Harmonic Balancer Slipped? - Chevelle Tech
Auto Insurance
Old Jan 12th, 09, 10:39 PM
350chev 350chev is offline
Alex
Default Harmonic Balancer Slipped?
Well after concluding that my poor timing was due to a slipped harmonic balancer I was curious if there was a way to fix it and set it back up to normal. To install the balancer I set it on its tooth, put a block of wood in front of it, and started pounding on it with a hammer to get it back in... Apparently that isnt a good idea. So all in all how should I go about resetting it so I can have accurate timing readings?
1971 Chevelle 350, 260hp, 200r4, 3.36 8.2.
Old Jan 12th, 09, 10:48 PM
d1_bradley d1_bradley is offline
Dave
Default Re: Harmonic Balancer Slipped?
Buy, rent or borrow a balancer installation tool. (one source) Use to install your NEW balancer, the one you pounded on is DONE.
http://store.summitracing.com/egnsea...5&autoview=sku
Dave Bradley
Old Jan 12th, 09, 10:59 PM
Alex
I bought some sort of kit from auto zone that I used to remove the dampener. Would I have been able to use it to put it back on? Yes I have a crank bolt.
That sucks what would a balancer go for? Also why did it ruin it? It went on straight...
Old Jan 12th, 09, 11:04 PM
Stalkingbear Stalkingbear is offline
Mike
You can buy a new dampener from Chevrolet fairly inexpensively.... they will sell you the one that goes with the engine so it would be the right part. If the outer ring moves, it needs to be replaced.... it will just move again even if you had the right equipment to 'correct' the movement. Hammering the dampener on is the 'NOT RECOMMENDED' way of installing it. The removal tool removes... an installing tool does the other part.
Old Jan 12th, 09, 11:08 PM
Alex
Ah I see. Yeah that makes sense. I was just wondering if you could convert the removal parts into a putting it back on parts.
  #6
Old Jan 12th, 09, 11:11 PM
figbash figbash is offline
Tom
If you've hammered on it, it's trash, throw it away and buy a new one. Install the new one with the proper tool, which is basically a piece of threaded rod, a washer and a nut. They need to be installed and removed by pushing or pulling on the hub, not on the outer ring.
Tom
1972 CHEVELLE SS
  #7
Old Jan 12th, 09, 11:20 PM
Alex
Tom
Alright I understand the concept. I will get a new balancer asap
  #8
Old Jan 12th, 09, 11:23 PM
davewho1 davewho1 is offline
Moderator
Send a message via Yahoo to davewho1
There are places that rebuild them, if you want to keep your original - damper dudes; damper doctor, etc. Google 'em.
Dave
1966 Fremont 11A, SS396/L35 coupe - 1 of 66,843
MM/763; A01; A39; A51; D55; M35; N40; U14; U63
http://www.cardomain.com/ride/307290...rolet-chevelle
  #9
Old Jan 13th, 09, 8:04 AM
PCB67SS PCB67SS is offline
Bill
Alex what lead you to believe the damper has slipped? Are you sure that when you installed the cam that you had the timing marks lined up correctly.....While not optimal or even remotely recommended I have seen dampers reinstalled with a block of wood and they survived.
My 67
  #10
Old Jan 13th, 09, 3:05 PM
Alex
I had it lined up as close as it was going to line up. It was perfect. One tooth more or less made it way off. Heres a picture, its hard to tell but you can see its even.
Also, I was reading 55-60* at 2000 rpm with glowing headers. As I advanced the timing more the headers went away, the car ran better, but still had some backfire. Right now the canister is touching the intake so I need to move it a tooth or move the plugs over and retard for more room.
I reinstalled it with a block of wood too. I just dont see how anything could have moved if it was on the tooth off the crankshaft
  #11
Old Jan 13th, 09, 3:43 PM
Georgia69 Georgia69 is offline
Mike
OK, I'm confused, you've been discussing a balancer and post a photo of the timing chain and gears? Anyway, I'm not convinced your balancer is your problem. I've installed several balancers with hammer and wood back in the old days when there was no money for special tools. Never had a problem with any of them. Re-install the balancer, find true TDC with the #1 piston, and check the alignment of the balancer with your timing tab.
  #12
Old Jan 13th, 09, 5:29 PM
Bill
In your photo you do realize your on number 6 compression and not number 1 correct?....To be on number one compression the dot on your upper pulley will be at 12 o'clock with the crank being the same as your photo 12 o'clock. In your other post you mention a oil leak....Now I could see how installing the damper with a block of wood could lead to a rear main leak. As mentioned previously its not the best method or recommended but I have personally done it myself in my youth......Back then either things were a whole lot simpler or I had that magic horseshoe up my A$$.
My 67
  #13
Old Jan 13th, 09, 6:41 PM
Alex
No that is the number one tdc... I wouldnt think it would start at all let alone run for 20 minutes with minor problems.
I ran it today at idle and it ran alright, backed it out of the garage and put it back in. No real problems. Did sound strange, not as loud as it did before and didnt have a lopey idle at all unlike the SMALLER cam that was in it before. Anyway its become a annoying timing issue. I noticed that I had about an inch left before I would rub the intake and I went ahead and started advancing it. After some movement the motor stalled out and died. I tried to start it up but the starter was hmmm lagging and really slow even though the battery was fine. It was also shooting up gas vapor out of the carb. I set back the timing a little bit and it started up but smoked out the tail pipes a bit... At least now after the cam break in I can idle it...
  #14
Old Jan 13th, 09, 7:24 PM
Bill
http://www.chevelles.com/forums/show...ing+chain+dots
My 67
  #15
Old Jan 13th, 09, 8:27 PM
Alex
Alright I read that and my dot does align with the dot on the crankshaft. I didnt use the triangle and it would be in that position otherwise...
Chevelle Tech > Mechanical > Engine      Current Topic: Harmonic Balancer Slipped?
Location
*REQUIRED*
Insurance
First Name
Human Verification
