| Chevelle Tech Current Topic: Spark Plug Gap - 1972 Chevelle 350, Point Type Upgraded To HEI | ||
| Register | Photo Ads | FAQ | User List | Social Groups | Calendar | Chat | Search | Today's Posts | Mark Forums Read | Insurance | Auto Loans | Auto Escrow |
| Engine |
What should the gap be? AC Delco brand new plugs. Going to gap them, but don't know to what. Asked around, I have heard things from .035 to .054. Brand new out of box. I doubt it should be at .054. I was thinking around .042 or something around there.
Haven't done this before, and I know someone on here has. Any info would be appreciated. Thanks all. 1972 Chevelle 350 - 47K original miles on motor. STOCK! |
| Sponsored Links | ||
Advertisement | ||
#2
You're correct about .0054 being too large. You were close, but most folks including myself gap plugs with an HEI at .0045
You'll be really happy with the upgrade! |
Awesome thanks! I asked on Yahoo! Answers and I have heard all those. But I will stick with what you said and see what happens. Should work out well. Thanks a lot!
Stock points was .035 so .045 is a good place to be with hei as already suggested.
scott
SCOTT 1969 CHEVELLE SS396/4SPD/M20/12BOLT/3:31'S ORIGINAL #'S MATCH/OWNED SINCE 1978. 1977 KAWASAKI KZ1000 (ORIGINAL OWNER) 1976 KAWASAKI KZ900 2006 YAMAHA 1700 ROADSTAR SILVERADO |
I was just curious, but what if you had the gap at say .035 for HEI? Does it not burn the fuel as efficiently?
Bill CarDomain Photos My Progress Pictures 396 (402) .030" over Edelbrock Performer RPM Air Gap Lunati 60203 / KB 0.180 domed pistons Holley Street Avenger 770 Muncie M-22 12 bolt posi 3.31 |
#6
I own an early Safari Van with 4.3 V6 and stock HEI, and that specification IS .035. But, with every other HEI I have, the gap is set to .045. The key is, if the compression ratio goes up, drop the gap down.
GM made a real mistake with HEI performance during their Oldsmobile years, they specified a spark plug gap of .060, and even later, .080. This was done to make sure the molecules of fuel could bet in between the plug gap, to get lit off, because the mixtures were so lean, those fuel molecules got further apart from the leanness. The gap had to be giant in order to get enough fuel molecules into it, to get the light off done. GM found that the giant gaps were killing many, many electronic components, namely coils and modules. So, the lesson learned is, stock compression ratios, .045, higher performance comp ratios, drop the gap, and don't gap your plugs larger than .045, no matter the coil, module, etc. Regards, Milton |
#7
WHAT PLUGS?
Plugs designed for a .035 gap often won't be too thrilled about being opened to .045. If you bought stock plugs, use stock gap. If you bought plugs for a newer vehicle with HEI, use the HEI gap. (preferably around .040--.045.) The ground electrode is longer, allowing the bigger gap. Yes, you can buy plugs designed for a huge gap; you don't want those. |
#8
Sorry for the hijack but I have a 1970 chevelle with a HEI and the Accel header plugs gapped to a .035 and was thinking about raaising the gap to a .045 but wasn't sure, and from what I read this would make a difference correct?
1: 1970 Chevelle SS-clone "ALMYDOE" Holley 4bbl, GMPP intake, Summit Racing Gear Drive, American Racing Rims, Flowmster Exhaust , DuPont Blue, Stock 12 Bolt w/ 2.73 no posi 2: 1987 Ford F-250, 6.9L Diesel, 2wd, B&W T-19, ported heads, straight pipe exhaust "HORSEPOWER is how fast you hit the wall, TORQUE is how far you move it "
#9
I'm using AC rapidfire #1, gapped at 0.045. I think the heat range SHOULD be a #2, but I had them, so I just put them in.
1966 El Camino 350/PG/3.07 |
#10
I've never had problems with negative electrodes when opening/closing the gap properly.
The only plugs I wouldn't re-gap are the ones preset for a specific gap, like the NGK's with the suffixes 9, .036, and 11, .044. Regards, Milton |
| Sponsored Links | |
Advertisement | |
| Display Modes | |
