crossflow vs downflow radiators wich is best - Chevelle Tech
Auto Insurance
Heating & Cooling Heating, cooling and air conditioning
Old Jul 16th, 08, 6:18 PM
hoffa hoffa is offline
Question crossflow vs downflow radiators wich is best
I have been told crossflow radiators cool better then downflow is this true? I have a BB chev. in a 65 ss, and this car comes equiped with a down flow originally.
Old Jul 16th, 08, 8:47 PM
onovakind67 onovakind67 is offline
Default Re: crossflow vs downflow radiators wich is best
Either will cool well, but the crossflow has one distinct advantage. A crossflow radiator will allow more pressure at the radiator inlet before the cap vents because the cap is on the low pressure side of the radiator.
Cross flow radiators are superior to upright radiators because the radiator cap is positioned on the low pressure (suction) side of the system. This prevents the pressure created by a high-flow water pump from forcing coolant past the radiator cap at high RPM. As mentioned in the radiator cap section, an upright radiator should be equipped with radiator cap with the highest pressure rating recommended by the manufacturer. The system will still force coolant past the cap at sustained high RPM.
http://www.stewartcomponents.com/tec...ech_Tips_5.htm
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
Old Jul 17th, 08, 4:27 AM
ALUMITECH REPRODUCTIONS ALUMITECH REPRODUCTIONS is offline
that statement is very correct in regards to presure ...there is a myth about crossflows being superior to down flows as far as cooling .. all in all its about SQ inches of cooling surface .. as of 68 most rads went to crossflow as hood lines got shorter .. so no where to go but wider .. so more SQ inches = more cooling .. but you will see many truck rads still run down flows due to the area and hood lines being taller .. look under the hood of a
f-350 .
the vertical tubes of a down flow work well with heat convection .
just a note
64 to 67 Chevelle bb ..403 SQ inches of core .. change to a cross flow conversion 374 SQ inches of core area ... a loss of 29 sq inchs of cooling core surface area .
Don
Chevelle Tech > Mechanical > Heating & Cooling      Current Topic: crossflow vs downflow radiators wich is best
Human Verification
