brake line routing - Chevelle Tech
Auto Insurance
Brakes, Suspension & Steering Conversion questions & more.
Old Sep 6th, 08, 3:07 PM
69elcoguy 69elcoguy is offline
Matt
Default brake line routing
I purchased pre-bent brake lines for my 1969 el camino and am trying to install them but they dont seem to follow the frame lines correctly. Should pre-bent lines basically bolt right up or do they still need some tweaking to them. And does any one have a picture of their frame with the lines attatched so i can see how there actually supposed to sit.
thanks
-Matt
Old Sep 6th, 08, 3:42 PM
BlueSS454 BlueSS454 is offline
Tom
Send a message via AIM to BlueSS454
Default Re: brake line routing
They shold follow the general contour of the frame, but they will need some tweaking.
Tom Rightler, MCC VP & Newsletter Editor
1970 SS Best ET: 12.31@108 MPH
1969 Malibu
1969 Dodge Charger
1970 Chevelle Convertible
Maryland Chevelle Club
Old Sep 6th, 08, 3:56 PM
furball8994 furball8994 is offline
Scott
Matt. I had to "tweek" my "pre-bent" brake lines pretty good to get them to fit to my liking...
The biggest problem was at the point where the frame bends out to the center rail (started to bend too soon, needed to straighten, then rebend), and where it comes off the frame rail and connects to the cross member over the axle (ended up pointing down instead of at the C-member).
SCOTT
TC #3238
ACES #7490
My Site
The Rebuild
To secure these rights, Governments are instituted among Men, deriving their just powers from the consent of the governed, That whenever any Form of Government becomes destructive of these ends, it is the Right of the People to alter or to abolish it, and to institute new Government
The Declaration of Independence
Old Sep 9th, 08, 3:53 PM
Matt
alright.. so I am still going to have to do some bending. Does anyone have a picture or their frame with the lines so I know how it should run?
thanks
Old Sep 9th, 08, 4:06 PM
Scott
Matt. Start by installing the block on the frame. (directly under the master cylinder) then lay out your lines. you will have two that run down from the master to the block. One short front (drivers side) one long front (pass. side and the one to the rear. You will also have a very short line that goes from the master to the (can't remember its name) little round block mounted under the master. Once you lay them out, You will see how they run.
Heres a pic of my master. Disregard the line lock. The little line runs from where the LL line comes out of the master to where the other LL line reconnects. Let me know if you need more pix and I'll run outside and get what you need.
SCOTT
TC #3238
ACES #7490
My Site
The Rebuild
  #6
Old Sep 12th, 08, 7:36 PM
Matt
Do you happen to have any pictures of where the lines connect to the block? Does the line that runs across the frame under the motor go to the block, or is supposed to go up to the booster? how its on mine it seems like it goes up to the booster.
Don't pay attention to the line on the left rail, it was backwards I switched that around.
  #7
Old Sep 12th, 08, 11:44 PM
6cylcecil 6cylcecil is offline
Cecil
Same basic issue on a 66, mine jumps too high over the right frame rail and not far out enough to land on the hose fitting. ( 2 bends to correct )
Is the stainless soft enough to work slowly with a 2" pipe nipple?
Blue sky, Black top
  #8
Old Sep 16th, 08, 4:37 PM
Matt
I have a tubing bender to bend the lines, I just need to know exactly where to bend them if anyone has a picture of their frame with the lines attached?
thanks
  #9
Old Sep 16th, 08, 10:29 PM
Matt
I got the proportioning valve, now can anyone show me where each of the lines are supposed to connect to on this?
thanks
  #10
Old Sep 16th, 08, 10:49 PM
Bryan59EC Bryan59EC is offline
Bryan
The rubber plug points to the front of the car.
Rear line "out" is opposite end.
Rear master res to the port left of the brake warning sensor.
Front res to the port on the right.
The lil rubber plug hole should go to the right front
just above it---left front
(That is how my 59 is plumbed)
Bryan's toyz
59 ElCamino 454/TKO 5spd--(daddy)
66 ElCamino 3oh7/TKO 5spd (mousey) Almost done On the street now!!!
65 Ranchero v8/4-spd, that my uncle bought new
  #11
Old Sep 17th, 08, 2:08 PM
Matt
the fitting on my rear brake line is smaller than the hole on the rear of the valve...is there an adapter that I can get to make it fit or did i some how get the wrong line (which is a prebent one) or valve? And is anything supposed to hook up to the brake warning sensor?
  #12
Old Sep 23rd, 08, 5:11 PM
Matt
Someone must have a picture of their brake lines setup on their frame... anyone?
also is this proportioning valve supposed to mount on the frame or should it be under the booster? I have seen it both ways and am very confused by this. most of my lines seem bent to go to the valve on the frame but then I would also need to get lines to run up to the booster. the line that runs across the front of frame seems like it should go right to the booster though.
any help or pictures would be really appreciated as I'm stuck and cannot figure this out
thanks
  #13
Old Sep 23rd, 08, 5:28 PM
Scott
thanks
Matt. If no one else post the pix first. I will go out and get some pic's for you right after I eat Dinner. What pix do you need?
SCOTT
TC #3238
ACES #7490
My Site
The Rebuild
  #14
Old Sep 23rd, 08, 6:09 PM
Matt
basically how the lines all connect at the valve because none of the lines I have go to the same spot so I need to see what needs to be bent where, and whether the lines should all meet somewhere on the frame or up near the booster.
thanks.
  #15
Old Sep 23rd, 08, 6:26 PM
Scott
Here ya go matt. Sorry it took so long. Photobucket decided to do site maintenance right after I uploaded them there. Your valve looks different. Mine is original. I just cleaned it up. You can even see where the clutch rod wore and rubbed it.
EDIT; Heres the photobucket link. There are a couple other angles. http://s217.photobucket.com/albums/c...8994/Assembly/
SCOTT
TC #3238
ACES #7490
My Site
The Rebuild
Chevelle Tech > Mechanical > Brakes, Suspension & Steering      Current Topic: brake line routing
Location
*REQUIRED*
Insurance
First Name
Human Verification
