12-bolt Torque specs? - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Nov 9th, 08, 3:23 PM
67Chevelleguy 67Chevelleguy is offline
wes
Default 12-bolt Torque specs?
Hiya Team!
Can you fine felles remember what the bearing cap torque specs are on a 67 12-bolt? I found a website that says 60-ft lbs, but I just want to be sure
Thanks TC!
-wes
Wes B in utah
warmed over stock black 67 SS clone
4 Speed butternut yellow 67 SS project
Old Nov 9th, 08, 3:34 PM
Mike Mike is offline
& Moderator
Default Re: 12-bolt Torque specs?
# Cover Bolt Ft. Lbs. 20
# Pinion Brg. Preload In. Lbs 20-25
# Pinion Brg. Preload In. Lbs 10-15 Used
# Ring Gear Backlash .005-.009
# Ring Gear Bolt to case Ft. Lbs. 90
# Side Brg. Caps Ft. Lbs. 60
http://www.drivetrainspecialists.com/setupspec.html
Old Nov 9th, 08, 4:01 PM
wes
Thank you sir!
Wes B in utah
Old Dec 3rd, 08, 8:21 PM
HMartin HMartin is offline
Team Member
Thank you search feature and Mike!
Old Dec 3rd, 08, 11:05 PM
big gear head big gear head is offline
Freddie
90 foot pounds of torque on the ring gear bolts is 2 times too much. The bolts will break or strip the threads. 45 foot pounds is correct for these 3/8 bolts. The other specs are not too far out. I don't set the backlash any tighter than .007 and no more than .009 in most cases. The pinion bearing preload shouild be 19 to 22 inch pounds in my opinion. 60 foot pounds is right for the bearing cap bolts.
  #6
Old Dec 4th, 08, 1:02 PM
& Moderator
Freddie ,it appears that they've changed the site and the specs since I posted.
Apparently someone pointed out the errors.
Thanks for your noticing them.
  #7
Old Dec 4th, 08, 9:10 PM
Freddie
The GM service manual also had the same specs in it. About 27 years ago I was putting together my first 12 bolt and I tried to torque the ring gear bolts to 90 foot pounds. Most of them stripped and I think a few broke. I had to buy a new set of bolts.
  #8
Old Dec 9th, 08, 1:28 PM
CDN SS CDN SS is offline
Gold Member
Bill
BGH .question I have one season on a new R&P and posi ..... thinking I should check the pinion nut to ensure it tight .... is that possible with out screwing up preload ...used a spacer not a crush sleeve ............. or should I just check the inch pounds it takes to rotake rear end ......... if so what should that be ??
66 CDN Malibu SS A51,L34,M20 Aztec Bronze
Now 439ci Straub Solid Roller Brodix RR ,Tremec by Liberty
10.97/ 124.31 1.41 60ft
Crusin / Track video http://www.youtube.com/watch?v=fhvDGOO4JAI
Engine
  #9
Old Dec 9th, 08, 3:20 PM
Freddie
Do you know what the original torque was on the nut? If you used a solid spacer then you should have torqued it to about 200 foot pounds. If you know what torque you used then just go back and torque it again. It shouldn't hurt anything.
There is no way to check the bearing preload on an assembled rear end. The only way to check it is if you remove the axles and differential.
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: 12-bolt Torque specs?
Location
*REQUIRED*
Insurance
First Name
Human Verification
