Question about the Holley 3310 Carb? - Chevelle Tech
Auto Insurance
2008 General Tech Forum from 2008
Replies ONLY, no new topics.
Old Nov 24th, 08, 12:29 PM
350 LT-1 350 LT-1 is offline
Mike
Default Question about the Holley 3310 Carb?
I am interested in purchasing a Holley 3310C carb (new or used). I have noticed there are more than a few versions of the carb. From 3310-1 up to 3310-11. Can anyone tell me the differences between one version and the next? If I were to buy a used one which version is the best to have and what are the risks?
Quick reply to this message
Old Nov 24th, 08, 12:40 PM
onovakind67 onovakind67 is offline
Default Re: Question about the Holley 3310 Carb?
The R-3310-1AAS is a model 4160 carb. The R-3310-2AAS is a model 4150 carb. In my 1976 catalog the 3310-1 and -2 are both listed at 780 cfm, while in the 1989 catalog the 3310-2 is listed at 750 cfm, as well as the 3310-3.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
Old Nov 24th, 08, 1:25 PM
Jason Snyder Jason Snyder is offline
the 3310 and 3310-1 are a 780 cfm carb ,these have dropleg boosters ! the others -2 and up have straight leg boosters . I PERSONALLY prefer the drop legs ,they tend to respond a bit better and are generally easier to tune . i seem to always get a lean bog out of the straight boosters. if you are good with holleys then you cantgo wrong with the 3310,or -1 . Most of the older carbs have beat up baseplates ,so be careful when buying . also the 3310 and -1 have rear metering blocks (4150) the newer -2 and up have plates (4160) . so the old carbs take the cake hands down !
Old Nov 24th, 08, 8:52 PM
Mike
Are parts readily available for the earlier 3310 and 3310-1 carbs if needed?
Old Nov 24th, 08, 9:03 PM
mr 4 speed mr 4 speed is offline
yup..not a problem
  #6
Old Nov 24th, 08, 9:34 PM
kettbo kettbo is offline
George
I will make my 4150 3310-2 into a 4160 with rear metering block.
The problem with the 4150 series is that to change the rear jetting you must dig into the carb and change the plate....stock size is 75 (or there about). People with very healthy SBCs or nice street 454s like 84 or 86 secondary jetting.
Just educate yourself in Holleys before using the 'previously-owned' market.
Lots of people get into the carbs that should not be working on these things....
George Kettler
o 70 Elky 496 build continues #074 AL heads
$2000 low buck 454 is broken, ran well for a 3995# all-up wt.
1.631 11.727 113.37 91.47 midtrack 1.647 11.729 113.49 91.58 mph mid track
Bests 1.620 60 ft 91.60 best mph
o 68 Vette 427/M-20/3.36 23 year owner
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
  #7
Old Nov 25th, 08, 7:17 AM
4160 has the metering plate...4150 has a metering block..not the other way around
:yup: The swap meet carbs I have bought over the years had some strange combos of jetting and powervalves...I wouldn't even considering trying them...recently I found a 850 double pumper for a friend recently...had 68 primary jets,72 secondary,3.5 powervalve in the front and the rear metering block was on backwards! Carb was nice and clean,almost like it came out of the box..nice score for $75!! Bought a $30 rebuild kit and put the stock jets/powervalves back in it...works mint
  #8
Old Nov 25th, 08, 9:01 AM
69 Daytona Yellow 3 Speed 69 Daytona Yellow 3 Speed is offline
Tony
Send a message via AIM to 69 Daytona Yellow 3 Speed
Talking Re: Question about the Holley 3310 Carb?
Try here....http://stores.ebay.com/Holley-Performance
Tony
33 Years of ownership, thanks dad !
Im real, my car is real and i have a tag line i dont hide nothing.
My 1969 Mellow Daytona Yellow SS396, 3 Speed, Bench Seat, Original Paint "Survivor".
Picture of "Crying 96" Tears Chevelle
Another Pic of "96 Tears" Chevelle
Press 1 for English
Press 2 for Deportation
  #9
Old Nov 25th, 08, 11:58 AM
Mike
Thanks for the tip on the Holley website on Ebay. I'll keep tabs on what's up for auction.
  #10
Old Nov 25th, 08, 7:16 PM
68chevelle533 68chevelle533 is offline
Mike
Send a message via ICQ to 68chevelle533
The 3310 is a great street carb. Mine had a bog off idle that was solved by changing the accelator pump cam.
Mike
70 chevelle
420 sb combo - 10.93@120.76mph
405 sb combo - 11.87 @112.5
307 combo - 12.91@105.33
68 chevelle 533 almost there
  #11
Old Nov 25th, 08, 7:40 PM
Mike
What version do you have? Did you buy a new one?
  #12
Old Nov 26th, 08, 9:55 AM
fabio fabio is offline
the newer one doesn't open the secondaries all the way. They will only open about 85%.
  #13
Old Nov 26th, 08, 10:03 AM
Boldly procrastrinating
TerribleTom II
They will open the secs as far as is needed? Maybe the engine in question doesn't need any more? What type of engine is it?
Tom
  #14
Old Nov 26th, 08, 10:37 AM
what spring is in it? what size motor?
  #15
Old Nov 26th, 08, 1:13 PM
Mike
I have a 70 Chevelle with a factory 12 bolt, 410 gears, M-21 tranny and a 350 engine. I'm building the engine to a factory LT-1 specs and want to put the original 3310 carb on. I don't know if I should go with one of the first versions (used) or to just buy a new one. I'm all for whichever one works better. Any thoughts?
Chevelle Tech > Team Chevelle > Archives > 2008      Current Topic: Question about the Holley 3310 Carb?
Location
*REQUIRED*
Insurance
First Name
Human Verification
You may not post new threads
You may not post replies
