how to mini-tub 70 chevelle - Chevelle Tech
Auto Insurance
Pro Touring Todays performance with classic style
Old Dec 22nd, 08, 4:22 PM
tea0341 tea0341 is offline
todd
Default how to mini-tub 70 chevelle
1970 chevelle 12 bolt posi, 350 turbo transmission 3 speed, 383 8-71 blower. any help would be great.
Old Dec 22nd, 08, 5:24 PM
1966_L78 1966_L78 is offline
Tony
Default Re: how to mini-tub 70 chevelle
A "mini tub" probably won't be too much help, as the frame rails will also need to be narrowed to add any noticible room...
But, a "mini-tub" should be relatively straight forward... Cut the inner wheel house from the outer wheel house, notch the floor and move the inner wheel house inward, then add a filler strip...
Once you go RAT, you never go back...
TC #1366
'70 Chevelle 427 Stroker
'66 Convertible Sold
Dual Quad 396 & Conv Int
'66 SS L78
Old Dec 22nd, 08, 5:33 PM
Racing Racing is offline
Dan
Here is a tech article from Malibu Racing on frame notching. It's a different year but the basic technique is the same.
Dan
Dan's 70 Chevelle
Spencer's 72 Chevelle
Old Dec 23rd, 08, 3:45 PM
MarkM MarkM is offline
I'm finishing up a '66 now, 3" per side. It's very time consuming. The frame work went quick, the body work took about 20 times longer.
Old Dec 23rd, 08, 4:43 PM
crimsonmajick crimsonmajick is offline
Shane
Do you have any pics of the process for your 66? I have a 67 I am planning on doing this to probably next month. I was hoping for 2" per side but 3" sounds better. I am trying to get all the information I can before firing up the welder!
Thanks!
67 Chevelle (in disrepair at the moment)
  #6
Old Dec 23rd, 08, 5:40 PM
I can email you a few pics. Is your email in your profile still good?
I needed 3" to fit the tire I'm going to run. It's really no harder to do 3" then 2", anymore then 3' and you'd have more issues.
  #7
Old Jan 3rd, 09, 1:54 AM
snake8700 snake8700 is offline
kevin
i think i could use those pics also if u wouldnt mind sending them to me too. my email is snake8700@aol.com
thanks,
kevin
  #8
Old Jan 3rd, 09, 2:37 AM
JpRngr JpRngr is offline
Corey
thanks,
kevin
Me, too, please! JpRngr@msn.com
  #9
Old Jan 3rd, 09, 7:49 AM
Pics sent to you two.
  #10
Old Jan 3rd, 09, 3:38 PM
jonfarrugia jonfarrugia is offline
John
Send a message via MSN to jonfarrugia
Here are a few pics of the mini tub I just completed on my 67. I was about to get 1.75" from both sides. Any more and there will be almost no support.
http://s200.photobucket.com/albums/a...er69/?start=40
  #11
Old Jan 4th, 09, 1:37 AM
Corey
http://s200.photobucket.com/albums/aa205/buttslapper69/?start=40
WOW! Where to begin? Twin turbo Viper V10? Wow!
Are you planning on sectioning your body to sit down over the frame? Your interior frame seems to stick down below the frame rails about 6". I would think it wouldn't clear the ground by much otherwise.
Thanks! How difficult was it to get everything straight before welding it back together? That's what I'm most nervous about.
Corey
  #12
Old Jan 4th, 09, 3:25 AM
D70 D70 is offline
TT v10 Chevelle, Wow...
1970 Chevelle! In pieces, since 04.
Project and Photo How-to's:
- Alumitech Radiator unboxing:
http://www.chevelles.com/forums/showthread.php?t=252259
- Full frameup tear down and rebuild:
http://www.chevelles.com/forums/showthread.php?t=99112
  #13
Old Aug 20th, 13, 7:58 AM
slayer396ss slayer396ss is offline
Travis
I am going to notch or z my frame to stuff some bigger tires in the back of my 70. Does anyone have any pictures of the inner fenders after they are cut and spaced out? I don't want to lose the back seat and it is my understanding that if i move the inner fenders over a couple of inches or square everything off, the back seat will not mount anymore. Is that correct?
  #14
Old Aug 26th, 13, 11:00 AM
'540 Chevell '540 Chevell is offline
These folks have a full kit to do a mini tub on our cars. I will like
to know if anyone has used their kit?
http://abcperformance.net/mini%20tub%20kit.html
  #15
Old Aug 29th, 13, 12:08 PM
Bikerman9967 Bikerman9967 is offline
Phil
ive looked into using theirs but you need to buy a bunch of add ons to get it to work.
first you need coil overs, if you want to use the stock spring hats you need to move them inboard and move them on your axle
if you go the coil over route you have to spend another 500 bucks
then, if if you still wanna go through with it you need to figure out what to do with the rear sway bar. the stock style sway bar will hit the new coil over mounts that are welded to the axle. so you will need to dump that and go with something else , which they also sell.
its really a 2k job if you buy everything instead of making it yourself
Chevelle Tech > Specialty > Pro Touring      Current Topic: how to mini-tub 70 chevelle
Location
*REQUIRED*
Insurance
First Name
Human Verification
