| Chevelle Tech Current Topic: Stripped Distributor gear | ||
| Register | Photo Ads | FAQ | User List | Social Groups | Calendar | Chat | Search | Today's Posts | Mark Forums Read | Insurance | Auto Loans | Auto Escrow |
| Troubleshooting Diagnosing problems done here. |
I have a 454 Hi Perf block with a 4.25 crank. My distributor gear on my accel distributor wore down over time, and then crushed on the cam gear under hard acceleration at 500 miles. I am running a high volume oil pump at about 70-80 psi cold. The engine was dynoed at 570 HP at the flywheel. Any ideas on why this happened to a non adjustable installation. I know that with a billet cam you should use a bronze gear, but this Crower cam was not a billet unit. What now, tear down, clean out, machine as neccesary and re-build? Any idea why this happened.
| Sponsored Links | ||
Advertisement | ||
#2
I would tear the egine down as there is now metal EVERYWHERE. MAKE SURE it's clean then reassmble
Ditto's to Matt. You'd better clean'er out!
Seems like we are hearing more and more problems with distributor gears. I'm thinking that the HV oil pump is the culprit. That's putting a lot of stress on the gear. I'm starting to get the notion that if you ever have a bronze gear, you might want to use a stock oil pump. Most will agree the stock pump is up to the task, even on a built engine. Sorry for your troubles, Steve. ------------------ -Mark "Some of us got it and some of us ain't." -Deputy Sheriff Barney Fife TC# 717 ACES #1641 1967 Chevelle SS396/375 1967 RailVelle 1964 Chevelle 283/195 1975 Corvette 396/425 "Wow, that's a mighty strong 350!" Rat Garage |
| Sponsored Links | |
Advertisement | |
| Display Modes | |
