LS1 Conversion - Chevelle Tech
Auto Insurance
Pro Touring Todays performance with classic style
Old Jul 8th, 08, 1:50 AM
xcessive_ss xcessive_ss is offline
Rod
Default LS1 Conversion
I'm getting ready to spend some money and I wanted to run this list past you guys who have done this swap already. I'm trying to do this in my garage so it needs to go as smooth as possible without any need of fabrication.
First of all, it's going into a 71 convertible chevelle.
LQ9 or L92 pullout motor w/ all accessories including the wiring harness
GM LH8 Oil pan and pickup
4L60E transmission
BRP mounts and trans K-member
grinded jeep steering box (for a/c compressor to fit)
Impala/Caprice gas tank - modded trunk area for pump access
Custom pre-bent 1/2" fuel line
Custom pre-bent 3/8" return line
I'm going to do alter the wiring harness myself.
The computer will be programmed on a dyno once it's running.
A couple questions.
Will I have to lift the body to install the fuel lines?? They are bent to go in the stock location.
Has anyone used shorty headers with the BRP mounts?? What will I gain by buying the edelbrock long tubes??
Am I missing any key info??
Old Jul 8th, 08, 5:38 AM
rianbechtold rianbechtold is offline
Ryan
Default Re: LS1 Conversion
Yes, the body will have to be lifted for the fuel line near the rear of the car.
IDk too much about LS swaps but you will want to look into what guys do for the cooling system unless you have that figured out already.
No SS here! Proud owner of a 1971 Malibu 454.
Updated Pic 1
Update Pic 2
Updated Pic 3
Old Jul 8th, 08, 1:47 PM
vrooom3440 vrooom3440 is offline
Steve
With respect to the body lift... it *is* possible to only lift the right side and R&R the fuel lines. You will want to loosen the left side mounts and remove the bolts from ALL right side mounts. Then you can jack up just the right side and get to the lines and that last mount on the rear frame kick up.
You may also want to check out the EFI conversion I did to a stock tank:
http://www.chevelles.com/forums/show...hlight=mu-2021
From the pictures I have seen the Impala tank fits but it's certainly not pretty.
Steve
1968 El Camino, 402 with TKO
Old Jul 8th, 08, 3:42 PM
h8tulooze1 h8tulooze1 is offline
Stacy
I was reading a lot of people are cutting off the top tabs of the tranny to clear the tunnel... LS1 Tech has info on it.
1967 Nova SS LS1
1970 El Camino SS396 L34
1965 Malibu Convertible SS
1970 Chevy SWB 4x4 BBC
Old Jul 8th, 08, 11:10 PM
thunderstruck507 thunderstruck507 is online now
Kevin
Shorty headers are worthless for anything but looking pretty. Long tubes will give you a power boost and for the price there's no reason not to go with those.
I'm in the middle of this swap. I'm not sure why you say you need to lift the body for fuel lines? I'm just going to use summit steel line and bend it myself to run along the frame where the stock line went, no return line.
You might also need:
TCC switch for torque converter
electric fans
throttle cable
transmission dipstick from lokar (theres virtually no room between the firewall and engine once its in, at least in my application
air cleaner with bends and MAF
shorten driveshaft
this is a pretty involved swap, lots of small stuff you don't think of
1971 Chevelle SS clone
head/cam ls1, 4l60e, 3.42 12 bolt
11.67@115mph, 1.71 60ft
  #6
Old Jul 9th, 08, 12:24 AM
andrewb70 andrewb70 is offline
Andrew
1/2" fuel lines are way overkill. 3/8" is plenty.
Andrew
1970 GTO Version 2.0 in progress
V8TV Feature video
Popular Hotrodding feature
Car Craft feature
1967 Cougar LSx build
"You were the gun, your voice was the trigger, your bravery was the barrel, your eyes were the bullets."
  #7
Old Jul 9th, 08, 12:45 AM
Rod
thanks everyone for your input
1/2" fuel line may be overkill but for 15 extra bucks I think it's worth it. I plan on doing some performance upgrades in the future so the extra fuel will come in handy
On the impala tanks .... I thought that if you cut the hole in your trunk it raised the tank underneath
  #8
Old Jul 9th, 08, 4:26 AM
Ryan
Near the rear of the car, on the passenger side, the fuel line goes in between the body and the frame. I've tried even which way and had to lift the body to get it through.
BTW, you said you aren't running a return, how are you planning to restrict pressure, are you going to run a dead-head regulator?
Updated Pic 1
Update Pic 2
Updated Pic 3
  #9
Old Jul 9th, 08, 12:12 PM
Kevin
corvette fuel filter with built in pressure regulator for $40 from Oreilley's that will be mounted right after my fuel pump, that way I don't have to run a return all the way to the engine, on the LS1 intake there isn't a return out like on trucks so it would need to go to a regulator somewhere down the line anyway
also don't forget:
power steering hoses, mine are differnt type than the power steering pump on the ls1
are you using a truck engine or corvette engine or fbody engine? fbody have the a/c on the pass side and alternator on the driver side, so I'm curious what you meant by trimming the steering box for clearance on that
  #10
Old Jul 10th, 08, 9:28 PM
64chevlle 64chevlle is offline
wow keep posting guys...I just bought a 03 5.3 out of a van and I am going to swap this into my 64 this winter so the more info the better..
Brian
64 chevelle frame off...383 w/scat crank ..195 AFR heads 3.73 w/ eaton posi. 12.45 @ 108.6 mph 1.80 60ft
http://www.cardomain.com/memberpage/809526 Updated 3/20/08
  #11
Old Jul 11th, 08, 12:17 PM
stealth71 stealth71 is offline
Mike
Check out the link in my sig. Lots of info there. Still not running yet though.
ACES Member
71 Chevelle - Who cares about the paint. You won't see it long anyway.
LS1/T56 swap - On the Street!!
For Sale: '71 Complete A/C PM Me
Chevelle Tech > Specialty > Pro Touring      Current Topic: LS1 Conversion
Human Verification
