Will 5X120 Fit 5X120.65 bolt Pattern? - Chevelle Tech
Auto Insurance
Wheels & Tires What fits what?
Old Dec 19th, 08, 11:22 PM
shonuff shonuff is offline
Banned
Default Will 5X120 Fit 5X120.65 bolt Pattern?
The guys at several rim shops have said yes. I even called Giovanna and the Service Tech said it would fit. Anybody have any opinions or maybe have tried this before.....I am interested in your views and knowledge. Thanks
I want to put these on my 69 20x8.5 front 20x10 rear.
Old Dec 20th, 08, 12:01 AM
69SS3964Spd 69SS3964Spd is offline
Default Re: Will 5X120 Fit 5X120.65 bolt Pattern?
The difference is .65 of a millimeter, which is a hair or 2! They often call the 114.3(4.5") and the 115 the same which is of course .70 mm difference. So yes, they should work just fine if your offset/backspacing is correct!
1969 Chevelle SS 396 4spd
1972 Chevelle SS 402 4spd #'s Matching!(SOLD 9-9-11!!)
1970 Monte Carlo SS 454
1969 Camaro RS 4spd
1970 442 4 speed
1970 F-85 W-31 4spd
1971 Monte owned since '86
Old Dec 20th, 08, 12:15 AM
Banned
have you heard of it causing damge to the studs long term or any other issues like vibration, etc......
Old Dec 20th, 08, 6:29 AM
GRN69CHV GRN69CHV is offline
Team Member
Joe
I'll let you know later today. I have a set of 20x8.5 w/ 5" BS and 20x9.5 w/ 6" BS off a BMW (5x120) here that my son brought home. DIfference on the bolt pattern is .026"
Status: Car-Less
http://www.chevelles.com/showroom/sh...2/limit/recent
Old Dec 20th, 08, 11:48 AM
You have also got to realize that that .65 mm difference is not at every stud, it is divided between all 5 studs! That is .13 mm difference per stud which is less than a human hair! So basically there is no difference. If you contact the places that makes these wheels their manufacturing tolerances are probably more than +or-.13 mm!
1969 Camaro RS 4spd
1970 442 4 speed
1970 F-85 W-31 4spd
  #6
Old Dec 20th, 08, 1:22 PM
Team Member
Joe
Just tried it. 5 x 120 bolt pattern fits perfect. Just have to watch the backspace. Wheels I have here are 20x 8.5 w/ 5" BS and 20 x 9.5 w/ 6" BS. These are sucked in too far. Ideally, the 9.5" rim should be 5.25" BS, 8.5" would be good at 4.75" BS. JMHO, '69's seem to work best with "0" offset.
Status: Car-Less
  #7
Old Dec 20th, 08, 3:26 PM
HMartin HMartin is offline
Team Member
Glad to know this! I have had my eye on a set of M Parallel BMW wheels. Do a search, cool wheel and resonably priced for an 18 inch rim.
  #8
Old Dec 20th, 08, 3:38 PM
Dave Birdwell Dave Birdwell is offline
Chevelle Doctor
Send a message via ICQ to Dave Birdwell Send a message via Yahoo to Dave Birdwell
Not true, bolt patterns are measured across two studs, not on a radaii.
Owner of Daves' Restoration, The cure for the common hoopty.
70 Chevelle L78/M21
00 Chevy Silverado 1500 4x4
06 Equinox
Wanted-1976 Nova SS.
  #9
Old Dec 20th, 08, 4:32 PM
animal69 animal69 is offline
Chris
You've got some thick hair! Most hair is .003-.005" thick. A mm .03937" so .65 of that is .026" and half of that is .013".
I never make mistakes, but on occasion I present myself with an opportunity to get very creative.
  #10
Old Dec 20th, 08, 9:51 PM
WQW! Not thinking right lately I guess, preoccupied with health issues! It woulg be half as much per stud. So .65 mm difference would be .325 mm difference per stud!
1969 Camaro RS 4spd
1970 442 4 speed
1970 F-85 W-31 4spd
  #11
Old Dec 20th, 08, 9:53 PM
Refer to above post!
1969 Camaro RS 4spd
1970 442 4 speed
1970 F-85 W-31 4spd
  #12
Old Dec 20th, 08, 10:05 PM
BillsCamino BillsCamino is offline
Gold Founding Member
"Wild Bill"
Send a message via AIM to BillsCamino
Actually, the bolt pattern of any wheel is a circle...and measured as a diameter.
Which obviously is simple to measure on an even number of lugs...more difficult on the odd numbered ones.
1972 GMC Sprint
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
  #13
Old Dec 20th, 08, 10:50 PM
seabees72ss seabees72ss is offline
Tim
Had a 2005 GTO with the 5x120. I bought a set of Draglites with the 5x 4.5/4.75 and they fit great, no problems at all. I still have the stock GTO 18's, may try them on the 72just to see how they look.
www.performancemachinetomah.com
ACES # 08627
Team # 4935
Senior Chief U.S. Navy Seabees, CAN DO!
Proud to be serving the greatest place on earth, good old USA!
  #14
Old Dec 21st, 08, 6:30 AM
Team Member
Joe
Only input I can give was trying a wheel on the car. Bolted a wheel up with two nuts installed (on two studs to locate it at the 4.75" bolt pattern) to center it and checked the alignment on all the studs - all were dead center (visually). FYI, this is on a rear axle that just had new studs installed about 1 month ago.
Status: Car-Less
  #15
Old Dec 27th, 08, 11:34 AM
ed1le ed1le is offline
Ed
Great thread...I've seen some slick wheels, including bmw, on ebay with the 5 x 120 bolt pattern and was wondering if there was much of a difference. Opens up the wheel options some more!
70 Skylark Convertible Pro-Touring project - LT1 w/ Lloyd Elliott cam, 11.1, 58mm TB, custom harness & tune, T56, 12-bolt w/ 4.10s
87 Iroc, ZZ4, ProTopline 220cc, cc305 w/ 1.6's, Miniram, Paxton SN2000, Raptor 700R4 w/ Vigilante 2600 stall, 3.73's, Hotchkis suspension w/ Koni adjustables, C5 brakes, 17" Centerlines
Chevelle Tech > Mechanical > Wheels & Tires      Current Topic: Will 5X120 Fit 5X120.65 bolt Pattern?
Location
*REQUIRED*
Insurance
First Name
Human Verification
