Mechanical (VS) Vacuum secondary Carb - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old Nov 9th, 08, 3:50 PM
shane918 shane918 is offline
Al
Default Mechanical (VS) Vacuum secondary Carb
I know this is a rookie question but Iím at the point now where I need to purchase a carb for my 350 being built. The guy building the engine said to get a 750 cfm carb. What are the advantages/disadvantages of (Mechanical (VS) Vacuum secondary) just trying to educate myself here.
Al
72 Chevelle SS Clone.
Engine, 350
12 Bolt Rear End
Eaton Posi 3.90 gears
Transmission 700R4 3000 stall
Work still in progress
Pics
Restoration website
http://72malibu.com
Old Nov 9th, 08, 9:45 PM
Lilracr Lilracr is offline
Bobby
Default Re: Mechanical (VS) Vacuum secondary Carb
If your looking for a driver that runs decent the VS carb is the way to go, now if you are looking for full performance and like all out power the mechanical secondaries are the way to go.
It can also depend on the build, you want to make sure there is enough motor there to handle the mechanical secondaries.
-Bobby-
Old Nov 9th, 08, 10:03 PM
ironhead ironhead is offline
No idea at what level your 350 is being built at,but a 750 cfm carb will support a mild 454 all day long.if your builder insists on 750 cfm,start off with the vac secondary.At least it will size itself to your engines needs.The double pump mechanical shows no mercy atop a small cube engine at low rpm.
George
8-71 blown 461 Rat on E-85
Old Nov 9th, 08, 10:16 PM
steve da wrench steve da wrench is offline
Steve
Assuming your engine is a mild "street" engine 350, a 600 cfm to 650 is good size for a street car. Vacuum secondaries are the way to go.
I usually recommend a 650 cfm edelbrock AVS carb. The secondaries are tunable as well with an air door (kind of like a Q-jet).
Mechanical secondaries are only wanted on a full on race car, IMO.
Old Nov 9th, 08, 11:30 PM
Al
I know the shop rates this engine at 410 hp and 428 lbs torque. I will get the specs in the morning. Thanks for the input.
Al
Engine, 350
12 Bolt Rear End
Pics
Restoration website
http://72malibu.com
  #6
Old Nov 10th, 08, 12:28 AM
figbash figbash is offline
Tom
If you plan on driving it on the street then vacuum secondaries are the way to go. Mechanical secondaries work best at wide open throttle such as on the track.
Tom
1972 CHEVELLE SS
  #7
Old Nov 10th, 08, 6:16 AM
MrBill66Malibu MrBill66Malibu is offline
Bill
Send a message via AIM to MrBill66Malibu
Don't make the same mistake I did, go with the DP if you are going to see any track time at all.
I thought my edelbrock carb would be fine, great for the street, sucks for the track!!! Now looking for a Holley 750 DP.
You can compensate the DP on the street more then at the track
Bill
385
4 speed M20
3:42 posi
1/8 mile 8.6 @ 84mph not too impressive LOL
http://s71.photobucket.com/albums/i1...libu/Chevelle/
  #8
Old Nov 10th, 08, 6:24 AM
troposcuba troposcuba is offline
Sean
dunno why everyone hates mechanical secondaries on the street. i have always driven them... 600dp on my 400hp 350 worked well. now 750HP (also dp) on my 500hp stroker. you just gotta be sure to jet it right and have the right pump cam and power valve. i would rather tune those items that trying to get the right spring and never really being sure if my secondaries are even opening all the way or not. can't really verify that on a vs carb except on a dyno. just my .02
Sean
'65SS, 385ci, AFR 195's, Comp XR 288HR, Forged bottom end, TKO600, 3.73/12 Bolt
Now in our new home in Tucson AZ
http://spotted.stripes.com/galleries....php?id=337573
"Aint no fun 'till somethin gets broke!"
  #9
Old Nov 10th, 08, 7:01 AM
mr 4 speed mr 4 speed is offline
Best carb for a performance 350 is a 750 Holley 3310 IMHO and experience...can't go wrong with the stuff the factory used (70-72 LT-1's came with 750-780 cfm vacuum secondary Holley)
If you want a mix of performance and economy,use a Qjet
  #10
Old Nov 10th, 08, 7:35 AM
69-CHVL 69-CHVL is offline
Vinny Vince
What rear 3.90? Any stall? With that much gear you may like the DP.
I say try both.
*69 CHEVELLE SS EFI 502/T56 Mag/3.90
*06 C6 LS2/T56
*96 Stang LQ9 6.0 turbo - everybody should have one!
  #11
Old Nov 10th, 08, 11:08 AM
Al
Car will be a weekend driver. And yea, she'll have to go to the track once or twice.
Here are the specs to what the shop is building.
Cam- 510
Duration- 318
Lift .0050
Pulls hard between 3000 - 6500 rpm?
Piston- Dome type
Compression 10.7
Heads- 202
Tranny- 700r
Stall 2500 minimum
Al
Engine, 350
12 Bolt Rear End
Pics
Restoration website
http://72malibu.com
  #12
Old Nov 10th, 08, 2:47 PM
LS6 Tommy LS6 Tommy is offline
Tommy
So did the LS6... Back in the "old days", the 780 vac sec was considered to be one of the best choices for a performance car.
In general, a vac sec is better suited for a heavier, numerically lower geared car & the double pumper is better suited for a light car or higher gearing.
Tommy
  #13
Old Nov 10th, 08, 3:13 PM
Vinny Vince
There should be a sticky - DP vs. Vac sec.
If you do a search, you'll have enough material to read for about an hour.
*06 C6 LS2/T56
  #14
Old Nov 10th, 08, 3:30 PM
Chris R Chris R is offline
I agree with the 3310. Great carb for most of the street engines out there.
Chris.
When the Boogeyman goes to bed, he checks the closet for Chuck Norris.
If it aint broke, just give me a minute.
  #15
Old Nov 10th, 08, 10:19 PM
Al
I just came across this article about Demon carbs. Has some tech info on
Vacuum and Mechanical secondaries
http://www.carcraft.com/techarticles...arb/index.html
Al
Engine, 350
12 Bolt Rear End
Pics
Restoration website
http://72malibu.com
Chevelle Tech > Information Exchange > Chevelle Tech      Current Topic: Mechanical (VS) Vacuum secondary Carb
Location
*REQUIRED*
Insurance
First Name
Human Verification
