offline
Jeff
looks like a nice build.
78 Malibu 454 9.6:1 comp with Brodix RR Ovals, Moral lifters. th350,2400 stall, ford 9in full floater with 3.70 gears and lightweight locker, 27X10.50-15 Hoosier QuickTime Dot tires.
Old Feb 1st, 09, 12:31 AM
I have some more pics to add. First step was a trial fit of all the components so I wouldn't run into any surprises through the process.
I had a friend bush the lifters and size them to .9045" with his BHJ fixture, no pics of that process taken as it was outside the shop.
Step 1 was size the cylinders so the pistons would fit.
I bored the block to 4.556" and honed it with the ARP studs torqued to 80ft. lbs with Felpro MLS gaskets and some huey alumunium torque plates.
Bore is 4.560" for this build.
Step 2 was line hone the mains as they were .0007" tight
I sized the small ends of the rods to get .001" pin to rod clearance, they came at .0007" out of the box.
Old Feb 1st, 09, 12:42 AM
Yes, the bolt for the rocker stands protrudes into each of the intake ports on all 8 runners. Once I figure the shim thickness necessary for the stands I will torque them in place and go in there with a carbide burr and blend them into the port.
Alot of the pieces are high end, but I didn't buy them all at once. A little here, little there. Many were originally going to be used in a 1500 HP blown alcohol 509. I'm tired of sitting on them, time to put them to use!
  #6
Old Feb 1st, 09, 12:56 AM
A few more pics of a preliminary mock up.
Miles of rotating clearance in the block. No grinding necessary. Crank e/p was .007". Piston to deck was .004" after square decking the block .015". Looking for a quench of about .045"
  #7
Old Feb 1st, 09, 1:18 AM
I installed the Dart 360's to check P to V and rocker geometry, yes I said 360cc heads will be used as they were one of the original items from the blown alcohol build. These are older castings from 1999, but Ron's Porting in St. Louis did them up very nice. Flow numbers on these are better than the current Pro 1 355 CNC models. I will post them later when I have the sheets in front of me. They are BIG, but I have light car and plan to spray a decent amount, I don't think they will hamper my goals, NA or on the bottle.
I have several cams to chose from that I will mention specs on later, still trying to decide what to use. I am using T&D rockers with a 1.8/1.75 combo which will put me at a 'net' lift of approxiamtely .800". I did say my idea of a street driven engine was little different than some didn't I? This is just going to be a toy with most of the emphasis placed on performance, believe it or not, with a budget in mind. I didn't have the luxury to go and buy the latest, greatest heads or build a bigger inch engine on a wim, I have had many of these parts for many years now and it is what it is. I have decided to build this 555" 'pump gas' effort engine.
All in all, everything fits pretty well. I need to clearnace the pushrod holes in the heads to run the 7/16" pushrod tubes, set the rocker stand heights after deciding on the camshaft and do some other little massaging but not as bad as I expected.
  #8
Old Feb 1st, 09, 1:25 AM
FourEightyNine FourEightyNine is offline
Brian
Send a message via AIM to FourEightyNine
Very nice helicoil welcome to the site
  #9
Old Feb 1st, 09, 2:04 AM
Wolfplace Wolfplace is offline
Mike
Very nice,,
Great pics, shows some of the work involved in doing this stuff correctly even with some of the best of parts
They don't exactly fall together
One thing I would be concerned with is those screens, I don't like restricting the return that much but I think I mentioned that on Speedtalk a while back when you were asking about the lifters?
Looks like this is going to be a killer "street deal"
Mike (Wolfplace)
VISIT US AT
+4axis CNC block machining+
Welcome to the internet,,, "Experts" made daily
"Life is tough.,, Life is even tougher if you're stupid."
----John Wayne----
  #10
Old Feb 1st, 09, 2:25 AM
540Hotrod 540Hotrod is online now
JIM
Going through a very similar build right now. Takes LOTS of time and you have to measure and check everything 3 times at least. Nothing fits the first time around perfectly when it's all new stuff.
Looking forward to the rest of the build and your results!
JIM
'67 Vette-555"/Gforce 5 Spd/Dana 60 IRS-3.07's
9.90@141.40
New: 1140 RWHP ET?
http://s318.photobucket.com/albums/m...rrent=Jim3.mp4
http://s318.photobucket.com/albums/m...rrent=Jim4.mp4
"...when it's not pointing at a wall...grab a gear!"
*This Life Stuff ain't no dress rehearsal"
  #11
Old Feb 1st, 09, 2:48 AM
DragRacer DragRacer is offline
Jason
Helicoil,
Very nice build!
I agree with Mike Lewis on the valley screen though.
Jason Gore
AKA DragRacer
Naturally Aspriated 450 SBC - 915 HP / 714 lb-ft
3555 lbs
1.40 - 60', 6.18 @ 116.7 MPH - 1/8th
  #12
Old Feb 1st, 09, 2:58 AM
aukai aukai is online now
Mike
Makes my Champagne (Thunder bird) budget seem a little reserved.
YOU KNOW YOU HAVE THE POWER..... AND IF YOU USE THAT POWER BAD THINGS ARE GOING TO HAPPEN!!
Mike Lewis street 572
http://www.lewisracingengines.com/
Holley HP EFI
Marcella Manifolds
Heads by Darin Morgan
Cam by UDHarold
.456 X 1.8/1.7
R2C Filters
www.r2cperformance.com
Ultra Carbon
www.ultra-carbon.com/
GF-5R,
http://trzmotorsports.com/wp2/
TRZ FAB 9" 4.56 REM, Cryo Treated
4000 lb street car
My Showroom
  #13
Old Feb 1st, 09, 8:04 AM
GRN69CHV GRN69CHV is offline
Team Member
Joe
Looks like the exhaust side of those Dart 360's have been worked over a lot. Compared to the exhaust side of my ProOne 310's, those exhaust ports are huge. Thanks for posting/sharing detailed pics. Kind of funny. You are building out 15 CI more displacement for a lite wt car to run in the 9's, I am building a very similiar yet detuned version that I hope to keep down around 625-650HP when done.
Status: Car-Less
http://www.chevelles.com/showroom/sh...2/limit/recent
  #14
Old Feb 1st, 09, 9:46 AM
lemonice lemonice is offline
Talking Re: 555" BBC 'pump gas' build
hello, what intake is that.? looks like the one that may have (rheer-morrison) cast into it.also are you using the felpro blue gaskets as in the picture or a multi-layer gasket. and last question, did you buy a new dart block, and have to machine on it?
  #15
Old Feb 1st, 09, 10:27 AM
Chevelle505cid Chevelle505cid is offline
Chris
Sweet Jesus! It's like someone read my mind and nearly assembled my dream engine! Great build! Great Pics! Keep up the good work. Some day when I grow up ( probably after the kids exit college over a decade from now) I would love to do a similar build. I think 9's on grunt and 8's on the hose are going to be pretty darn easy. Sweet, Sweet build!
http://www.cardomain.com/ride/2923126/11970 Chevelle SS replica ( Its what I can afford )
Shooting for 10's on pump gas. Most likely will run 11's
Dont lift till you see God.
Chevelle Tech > General Tech Area > Performance      Current Topic: 555" BBC 'pump gas' build
Location
*REQUIRED*
Insurance
First Name
Human Verification
