Whats the optimal engine coolant temperature to make most HP? - Chevelle Tech
Auto Insurance
Old Sep 9th, 08, 11:36 PM
Dave427 Dave427 is offline
Dave 383 now
Default Whats the optimal engine coolant temperature to make most HP?
Some guys swear that their engine makes the most horsepower when their engine is cool @ 160, and some say they make the best horsepower when their engine is hot @ 195. Whats best?
Dave
Old Sep 9th, 08, 11:53 PM
BowtieAaron BowtieAaron is online now
Aaron
Send a message via AIM to BowtieAaron
Default Re: Whats the optimal engine coolant temperature to make most HP?
ive always had good luck with a 180 in my sb's.
aaron
71 chevelle
355 10.3:1cr, brodix ik180 heads, voodoo hyd roller, holley efi intake, eMS-PRO, 60lbs dekas, ls tb, 700r4, 3.55 gears
Soon to be 7875 turbocharged!
368rwhp 383rwtq n/a with carb
12.23 @ 110 1.68 60ft
Dyno video NA
http://youtu.be/PvZ7tDVyryw
Old Sep 10th, 08, 1:22 AM
Bomber '67 Bomber '67 is offline
There is not just one "best" temperature - it depends on how the engine was built and where you are measuring the coolant temperature: at the head or the intake manifold? For a street car you will experience the best oil life and engine longentivity when your coolant is 200 to 205 degrees. Oil life is shorter when the engine is run cooler because there needs to be a sufficient engine temperature to burn off the atmospheric contaminants that are attracted to oil - oil is hydroscopic. Max effort later model computerized fuel injected engine tuners shoot for lower temperatures (~ 160 to 170) because they are fighting the dreaded knock sensors that will pull out serious amounts of timing if they perceive any detonation (knock sensors are not perfect).
Thomas
El Caminos a pair: '67 Bomber, '65 496
Avanti, Corvette and more
Old Sep 10th, 08, 2:19 AM
kirkwoodken kirkwoodken is offline
Ken
Whatever coolant temp you have, you want oil temp at least 220 to boil off water and acids. Head temps can be 300 F. degrees without problems. Air cooled two strokes get pretty warm. Ideally, you want intake air cold, head temp hot so as not to absorb combustion heat. More criteria that is hard to meet. It is a heat engine, made to run hot. You don't want to suck too much heat out of it by way of cooling system.
kirkwoodken
406 SB, Original Bill Thomas '63 Rochester FI
AFR 210, Lunati 501C2LUN, 255/263@.050", .628"
10:1, TH400, 3.31's, 4400 SS
"Life is too short to not run a solid roller cam."
"Nothing is impossible; if you don't know what you're talking about."
Kirkwoodken
Old Sep 10th, 08, 7:43 AM
SWHEATON SWHEATON is offline
Team Member
Smile Re: Whats the optimal engine coolant temperature to make most HP?
For Our 30-40 Yr Old Sbc/bbc Motor Design Approx 180-190 Deg F With Most Setups.
Todays Motors Are A Different Story,hotter Is The Norm.
Scott
SCOTT
1969 CHEVELLE SS396,ORIGINAL #'S MATCH,GOT IN 1978,(In 2001 rblt/bored original 396 .030 to 402)/M20/12BOLT/3:31'S
2006 YAMAHA 1700 ROADSTAR SILVERADO (1 owner ,GOT in 2009,4,700 miles/WK end fun)
1977 KAWASAKI KZ1000 (AM ORIGINAL OWNER ,GOT IN 1977,NOW has 29k miles/WK end fun)
2002 MAXIMA (DAILY DRIVER/1 owner,GOT 3/2013 w-44k miles)
  #6
Old Sep 10th, 08, 7:48 AM
onovakind67 onovakind67 is offline
For example an NHRA Pro Stock engine makes over 1,400 HP and uses a 0W-5 weight engine oil. A NASCAR Nextel Cup Engine only makes 850 hp but uses a 5W-20 weight oil. How can a more powerful drag motor use a lighter weight oil? The NHRA Pro Stock motor runs at a cool 100 degrees F. A NASCAR Nextel Cup engine runs around 220 degrees F. Our Joe Gibbs Driven XP0 racing oil is 11.5 Centistokes at 100 degrees F, and the XP0 oil is popular with the NHRA drag racers. Joe Gibbs Racing uses the XP1 in our un-restricted NASCAR Nextel Cup engines, and the XP1 is 9.5 Centistokes at 212 degrees F. As you can see, the operating viscosity of the 5W-20 XP1 oil is lighter than the operating viscosity of the 0W-5 XP0 oil due to the difference in operating temperature.
http://www.joegibbsracingoil.com/tra...er/082106.html
It depends on the application.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
  #7
Old Sep 10th, 08, 9:10 PM
ironhead ironhead is offline
Dave
I would swing towards the 195 F and a cold air induction.The 160F guys are sucking heat energy away from the piston top thru the cool cyl walls.A cool head and a hot block is more desireable for a street deal imo.The combustion chamber can be coated so as to not tranfer heat energy into the coolant..and still allow the valves to transfer heat thru the guides and seats.Now if we could come up with reverse cooling on our 60,s era engines..I would get on board in a heart beat.
George
8-71 blown 461 Rat on E-85
  #8
Old Sep 10th, 08, 10:12 PM
boldm boldm is offline
With the correct tune up the cooler engine (coolant temp) should always make more HP.
