GMPP BBC Serpentine Kit - GM Performance 19172805 - Chevelle Tech
Auto Insurance
Old Nov 5th, 08, 3:49 AM
ss396boy ss396boy is offline
Jason
Default GMPP BBC Serpentine Kit - GM Performance 19172805
Anyone using this kit on their BBC A-body, Summit is showing the PS pump might hit the steering box, wondering if anyone has had this issue.
Looking to get a serpentine kit and this like like a nice setup for $700. Also looking at the march setup, but it's quite a bit more. The GMPP includes the water pump, PS pump, A/C, and brackets.
69 540 FAST EFI BBC El Camino"it's alive"
http://profile.imageshack.us/user/peetsjunkie/images Check out the latest stuff here!
Old Nov 5th, 08, 9:28 AM
VinnyLSS572 VinnyLSS572 is offline
Vinny
Default Re: GMPP BBC Serpentine Kit - GM Performance 19172805
I have this setup brand new in the box and never used.I purchased it for my 70 Chevelle and never used it because I went to an electric water pump and no longer use the car on the street.
PM me if you are interested in the kit
Vinny
1970 Chevelle ZZ572/720R
TH 400 w/brake
12 Bolt w/ 4.10 gears
best run to date
9.830 @ 135 mph
1.324 Best 60'
http://www.dragtimes.com/Chevrolet-C...slip-9729.html
http://i135.photobucket.com/albums/q...LEATETOWN2.png
1969 Camaro SS 8.721 @ 156.61
Old Nov 5th, 08, 9:32 AM
67EC 67EC is offline
Frank
I had one on my 67 big block El Camino. I couldnt fit the power steering pump with this kit or the original setup I had.
49 Fleetline LQ4, T10, two S300s blow through
80 RX7 LY6, th350, pt7675 ms1
Old Nov 5th, 08, 12:37 PM
Jason
Did it hit the steering box?
Old Nov 5th, 08, 2:13 PM
Frank
Yes it did. I think there might be more room in the 68 and up engine bay though, so dont let me discourage you from trying. I went from a sbc with power steering to a bbc and couldnt get it to fit.
  #6
Old Nov 5th, 08, 2:32 PM
70 502 70 502 is offline
i talked to gmpp about this kit on my 70 monte carlo and they had installed one on their 70 project car with whatever big block they were using and was told a little grinding on the box was needed for pulley clearance,might have to make sure of whatever mounts you are using as they will determine how much grinding is needed. i had to modify my whole kit because of the gearbox being 4"forward,could not mount the ps pump whatsoever.
  #7
Old Nov 5th, 08, 2:34 PM
also was the previous part number i used,however shouldn't make a difference on the lit mounting itself.
  #8
Old Nov 5th, 08, 3:49 PM
godsend godsend is offline
Send a message via ICQ to godsend
Its also heavy as hell ;(
  #9
Old Nov 5th, 08, 8:34 PM
Frank
Yeah for sure, it is definitely one heavy son of a gun. Ive got my S400 hanging off the passenger side of it it is so heavy and stout.
  #10
Old Nov 5th, 08, 8:44 PM
317millhand 317millhand is offline
steve
67's and older have a more narrow frame in the front putting the steering gear box too close to the engine block to use a saginaw style pump. That is why the remote style ps pump was used on these cars with a big block. Small block cars dont have a problem.
  #11
Old Oct 29th, 09, 10:58 AM
BB_Mike BB_Mike is offline
Team Member
Bump.
I might be using this kit on my 71 chevelle with a big block.
If I was getting the brackets only and needed to get the A/C, Alternator, P/S, what vehicle would I quote to the parts counter people?
What vehicle would I suggest to them for the remote resevoir Power steering setup? Is that power steering pump a smaller profile insuring that I would not contact the steering gearbox?
Can I get an aluminum reverse direction water pump from an aftermarket supplier?
member number 684
71' coupe project:
goal: 150+MPH, 9s driven to and from track, 275 front tire, 315 rear tire, 1000+HP
Build: 540cid, twin turbo, 4L80e, ...wait for it...
Heart of Dixie Chevelle Club
  #12
Old Oct 29th, 09, 11:16 AM
Team Member
Also,
what are your thoughts on this:
http://www.kwikperf.com/bbc_serp_kit.html
It seems like the better option of the two if you can find the pieces and parts that they do not sell. I am looking into it now...
member number 684
71' coupe project:
  #13
Old Oct 29th, 09, 6:58 PM
phocksphyre phocksphyre is offline
John
Originally Posted by BB_Mike View Post
Also,
I had one of these put together and mounted on my 67 El Camino BBC, even adapted to use a Sanden compressor for the A/C. Had to put it together in a certain order to get the PS pump in and clear everything but it did fit and looked pretty good. I had the aluminum SBC brackets powder coated and it looked pretty trick. Unfortunately my computer took a crap and I lost the pics. The problem with a 66 or 67 is that the switch to a LWP results in not enough room for a fan. You might be able to get an electric fan setup in there, but a regular fan or flex is out. I think Don at Alumitech has a setup which will clear it now. I had a conversation with him at the time, and he was working on it but it wasn't yet available when I tried it (several years ago). The cars which came with a LWP should be no problem.
John
'67 Elky - 496 / TH400
"Democracy is two wolves and a lamb discussing what's for dinner. Freedom is a well armed lamb contesting the vote" Benjamin Franklin
http://www.picturetrail.com/gallery/...6593&members=1
  #14
Old Oct 29th, 09, 7:19 PM
Frank
Hey Mike I am Frank with the kit. I think the GMPP setup is just too heavy for a performance application, maybe any of the cheaper budget serpentine setups are too heavy. If you arent spinning your motor real high, probably arent with turbos you'll have more than enough power, maybe just re-evaluate staying with standard v-belt? I was all hot and bothered for the serpentine setups at one time and then once it was a pain I did a v-belt and it has worked fine.
Let me know I am totally willing to send it to you I just think it is too heavy. The weight difference is like going to aluminum heads on your BB and adding the weight of iron heads back on!!!
  #15
Old Oct 30th, 09, 7:32 AM
John
The weight thing is Huge! I bought a setup from my local Chevy dealer. The brackets in the one I got are cast steel (= HEAVY). Then add the problems of the PS pump hit the steering box, and fan clearance...I went back to V belts. Using the SBC setup puts ALL of the accesory drive hubs in the same plane and moves them in toward the WP. The result in 66-68 models (don't know about 64-65) with limited room between motor and radiator is that in addition to no room for a regular fan, the accessory drive pulleys interfere with the motor of electric fans, whether using one or 2. There are some pretty thin Spall units with high CFM that might work. SOmeone on here (TC) has a working setup - search the topic and you should find the thread. Include my name (phocksphyre) as I was involved in the discussion. This has been covered pretty well on a couple of occassions.
John
John
Chevelle Tech > General Tech Area > Performance      Current Topic: GMPP BBC Serpentine Kit - GM Performance 19172805
Location
*REQUIRED*
Insurance
First Name
Human Verification
