Chevelle wiring diagrams - Chevelle Tech
Auto Insurance
NW Northwest Region
Old Jan 12th, 09, 4:09 AM
cobaltchev67 cobaltchev67 is offline
Mike
Default Chevelle wiring diagrams
I brought up to Greg(TOG) that I bought a full color and easy to read wiring schematic years ago, and he was curious where I bought it. The one I use is 8 1/2" x 11", utilizes both sides for front and rear wiring, fits nicely in one of my assembly/service manuals, is laminated, and is one of the best reference tools I own. I highly recommend it if you do anything with your car's wiring or have any sort of problem with the wiring or lights. This has saved me from many headaches looking at and following the little black lines and lettering in the service manual when adding/changing wiring on my car, and I'm an electrician.
Ok, That's my PSA for today
http://www.classiccarwiring.com/
1967 Chevelle Custom
SBC 383
Gear Vendors Overdrive
Jerico DR-4
S60, True Trac, 3.54 gears
http://s348.photobucket.com/albums/q...67%20Chevelle/
Old Jan 12th, 09, 8:25 AM
66 Buick Special 66 Buick Special is offline
Greg
Default Re: Chevelle wiring diagrams
When I bought my car someone had installed an HEI ignition....kinda.
Power was coming from multiple sources and the only way to turn the motor off was to flip a switch under the dash.... the key was only used to start it and would not shut off the car.
Through this site someone hooked me up with a printable version of a '66 diagram and a elsewhere online I found a diagram for a '74 Chevy ( I forget which model) so I could see how the HEI was supposed to be wired.
I've refered back to it a few times.
It's only black & white but the wiring color is labeled.
The one you linked is much easier to read.
"the Special" SBC 355/TH350/12 bolt 3.90 posi
Best motor pass - 12.58 @ 107mph
Best nitrous pass (125shot) - 11.72 @ 115mph
http://www.cardomain.com/ride/2345518/1
Old Jan 12th, 09, 11:42 AM
webfoot webfoot is offline
Team Member
Jeremy
I have a factory wiring diagram manual - needless to say, it sucks.
Jeremy
70 Chevelle
383, AFR heads, voodoo hyd roller.
Best time 8.09 @ 88.49 MPH (1/8 mi.)
68 GTO 'vert factory 4-sp, rally gauges, hidden headlights
Old Jan 12th, 09, 12:25 PM
Juhosaphat Juhosaphat is offline
Chad
The poster would be an awesome reference point and you wouldn't have to hide it anyway. Just put it up on the wall in the garage I may be buying one of those in the near future.
2009 Best of 13.16 @ 101.54 w/.039 r/t and 1.84 60'
Old Jan 12th, 09, 2:05 PM
Brettd85 Brettd85 is offline
Brett
Reminds me I probably need to buy an assembly manual for the 66. I have to reinstall the heater controls and all the ducting, sounds like quite a chore. ugh.
1968 Camino Custom
468, TKO600, 3.73:1
Pic of Car: http://i52.photobucket.com/albums/g3...5/DSCN0827.jpg
Pic of 468:http://i52.photobucket.com/albums/g3...5/IMG_0233.jpg
1966 Triple Black Chevelle
327, TKO600, EFI, 4.11:1
Pic of Car: http://i52.photobucket.com/albums/g3...5/DSCN1706.jpg
  #6
Old Jan 12th, 09, 6:43 PM
Kevin R Kevin R is offline
I have a few orinal assembly manuals. I will let you check them out if you want Brett.
  #7
Old Jan 13th, 09, 7:47 PM
anychevy anychevy is offline
Team Member
Dave
Send a message via Skype™ to anychevy
This 69 Diagram should give you the basic layout and colors for 64 to 72
http://www.chevelles.com/showroom/sh...6/limit/recent
I'll leave it there for a while
Specific years can be found here, but only in B&W
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Cheers
Chevelle Tech > Team Chevelle > Team Chevelle Cruiz-ins > NW      Current Topic: Chevelle wiring diagrams
Human Verification
