Called ISKY today about our 307 cam topic - Chevelle Tech
Auto Insurance
Old Oct 8th, 08, 7:47 PM
Part Timer Part Timer is offline
Team Member
Bob
Default Called ISKY today about our 307 cam topic
Since a lot of you have suggested the ISKY 264 Mega, I called them to ask their opinion (figured I might as well since i have pestered everyone on here and at Crane and Comp). Anyway I told them the subject was a 307 with 305 heads, 600 cfm, and headers and a 2000 stall converter. They said the 264 Mega would work but a regular 270 would also work with a nastier idle. It has 270 duration and 445 lift. Does this one sound like a good option to you as well? Thanks for all yoru help.
"Thats what she said" Michael Scott
"Trying is the first step toward failure" - H. Simpson
Aces Member # 08163
1972 Chevelle
Old Oct 8th, 08, 7:54 PM
Jason Snyder Jason Snyder is offline
Default Re: Called ISKY today about our 307 cam topic
i believe they gave you incorrect info ? the 270 mega has .470 lift and 108lsa .I have used alot of these in 350s. they run killer in 9.5-10.25 engines with headers and a 600 carb . they havea nice lope as well , should sound really good in a 307 !
Old Oct 8th, 08, 7:57 PM
BillsCamino BillsCamino is online now
Gold Founding Member
"Wild Bill"
Send a message via AIM to BillsCamino
I bought the Voodoo #60102 cam kit for my 283 (292"), 305HO headed engine project.
I've used the Voodoo line of cams before with great results.
This cam is 262/268; 219/227 @.050"; .468/.489 lift w/1.5 rockers; 112 LSA.
Should work very well with this 9.75 CR small block.
1972 GMC Sprint
^^^ On my "To Do" list for heart transplant
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
Old Oct 8th, 08, 7:58 PM
Team Member
Bob
They told me to not use the mega 270 just the regular 270. It is part number 201270.
Aces Member # 08163
1972 Chevelle
Old Oct 8th, 08, 8:32 PM
pdq67 pdq67 is offline
Guest
Paul
Isky steered you to the "old-school" 270 cam is all and it will be great for you, imho!!
It's actually the cam they sell to compete against the CC 268HE and Crane/Cam Dynamics 272/272 Energizer!
You will be FINE, imho!!
pdq67
PS., and my hopped up, .040" overbore 300hp/327 had the old Crane/Cam Dynamics 272/272 Energizer in it and it ran like a "scalded-dog"!!!!!
  #6
Old Oct 8th, 08, 8:51 PM
oh gotcha ! what is the lsa on the standard 270 ?
  #7
Old Oct 8th, 08, 8:56 PM
Guest
Paul
Their e-cat say's both are 108.
pdq67
  #8
Old Oct 8th, 08, 9:23 PM
Team Member
Bob
What is an LSA and what does it do?
Aces Member # 08163
1972 Chevelle
  #9
Old Oct 9th, 08, 7:04 AM
71454Chevelle 71454Chevelle is offline
Darren
Send a message via ICQ to 71454Chevelle
Cam card for Isky's 270
http://www.iskycams.com/timingchart...._number=201270
Cam card for Isky's 264 Mega
http://www.iskycams.com/timingchart....ng_chart_id=93
Darren
1971 Chevelle
496
CFM Ported Stage 5 Brodix Race-Rites 310cc
10.5 scr
Ultradyne Solid Roller 256/264 .660/.660 108 lsa
CFM Ported Victor Jr / Pro Systems HP1000
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Mosier axles
30x12.5 ET Street Radial
525++ rwhp
http://www.chevelles.com/showroom/da...0930-00149.jpg
http://www.chevelles.com/showroom/da...m/Vic_Jr_1.JPG
  #10
Old Oct 9th, 08, 4:46 PM
Originally Posted by 71454Chevelle View Post
man they are so close i would FLIP A COIN !
  #11
Old Oct 9th, 08, 6:22 PM
kettbo kettbo is offline
George
Holy crap, the Isky 270? Maybe the same guy that recommended that cam for my 312" SBC back in 1980 is still there!
I lived 15 minutes from Isky in SoCal
I had rod bearing failure on my 427. Had sold a 400, a 350, and some other stuff...so only had the 307 shortblock left. My pal threw the shortblock into the trunk of his ROADRUNNER and took it to the shop for me. The 2V heads also. Just my luck, someone wanted my 2V heads so I upgraded to #462 Humper heads 1.94/1.50 and got the shortblock back 40-over. Cam, Isky 270!
Thing was, the engine went into my 68 Nova that had a fiberglass hood, 10-inch converter and 4.56 gears! The cam pulled to 6000 no issue and many a folk got a good look at my rear bumper even though they had lots more engine.
Combination
Combination
Combination
When you get tired of saying that, say
light car
light car
light car!
George Kettler
o 70 Elky 496 build continues #074 AL heads
$2000 low buck 454 is broken, ran well for a 3995# all-up wt.
1.631 11.727 113.37 91.47 midtrack 1.647 11.729 113.49 91.58 mph mid track
Bests 1.620 60 ft 91.60 best mph
o 68 Vette 427/M-20/3.36 23 year owner
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
  #12
Old Oct 9th, 08, 9:14 PM
TMessick TMessick is offline
T
LSA = Lobe Separation Angle. (#10 in the pic above from CompCams) Basically, the angle (in cam degrees) between peak lift on the exhaust valve and peak lift on the intake valve. (click on the pic for some good info from Crane)
Smaller (tighter) LSA's mean the intake and exhaust valve peaks are closer together. For a given set of lobe profiles, this means more overlap and a nastier sounding idle. Tighter LSA's also tend to have peakier torque curves with peak torque at a higher RPM. Larger (wider) LSA's have the opposite effect. 106-108 is on the tight end of the "typical" scale, 112-114 is on the wide end of "typical".
  #13
Old Oct 10th, 08, 11:28 AM
fabio fabio is offline
not much of a difference but the 264 seems a little more modern. But really not much of a difference but that's what I would run. tight lsa will help it come on harder and have more down low while sounding nasty. They don't the mpg as a wider lsa would though.
  #14
Old Oct 10th, 08, 12:19 PM
Guest
Paul
Fwiw, my 1982 Isky cat. say's the 270 HL is spec'd;
270/216, 108/108, .445" lift.
And the 264 Mega from their e-cat. just now is spec'd;
264/214, 108/108, .450" lift.
Imho, the 264 will midrange T a schosh better and the 270 will Hp rpm a schosh better so take your pick. But, all said and done, they are darn close!
And the 270 Mega is spec'd;
270/221, 108/108, .465" lift!
pdq67
Chevelle Tech > Mechanical > Engine      Current Topic: Called ISKY today about our 307 cam topic
Human Verification
