Comp Cams 280H Magnum and Vortec - Chevelle Tech
Auto Insurance
Old Jan 22nd, 09, 11:00 PM
david_396 david_396 is offline
David
Default Comp Cams 280H Magnum and Vortec
This is the max lift for stock vortecs correct??
cam specs
Magnum 280H Hydraulic Flat Tappet Camshaft Only
Lift: .480''
Duration: 280°
RPM Range: 2000-6000
Have this cam in motor already. Have a set of stock vortecs with about 50k miles on them sitting on shelf. Thinking outloud about putting these on the Camaro. Have vortec intake already also. Didn't want to spend big $$'s on modifying heads if I didn't need to. Flat Top TRW pistons. Current heads are 64cc 2.02 intake 1.94' exhaust.
Thanxs david
55 210 Chevrolet New project
64 El Camino (sold to finance new project)
67 SS Chevelle '396
69 Sanger Flat Bottom boat
77 El Camino parked daily driver
78 Z/28 Camaro, High School Car Class of 80 350'
80 Spectra 21' Mini Day cruiser Blown 454
88 IROC Camaro (sold to finance new project)
1994 fac2 dr Blazer 4x4
02 F-250 7.3L Diesel 4" lift
Old Jan 22nd, 09, 11:50 PM
d1_bradley d1_bradley is offline
Dave
Default Re: Comp Cams 280H Magnum and Vortec
Which Vortec head casting number? Here's an article on the iron heads.
http://www.carcraft.com/techarticles...ade/index.html
Dave Bradley
Old Jan 23rd, 09, 12:43 AM
David
Damn, I thought the lift limit was .450". Spring change I could do myself. Buddy can do the valve job. So:
Valvespring, beehive
Comp Cams 26918 $186
-Retainer, steel
Comp Cams 774 $59
-Keepers, 7-degree
Comp Cams 648-16 $28
Still half the price of brand new stock vortecs.
Vortec cylinder head
GMPP 12558060 $489/pair*
I was hoping a gasket set was all I was lacking!#%
-Vortec head, modified
Scoggin-Dickey SD8060A $639/pair*
67 SS Chevelle '396
Old Jan 23rd, 09, 12:44 AM
David
Gotta go look in the shop. There still bolted to the complete motor.
67 SS Chevelle '396
Old Jan 23rd, 09, 1:15 AM
sschevellefan sschevellefan is offline
Anthony
The vortecs have a talled guide so you`ll most likley have to have it machined down. you can buy the tools from summit and do it yourself or you can buy cranes springs that is for this application or you can do what is refered to as the "ghetto grind" on some sites on the bottom of the retainers.
  #6
Old Jan 23rd, 09, 1:06 PM
Lilracr Lilracr is offline
Bobby
Don't forget you need a Vortec intake to fit the heads, the center bolt valve covers and self aligning rockers.
machine the valve guide down for clearance, and either use your existing springs and retainers or buy the beehive springs and retainers.
Will be a good investment for power over a stock head.
-Bobby-
  #7
Old Jan 23rd, 09, 4:51 PM
stock48 stock48 is offline
Jarrett
You can also use +.050'' valve locks.
~1972 Nova street car, Factory shortblock 6.0L LS, 76mm turbo, JFR218 Cam, calTrac/275's. 8.22/164.70 @3400 lbs. Drag Week 2014 SSRPA Winner.
~2003 GMC 4x4 Factory shortblock 6.0L, 76mm turbo, JFR"Triple"12 cam, daily driver 9.73@139 mph @4850 lbs
Custom LS cams, Yank torque converters, Racetec pistons and more..
  #8
Old Jan 23rd, 09, 5:02 PM
onovakind67 onovakind67 is offline
That's a really big exhaust valve. Most heads don't have one much larger than 1.6".
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
  #9
Old Jan 23rd, 09, 6:15 PM
DOUG G DOUG G is offline
Team Camaro
The 280H CompCam is really .486 lift with 1.5 rockers.
Great little cam IMO... got it into the low 12's in a 406 with 10:1 compression. Here's how it sounded -> http://s10.photobucket.com/albums/a1...t=DSCF0001.flv
68 Camaro~406ci
RedЯum <-Pics
11.304 @ 119.05 ~1320' NEW (3/19/11)
http://youtu.be/48OfD_C4JWU <-11.36 Vid.
Some days all you can do is just smile
Chevelle Tech > General Tech Area > Performance      Current Topic: Comp Cams 280H Magnum and Vortec
Human Verification
