Cheap 283 mods/hop-ups - Chevelle Tech
Auto Insurance
Old Oct 9th, 08, 9:43 PM
tomcowle tomcowle is offline
Tommy
Default Cheap 283 mods/hop-ups
1965 malibu, 283", turbo 350 trans with 10" convertor, 3.73 gears, 26" tall rear tires, holley dual plane, 600cfm carb. 1 5/8 headers
I'm looking for some cheap 283 speed tricks.
Can I install 1.6 ratio rockers and gain?
Carb spacer?
valve lash?
Larger cam (not wanting to change springs at this time)?
Old Oct 9th, 08, 9:46 PM
65lkey 65lkey is offline
Paul
Default Re: Cheap 283 mods/hop-ups
figure out what heads you have. Maybe try and increase compression ration. then add some cam to it. or cam at least
Trying to break the 13's $1 at a time
1965 El camino
http://s88.photobucket.com/albums/k1...20El%20camino/
Old Oct 9th, 08, 9:47 PM
Tommy
Stone stock 1965 283 heads.
What was the head gasket thickness factory?
Old Oct 9th, 08, 10:15 PM
Jerry70 Jerry70 is offline
If your cam is still stock, that's where you'll find the most hp per $. Something around 220º @ .050 would give a noticeable mid/upper rpm increase without killing too much low rpm power. Next up would be heads (or heads AND a 350 shortblock . The items you mentioned would probably get you a couple horses each with a stock cam.
Old Oct 9th, 08, 10:32 PM
Paul
I try and find some vortec heads or a better 1.94 intake valve head then a cam with about 220* @.05
Personally I like 283's there out of the ordinary and with a cam they sound awesome too
1965 El camino
  #6
Old Oct 9th, 08, 11:49 PM
pdq67 pdq67 is offline
Guest
Paul
Smile Re: Cheap 283 mods/hop-ups
I'mmm herrrre!!
Sure, get her up to 10 to 1 using worked over and planed to 50 cc chambered 305HO, -601 heads, Fel-pro's #1094 .015" thick shim headgaskets, stock flat-top pistons and install this solid lifter cam from PAW that I figure is this Elgin cam.....
E-1133-P; 280/246, 108/106, .498, Lash, .030 and .030
in it from PAW for like less than $50 when I bought mine and have more fun than the Law will allow!
PAW calls it their 264/246 cam so go figure IF they are still selling it and I have one in my bedroom closet for my next junk292/301 engine that I am gathering parts for!
You will be looking at 385 hp at 6500 rpm and 350 t at 5,000 rpm per D2k?
pdq67
PS., you put 64 cc Vortec heads on her and your CR will be about 8 to 1 unless you install stock 1/8" tall, 1/2 round, domed pistons.
I know all about this stuff b/c of my old junk301 from years gone by!
  #7
Old Oct 10th, 08, 1:07 AM
kettbo kettbo is offline
George
Tommy,
Your engine is SCREAMING for better heads and cam. However, you will not get much of a car if you want to run stock springs
George Kettler
o 70 Elky 496 build continues #074 AL heads
$2000 low buck 454 is broken, ran well for a 3995# all-up wt.
1.631 11.727 113.37 91.47 midtrack 1.647 11.729 113.49 91.58 mph mid track
Bests 1.620 60 ft 91.60 best mph
o 68 Vette 427/M-20/3.36 23 year owner
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
  #8
Old Oct 10th, 08, 1:29 AM
Guest
Paul
That's really not so b/c all Chevy did when they installed the old 30-30 cam was QC'd their stock springs and installed them.
I do suggest installing at least a cheap set of Z-28, (-142), valve springs tho! Heck, what are they?? $25 to 35/set?
Check Midwest Motorsports Elgin Z-28 type springs and retainer kit.
pdq67
  #9
Old Oct 10th, 08, 1:30 PM
67kmq 67kmq is offline
Mike
Send a message via AIM to 67kmq
my 67 283 has stock heads (1.94 1.5 valves if i remember correctly), hooker hk32(i think thats the part number) 1 5/8 headers, hei distributor, weiand al intake with edelbrock 600cfm carb with manual secondaries, supposedly has a 485 lift cam already installed, dont know much more about it than that, and electric fan, all sitting in front of a muncie. hopefully i at least have 283 hp at the flywheel. it came with 195 hp stock
edit- pdq what should 283s like these be shifted at? i see your hp quote is at 6500 rpm, but i was figuring on shifting at 6k
Keep cars, not girlfriends
1967 Chevelle 283 m20 on the way summer 09... or 10
  #10
Old Oct 10th, 08, 2:18 PM
rkd rkd is offline
Ron
Spray it!
66 Malibu Coupe, home rebuilt 350. Took me 39 years to get her!
  #11
Old Oct 10th, 08, 2:37 PM
Jason Snyder Jason Snyder is offline
question , how much valve lift can yu use with 1.94 valves and the small bore ? im sure the valve will interfere with the bore at some point ?
  #12
Old Oct 10th, 08, 3:31 PM
BillsCamino BillsCamino is offline
Gold Founding Member
"Wild Bill"
Send a message via AIM to BillsCamino
1.94" valves will not interfere with a 3.875" 283 bore no matter what lift... a 2.02" intake valve will though.
1972 GMC Sprint
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
  #13
Old Oct 10th, 08, 3:32 PM
gotcha thats what i was wondering .
  #14
Old Oct 10th, 08, 5:07 PM
FRYNTYR FRYNTYR is offline
Doc. Smokum
I have a customer that has ran a set of my not-quite-stock vortecs, cut out to 2.02-1.6's sitting at 52CC's on a little .060 over 283. It's his back up motor to his 350 powered circle track car. He has won races with that little motor and while it is lacking a little torque coming out of the corners to the 350, it rips down the straights.
So, I know a over bored 283 will accept a 2.02 valve. Std bore, I don't know.
Personal best, 9.22 @ 152 MPH. Looking for 8's this year.
http://tcnwracing.com/
  #15
Old Oct 10th, 08, 10:12 PM
Guest
Paul
Only one or MAYBE two of 283 engines came out w/ the -461x heads w/ 1.94"/1.50" valves and it was in the early '60's so all the others ran heads like the power pack w/ 1.72"/1.50" valves.
Or smaller intake port jobbers than them.
You can run 2.02"/1.60" valve double-hump heads on a 283 IF you use a lift limited cam that's from .450" and shorter! But you'd better run domed pistons and shim headgaskets b/c your CR will be down around 8.2 or so w/ flat-tops!
The 283 I finally got that was my Nephew's had a good set of big valve 291 heads on it, flat-tops and a TRW 308/246, .433" lift hi-cam in it! I figure the reason he got the old junk car w/ it in it was b/c it wouldn't pull me off my Throne, it was so low CR'd!!
pdq67
Chevelle Tech > Mechanical > Engine      Current Topic: Cheap 283 mods/hop-ups
Location
*REQUIRED*
Insurance
First Name
Human Verification
