66 or 67 Dash Photos - Chevelle Tech
Auto Insurance
Interiors Upholstery and soft trim
Old Jan 26th, 09, 9:55 PM
1967 Bodyoff 1967 Bodyoff is offline
Jason
Default 66 or 67 Dash Photos
I am looking for some photos of custom 66 or 67 dashes that include gauges, or photos of where you guys are mounting gauge pods. I am starting to restore my dash and need some ideas since I have the base dash, but would like oil, temp, and volt gauges.
Old Jan 26th, 09, 10:26 PM
DaleM DaleM is offline
Gold Founding Member
Dale
Default Re: 66 or 67 Dash Photos
Here's my old 67 with Dakota Digital hot rod gauges w/4-speed and no A/C.
The 'second' version moved the in-dash radio to the console to make room for the center A/C vents. Also swapped the 4-speed for a 700R4 and B&M Quicksilver shifter plus I added Autometer mechanical water temp and mechanical oil pressure gauges. A few more interior photos at http://dalesplace.com/others/67chevelle/interior.htm
My current 67 El Camino is a bit more conventional with an Autometer 3-gauge pod (water/vacuum/oil) centered below the dash and a voltmeter in a single gauge black cup to the far left. A little more spartan since its not driven much and pretty much relegated to hauling duties.
NECOA #41 - 67 El Camino (sold) ~ TC Gold #92
* I only report what I read. If they're wrong, I'm wrong.
* ChevelleStuff - Decoding info for 64-72
* 1966/1967 Chevelle Reference CD
* L78~L79~LS3~LS5~LS6~YF3~SS396~SS~El Camino & Laguna S3 Registries
* ChevelleStuff Mailing List
Old Jan 26th, 09, 10:29 PM
Dale
If you're 'restoring' your dash you might consider a set of OE-style gauges to fit the original gauge cluster like these from http://shiftworks.com for $205. A voltmeter is available in place of the ammeter.
Old Jan 27th, 09, 12:20 AM
cobaltchev67 cobaltchev67 is offline
Mike
I'm doing the Haneline dash pieces with 6 gauges(from Nordskog), unfortunately they will ship this week, were supposed to ship last week....will post when I get it done in the next few weeks.
1967 Chevelle Custom
SBC 383
Gear Vendors Overdrive
Jerico DR-4
S60, True Trac, 3.54 gears
http://s348.photobucket.com/albums/q...67%20Chevelle/
Old Jan 27th, 09, 7:14 AM
cuisinartvette cuisinartvette is offline
Sheepster. BAH!
Did the same thing..numerous people Ive talked to say the retro gauges are very accurate and reliable. Still like seeing the analogs sometimes but everyones got em. Easy to switch out of you get tired of them in fact dont even have to remove the dash;two screws and youre done.
This post is a duplicate of a post that you have posted in the last five minutes.
  #6
Old Jan 27th, 09, 11:17 AM
Dale
One thing I'd look for if you're doing the repro factory-style gauges is try to find a 66 cluster to start with. The high beam indicator was moved to the cluster face in 67. The gauge option from the factory in 67 used the same face as the 66. That is, no high beam indicator and the other two warning lamp pods were different as well. Naturally one doesn't have to be 'correct' here but adding the gauges to a non-guage 67 cluster will stand out.
  #7
Old Jan 27th, 09, 12:03 PM
eabride eabride is offline
Eric
I have a Shiftworks gauge conversion kit that I would like to sell. PM me if anyone is interested.
  #8
Old Mar 5th, 11, 11:56 PM
HMartin HMartin is offline
Team Member
Dale I am adding the gauges to a non 67 gauge cluster and saw that Hinshaws sells the brake and bright light lense. Would thesr work with the four hole slots off of my 67, could the space between be opened up or should I look for another cluster? Getting ready to do the AAW rewire on the car.
  #9
Old Mar 6th, 11, 12:13 AM
Dale
I think the new lenses will work. The standard 'funnel' (for lack of a better term) is split into two channels for each bulb but looking at an old one I have I don't see why the center divider couldn't be cut out with something as simple as side cutters and maybe a Dremel-type tool to clean it up a bit.
  #10
Old Mar 6th, 11, 12:21 AM
keithb keithb is online now
Keith
Send a message via AIM to keithb
That is what I did for mine I used a hack saw blade and cut out the divider. When I bought the lense from James Hinshaws that is how he told me to do it
1966 Chevelle SS 396/360 M21 3:73 posi. silver/blue buckets
1994 Corvette coupe LT1 auto
Maryland Chevelle Club #682
  #11
Old Mar 6th, 11, 9:34 AM
Bryan59EC Bryan59EC is online now
Bryan
I used the 67 speedo (bright light)
and the standard instrument panel when I put the 'Shiftworks' kit in.
Also using AAW classic update.
wired the car to use the 'BRAKE' 'GEN' 'HOT' and "OIL' lamps as well the gages.
only had to add one wire to the cluster----hot----and I get the brake indicator as well.
did require a couple of modifications to the wire harness tho.
Bryan's toyz
59 ElCamino 454/TKO 5spd--(daddy)
66 ElCamino 3oh7/TKO 5spd (mousey) Almost done On the street now!!!
65 Ranchero v8/4-spd, that my uncle bought new
  #12
Old Mar 6th, 11, 9:15 PM
john 67 john 67 is offline
Haneline guage panel,
  #13
Old Feb 22nd, 12, 9:54 PM
david_396 david_396 is offline
David
Bringing an old post to the top. Found a complete factory 66 gauge cluster, speedo and gauges. Was wondering if the 66 gauges are the same for a 67. Want to use the 66 gauges in my cluster. My cluster also has the mechanical speed warning indicator on dash face.
55 210 Chevrolet New project
64 El Camino (sold to finance new project)
67 SS Chevelle '396
69 Sanger Flat Bottom boat
77 El Camino parked daily driver
78 Z/28 Camaro, High School Car Class of 80 350'
80 Spectra 21' Mini Day cruiser Blown 454
88 IROC Camaro (sold to finance new project)
1994 fac2 dr Blazer 4x4
02 F-250 7.3L Diesel 4" lift
  #14
Old Feb 22nd, 12, 10:52 PM
Chris R Chris R is offline
David, if you scroll up to Dales post #6. That should help answer your question. If your asking if 66 gauges will fit a 67 or vise versa. I do believe they will swap. Although ill admit I havent personally seen both year gauge clusters side by side to see if they would match. Ill bet Dale can answer that one too.
Chris.
When the Boogeyman goes to bed, he checks the closet for Chuck Norris.
If it aint broke, just give me a minute.
  #15
Old Feb 22nd, 12, 11:12 PM
nutt nutt is offline
Frank
This is kinda what im looking to do. How many places out there have this set-up? Which one is better? I remember reading about it but dont remember where.
Currently doing a frame-off on a 66 SS 7...make that 8 years and counting!!!
ZZ502
Lunati cam, Pro-Sytems 1000HP carb
TKO600
Link to some early restoration
http://s293.photobucket.com/albums/mm52/nutt19/
Link here to the project section newest pictures and updates.
http://www.chevelles.com/forums/showthread.php?t=366790
You may not post new threads
You may not post replies