Any heads up racers, pro stock etc who make a better living by winning, or class racers, like super stock set on kill, trying to set national et records etc, they don't run 200 degree water temps,,, more like 120-140 on the starting line.
With the appropriate tuneup, I always ET quicker with a cooler running engine!
An added benefit would be to maintain hotter oil temp, less fluid friction.
93 Camaro backhalf car, 3100lbs SBC406 (tow truck motor) AED 850DP,super victor, AFR210 elim, Flat tops, UD Harold SR 243/249/112LSA, 1-3/4 custom headers, T-400, 4500 stall 4.30, best ET/MPH 10.30 at 129 mph (corrected), 10.57 at 126 at 3100 foot air. 1.39 - 60 ft. 91 octane pump gas.
47 years old, into my 5th decade of drag racing.
  #9
Old Sep 11th, 08, 9:56 AM
mirage2991 mirage2991 is offline
JB
knock sensors isn't the problem, you can detune them, matter fact I had to detune mine on the Goat as I was picking up some "false knock".
I think mose new engine are set to run hoter due to emission constraints. I do believe a hoter engine has less emission and has cleaner oil (like one stated: hot oil burns off the impurities like water).
They are also ran hoter for the Cats. Cats need to be at a certain operating temp to "work" like they are suposed too, so I would assume keeping the engine "hot" insure that the exh. gas are at the appropriate temp.
69 Camaro SS, Black on black
489 ci 10:1
1968 corvette convertible 327/4 speed
2011 ZR1 Arctic White w/black headlights
  #10
Old Sep 11th, 08, 11:01 AM
Highway Star Highway Star is offline
Team Member
Jake
i can attest to the newer vehicles liking higher temps. the newer 3800 gm motors have 205 thermostats, they like it hot for a cleaner burn, for less emissions gases and actually have a coolant bypass line plumbed into the water pump and manifold that purposefully heats up the intake right at start up to warm it quick and cut more emissions.
1972 Malibu Sport Coupe - Victory Red on Black - 350/TH350
I do all my own stunts.
  #11
Old Sep 11th, 08, 11:47 AM
Team Member
FYI,SOME MORE INFO ON OPTIMAL ENGINE TEMPS FROM COBRA VALLEY PERFORMANCE.
This is why is suggest 180 deg for best street perf temps.
SCOTT
However, there is a "middle ground" where both optimum performance as well as minimal wear share similar characteristics. That "magic" number lies in the 175-180 degree range, which requires a 180 degree thermostat.
The all too commonly used 160 degree thermostat is way too low to be considered for performance or engine longevity. Engine wear increased by double at 160, than at 185 degrees. So then, why do the 160's exist in the first place? The 160's were commonly used in older, open loop cooling systems where only 6 pound radiator caps were used, and low 212 degree boiling points were experienced. In contrast, modern cooling systems can see upwards of 260 degrees in coolant temperature with radiator pressures exceeding 45 pounds. Many early hot rodders found the 160's to be better performing than the 190's, however, the in between "180" appears to satisfy both ends of the spectrum. The correct water temperature is required for the cylinders to achieve a minimum specific temperature in order to allow a fully homogenized Air/Fuel mixture to combust efficiently. Guess what the minimum number is… right! 180 degrees. Even so, you might see some still recommending the lower 160's, for no other reason than to possibly get that last drop of horsepower out, at the high price of dramatically reducing the life of the engine and it's internal components.
SCOTT
  #12
Old Sep 11th, 08, 11:51 AM
Dave 383 now
Sounds good, 180 is where its at. With the 160 stat the engine seems to run at 170 a long time. But when in traffic it stays at 180.
Dave
  #13
Old Sep 11th, 08, 1:11 PM
Ol' Smokey thought that 200° was the lower limit for making serious power. It's about the conservation of engine heat, turning it into power instead of dissipating it through the cooling system.
  #14
Old Sep 11th, 08, 1:39 PM
Schurkey Schurkey is offline
Gold Founding Member
I agree. Keep the ENGINE hot; and the incoming air/fuel cold. There can be power gains with a "cold" engine, but it's not because the engine itself is cold, it's because they're not transferring as much heat to the air/fuel charge.
There were a lot of aftermarket PROMs sold for early computer-controlled vehicles; and it was recommended that a 160 thermostat should be used with them--the colder thermostat helped "fool" the computer into thinking the engine wasn't fully warmed-up, and so the computer was adding extra fuel as if the engine still needed "choke". So, yeah, the power went up--not because the engine was cool, but because it was getting a more advantageous air/fuel ratio.
It's not the cool engine temperature that's responsible for improved power.
Don't forget applying thermal barrier coating to the intake ports, to reduce heating of the intake charge.
1955--1959 Pontiac "Gusher" cooling. That doesn't quite make the "'60's era" cutoff, though.
I agree. Make the heat do actual work instead of inviting it to dissipate through the radiator.
  #15
Old Sep 11th, 08, 5:48 PM
I stand by my original response.
What Dave427 is asking is whats engine temp is best for making the most horsepower.
I don't see anywhere in his question anything about engine longevity.
I agree, the hotter coolant temps will reduce cylinder wear.
saying that,
my engine in sig is in it's 6th year,
400 + passes,
20,000 miles,
160 stat it's whole life.
why 160, because this is where it ET the best.,,,leaving the starting line at 160-165F, crossing at 170-175F.
and believe me it's not worn out.
Chevelle Tech > General Tech Area > Performance      Current Topic: Whats the optimal engine coolant temperature to make most HP?
Human Verification
