Inner Fender Dust Shield Install????? - Chevelle Tech
Auto Insurance
Body Shop Paint & Body Forum
Old Aug 4th, 08, 3:41 PM
SHUVELL72 SHUVELL72 is offline
Unhappy Inner Fender Dust Shield Install?????
Has Anyone Found An Easy Way To Install Inner Fender Shields(bending Over Those Hardend Staples). Problem Is, They Are Installed On The Car. Yes I Know, Big Big Mistake!!!!!!. Any Ideas Would Be Appreciated.
Thank You.
Old Aug 4th, 08, 4:52 PM
Elviss 1971 Elviss 1971 is offline
Terry
Send a message via Yahoo to Elviss 1971
Default Re: Inner Fender Dust Shield Install?????
I have a set and I am going to remove the inner fenders and install them this winter.... It has to be easier that way.
Terry
http://s145.photobucket.com/albums/r...t=DSCN0579.jpg
"A man's got to know his limitations"
Old Aug 4th, 08, 5:14 PM
Bill Rose Bill Rose is offline
Team Member
Bill
The problem isn't the inner fender being in the car, the problem is the stiff staples. Get some stainless steel wire , the same thickness as the staples and make your own staples that will be easier to bend. Pre-drill the holes if they're new wheel wells, and you'll find the job easy. You can also use paper clips. The paper clips that are about an inch and a quarter long, have the correct wire thickness.
Old Aug 4th, 08, 5:31 PM
lev8trmn lev8trmn is offline
Bob
Send a message via AIM to lev8trmn
Taking notes for future reference Good ideas there Bill. Mine are still out on the floor, but If I forget (Like I have been doing lately) I'll have "Plan B" I have new repop inners (Steel) Is there reference dimples to where to drill the holes for mounting?
ACES #9162
"ELEVATOR" BOB "CYA-L8TR"
LEV8TRMN--"I HAVE MY UPS AND DOWNS"
72 Chevelle Restoration Project: http://community.webshots.com/user/lev8trmn
Old Aug 4th, 08, 5:35 PM
hpsherlin hpsherlin is offline
Team Member
Herbie
Is is correct that they mount from underneath the inner fenders and the staples go through the a-arm shields and then the inner fender with the staples bent over on the top side of the inner fender?
I still have to install mine.
http://www.chevelles.com/forums/pict...&pictureid=490
Herbie
'67 SS Chevelle 460"
XE284, 9.97:1, CK 2004R, 3.42 12bolt
Holley 770SA, RPM AirGap, 3200 stall
  #6
Old Aug 4th, 08, 5:55 PM
Assembly Manual Shows That They Go On The Inside, With The Staples Bent Over On The Outside Of The Liner. (wheel Side) The Paper Clips Would Be A Little Soft, Would Not Hold As Tight, As For Stainless- They Would Be As Hard As The Ones Supplied. If I Can't Figure Out Some Way To Do It I Will Probably Go With The Paper Clips. Thanks For The Help. I.o.u. All!!!!
  #7
Old Aug 4th, 08, 6:50 PM
alss alss is offline
Albert
I have done three cars with the large legal size paper clips and have had nothing even wiggle loose even a little bit. Just need to "tuck" them in when your done with the initial bend with a tool or your choice..works great! and they are nickel plated to boot!
ALbert
1969 9566AA COPO Chevelle
COPO 2
COPO motor
1969 Malibu 489 ZL-1 T 56
http://i518.photobucket.com/albums/u...DSC_0201-1.jpg
1969 Beaumont 454 ZL-1 6 spd..under construction
http://i518.photobucket.com/albums/u...DSC_0520-1.jpg
1969 300 2 door post 427 ZL-1 4 spd
http://i518.photobucket.com/albums/u...DSC_0055-1.jpg
1969 Z 28 X77 D 80 olympic gold
MCC#511 ACES #1805
  #8
Old Aug 5th, 08, 9:41 AM
rbarnes rbarnes is offline
This is correct for the plastic inner finders but the steel ones are stapled from the top like the assembly manual. I used some floral wire from a local craft store and cut and bent to the correct size and haven't had any problems with them coming loose or discoloring.
Ray Barnes
69 SS Fathom Green/Med. Green Int.
ACES #1608
  #9
Old Aug 5th, 08, 9:52 AM
oldtimebaseballfan oldtimebaseballfan is offline
Tim
Each of the assembly plants had their own way of doing it. I have seen original cars with the staples from the bottom and original cars with the staples from the top.
This is not a "one size fits all" assembly process.
Tim
ACES # 6575
MCC # 643
1970 L78, Red on Red, 4 spd
1970 LS6, Misty Turquoise on Black, 4 spd
1970 L34, Black on Black, 4 spd
  #10
Old Aug 10th, 08, 11:08 AM
Smile Re: Inner Fender Dust Shield Install?????
Problem Solved!! Used.060 Galvinized Wire(actualy Electric Fencing Wire). I Was Going To Use The Paper Clips Then I Came Across This. Worked Great.
Thanks All For Your Input.
  #11
Old Aug 11th, 08, 2:57 PM
OLDED OLDED is offline
Team Member
Ed
Do whatever these emails say to use the staples - but a good trick is to also contact cement the dust shield into place before you install the staples. It stays where you put it and makes the staple installation a snap. Just drill thru the existing staple holes in the inners and on thru the rubber, then install the staples. Don't go overboard on the glue and it can't be seen when you are finished.
OLDED - It's STOCK if it's made by GM and it fits!
*65 Elky, Gen VI 496 BBC, TH400
*59 Vette, 283/270 hp. T5 5 spd., 4:11 posi.
*Harley - 06 Street Bob
*Life Member - Team Chevelle & Team ElCamino
*Peach State Chevelle Member
*Retired June 1, 2014****
Chevelle Tech > General Tech Area > Body Shop      Current Topic: Inner Fender Dust Shield Install?????
Human Verification
