muncie 4 speed problems - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Oct 4th, 08, 10:51 AM
72 ss canadian built 72 ss canadian built is offline
mike
Default muncie 4 speed problems
reinstalled muncie 4 speed seems to shift ok,clutch engages & disengages ,but always in gear no neutral.disconnected linkage set all levers to neutral,still no neutral with car running. any suggestions please
Old Oct 6th, 08, 2:33 AM
JWA JWA is offline
Administrator
Jeff
Default Re: muncie 4 speed problems
ttt
Gold Founding Member #158
Old Blue
The TC Search >> HOW-TO
TC photo >> HOW-TO
Old Oct 6th, 08, 7:05 AM
dreis454 dreis454 is offline
Dan
shifter adjustment
72 ss 454 "W" code,w/cowl induction (how many left?)
matching # LS5 454+.060" 9.2 :1, 2.19/1.88 valves,Comp HR cam 289/295 234/240 .613/.613 110* (dyno'd @ 557hp @ 5400 & 583tq @ 4100)
matching # M22 w/CF dual friction clutch.
Holley 750 HPs dp(82751) on Weiand Stealth & MSD Pro billet HEI
Hedman Elite headers/Flowmaster exh. (w/super 40s)
TC#3095
Garage find parked from 1978-2004
http://macswebs.com/ls5registry/bal/bal.htm
http://www.chevelles.com/showroom/sh...0&ppuser=25834
http://ssregistry.macswebs.com/1972/1d37w2b_reis.htm
http://www.youtube.com/watch?v=YqZkVw6xMkM
Old Oct 6th, 08, 7:50 AM
Wally Wally is offline
Moderator/Gold 67
Was somebody in the trans??? Never seen one that had no neutral unless the clutch was whacked.
Gold 67
M.C.C. 559
1967 Malibu
www.muncie4speed.com
www.muncie5speed.com
Nothing Shifts Like a Muncie!
Old Oct 6th, 08, 11:40 AM
oman oman is offline
Originally Posted by dreis454 View Post
shifter adjustment
Seems to me the Shifter adjustment has been eliminated because he says "disconnected linkage set all levers to neutral"
  #6
Old Oct 6th, 08, 11:51 AM
Ken Ficquette Ken Ficquette is offline
KenF
I have seen this when the side plate was removed and reinstalled with one of the shift forks not installed on the slider properly.
  #7
Old Oct 6th, 08, 2:26 PM
Moderator/Gold 67
It won't shift OK if it gets put together with a shift fork not in the clutch. I can't imagine how the hell you can do that to start with, backwards on the clutch maybe.
Gold 67
M.C.C. 559
1967 Malibu
  #8
Old Oct 7th, 08, 8:47 AM
BigBocks66SS BigBocks66SS is offline
Team Member
Jim
Have you tried to drive the car? Does it try to lock-up when you try to back it up? When you say that it is always in gear, does it just try to lunge a little, or does it actually feel like it is in gear? If trans locks up when you try to drive it, then it has a gear that is engaged when it is not supposed to be. It may be as simple as one of the shift forks were not properly installed, if it trys to lunge just a little when you let out on the clutch, then it may just be a little tight, I know that 90w on a cold morning will allow it to lunge a little.
  #9
Old Oct 7th, 08, 5:57 PM
5speeds 5speeds is offline
Paul
the guys says: NO NEUTRAL. Has nothing to do if his clutch is releasing or not. Its always APPEARS TO BE in gear...
This is what you need to do....
Pull the transmission! More than likely either whoever rebuilt it shimmed the input in so tight so that the synchro ring is jammed up against the 4th gear cone. As Wally mentioned a slider backwards will force the transmission to appear to be in gear because the synchro ring is loaded.
Or shut it off and stick it in reverse and start it up with the pedal down and see if something breaks free. It could simply be a stuck ring. I think however the 4th ring is jammed in too tight. I see this quite often when builders are obsessed thinking that they need to shim input shafts in.
Paul
www.5speeds.com
Thanks,
Paul Cangialosi
http://www.MuncieBook.Com
http://www.transmissionbook.com ( Facebook Support )
http://paul.video ( Youtube Videos)
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: muncie 4 speed problems
Location
*REQUIRED*
Insurance
First Name
Human Verification
