driveshaft loop install.. how far back - Chevelle Tech
Auto Insurance
Old Nov 5th, 08, 9:51 PM
BowtieAaron BowtieAaron is offline
Aaron
Default driveshaft loop install.. how far back
im going to the track this sunday, and now that i have sticky tires, i need to run a loop since i have a stick.
so how far back does the loop go from the x-member, is it 6"?
thanks
aaron
1971 Chevelle. 355, megasquirt efi. On3 7875 turbo. 700r4, 355 gears. C5 brakes, SC&C stg2+, hellwig bars, 04-06 gto seats.
Little walk around video
http://youtu.be/D_B0B1RNmcc
Old Nov 5th, 08, 10:08 PM
77 cruiser 77 cruiser is offline
Jim
Default Re: driveshaft loop install.. how far back
I think no farther than 6" back from the u joint.
Jim
77 Monte
385- AFR 190's Clay Smith solid--200-4r w/ 3.73's
67 Imp.SS for the wife 275 hp 327-TH350
http://myweb.midco.net/77cruiser/
Old Nov 5th, 08, 10:14 PM
nolimitpkr nolimitpkr is offline
Brian
x2
1968 300 deluxe
15.9 @ 88.0 mph
1968 mailbu (383,th400,12bolt/posi)
13.52 @ 101.84 mph
"Just about the stupidest thing you could do, is to try and move a big block with your shoes untied."
"IF YOU HAVE A RACE CAR BUY RACE CAR PARTS"
Old Nov 6th, 08, 2:03 AM
BillyGman BillyGman is offline
Here's a pic of the loops that BMR Fabrication sells. But they come in black unless you specify red. I installed one of these on my 70 Chevelle, and what I like about them is that they're contoured specifically for our cars, since the arms are angled perfectly to follow the angle of the reinforcement boxed rib on the Chevelle floor board where the floor is the strongest. Which I believe is also the perfect distance away from the front U-joint. The main hoop also fits the driveshaft tunnel perfectly. It makes for a much more precise fit and a cleaner install than those universal type loops made by Lakewood and Competition Engineering do.
http://www.bmrfabrication.com/A-Body.htm
70 Chevelle SS clone (632 CI powered).
Old Nov 6th, 08, 9:01 AM
Mikeys69 Mikeys69 is offline
/\/\ikey
Send a message via MSN to Mikeys69
Thats just sick. Mine came in pieces. Ready to assemble..right.
Nice loop..
2012 GMC Terrain
2011 Chev Silverado
2004 Chev Silverado
1969 Chevelle Malibu 406 SB
http://www.chevelles.com/forums/showthread.php?t=386745
Some day I will own a 1967 Chevelle, again.
  #6
Old Nov 6th, 08, 10:00 AM
LS_5 LS_5 is offline
Gold Founding Member
Andy
Thanks, Billy.
Andy
'70 Resto/Mod Coupe
555 Solid Roller - Mike Lewis Racing Engines (791/700)
G Force 5 speed (GF-5R)
Strange 9", Lenco Billet Locker, 3.50 gears
http://www.chevelles.com/showroom/da...ber_08_058.jpg
  #7
Old Nov 6th, 08, 10:03 AM
Aaron
thanks guys.
i have a universal one i got from jegs about 2 years ago that i never put on. i will make it work.
thanks again.
aaron
  #8
Old Nov 6th, 08, 10:28 AM
OLDED OLDED is offline
Team Member
Ed
I like the concept of the loop that bolts under the trans mount. Does anyone have or know of anyone's experience with it doing what it needs to do if a joint actually breaks? Thanks,
OLDED - It's STOCK if it's made by GM and it fits!
*65 Elky, Gen VI 496 BBC, TH400
*59 Vette, 283/270 hp. T5 5 spd., 4:11 posi.
*Harley - 06 Street Bob
*Life Member - Team Chevelle & Team ElCamino
*Peach State Chevelle Member
*Retired June 1, 2014****
  #9
Old Nov 6th, 08, 1:53 PM
I liked it too, so I bought one (although I cannot remember where I bought it from, and I've misplaced the receipt, so I couldn't even tell you where) but I went to put it on my car, and learned that it's only good for the Chevelle stock sized 1310 series U-joints. I have 1350 series U-joints, and that loop that bolts to the transmission mount has a diameter that's too small, so it won't even clear the 1350 U-joint, nor the 1350 series transmission slip yoke. It looks like it would be good if you have the smaller 1310 U-joints though.
  #10
Old Nov 6th, 08, 3:13 PM
showbiz showbiz is offline
Greg
Wish I would have seen this when I posted about a loop,(thats a nice unit) had a lakewood & fabbed ,bent to conture of the body brace ,loctite all bolts ,& renforced. yes 6" max from u/joint center 2"wide band is the NHRA rule in the 2007 book
1972 Custom Resto Mod Elcamino.. ..ZZ572/620 /650/NOS/ TKO600Tremec /12 bolt 373 /JYD /Cpp Big Brake discs/ Air RideTechnologies Street Challenge/
  #11
Old Nov 6th, 08, 4:07 PM
Aaron
thanks guys.
aaron
  #12
Old Nov 6th, 08, 5:07 PM
DougA DougA is offline
Doug
I easily made one.I bought just the 2" loop from Jegs,I think it was around 10 bucks.I then took a piece of 1/2"bar stock about 3" wide by about a foot long.Welded the loop on the top of the end of the stock.There are 2 holes,one behind each other on the crossmember,a couple of inches apart,parallel with the tailshaft.One was 1/2 " drilled the other one out to 1/2".Drilled the stock and bolted it into place with two 1/2" hardened bolts.It's a bit of an overkill as strong as it is,and it's a little heavy,but the best part is I didn't have to drill any holes in my virgin floors,and it's easily unbolted out of the way.
70 SS 454 LS-5 M-22 Matching #'s
Sold New@Baldwin Chevrolet
Jeff Dotterer Authenicated
LS-5 Registry
72 SS 454 El Camino W Code
Powered by 427 Oval Port 4 Speed
60',1.47, 6.69@102.42 10.53@128.1
My Showroom
Elky in Car Camera Rowin' Gears http://www.youtube.com/watch?v=5vMnf...layer_embedded
Wheels Up Video http://www.youtube.com/watch?v=MQuBitMOA5w
Elky Wheelstand http://i1268.photobucket.com/albums/...Wheelstand.jpg
  #13
Old Nov 6th, 08, 9:56 PM
/\/\ikey
Does any of this stuff have to be something like SFI approved?
2012 GMC Terrain
2011 Chev Silverado
2004 Chev Silverado
  #14
Old Nov 7th, 08, 1:37 AM
Not that I know of. My guess is that if the tech inspector can reach the loop, and he grabs onto it to try and wiggle it, and it feels solid, then he won't have a problem with it as long as it's relatively close to the front U-joint. And I can't see them trying to crawl under there with a tape measure to enforce the exact distance specified by the NHRA rule book either.
  #15
Old Nov 7th, 08, 2:06 AM
FourEightyNine FourEightyNine is offline
Brian
Send a message via AIM to FourEightyNine
Your guys tech inspector actually looks? Wow ours just says you got a loop? Yup, alright then your ready to go.
Its helps if you havent washed your car since las ttime and you still have the numbers on the window.
Chevelle Tech > General Tech Area > Performance      Current Topic: driveshaft loop install.. how far back
Location
*REQUIRED*
Insurance
First Name
Human Verification
