For those with AFR 195 eliminator heads - Chevelle Tech
Auto Insurance
Old Jul 2nd, 08, 7:44 PM
tach tach is offline
Default For those with AFR 195 eliminator heads
I have a set of AFRs on my sb part #1034. Can someone give me the correct size for the temp sensor hole? I know the hole is 3/8" but, is it an NPT? I called AFR and they said it was a 3/8" x 18 NPS???? I went to the local parts house and they gave be the 3/8" NPT. I tried screwing that in and it will only go a few threads before it get hard to turn. If it is indeed the NPS where can I get this fitting? Thanks.
Old Jul 2nd, 08, 8:57 PM
trmnatr trmnatr is offline
Banned
Butch
Default Re: For those with AFR 195 eliminator heads
NPT, it will not screw in by hand, it should get "tight"
Use some permatex thread sealant on it
Old Jul 2nd, 08, 11:20 PM
mod since about forever, old now :)
TerribleTom II
if you have to you can run a 3/8" NPT tap into the hole. This is the same crud Dart is doing on the Big M blocks. NPS means National Pipe Straight I think. It's a cheapskate deal IMHO. It not like they don't know people are going to be screwing tapered pipe sensors in there. I had to re-tap every pipe plug holes in the Big M block I'm currently working on. A PITA for sure.
Tom
Old Jul 3rd, 08, 10:40 AM
thanks guys. Time to go back to the parts house.
Old Jul 3rd, 08, 9:03 PM
Well, I just got back from Autozone, Ace hardware, and Tractor supply with no luck of finding the Famous NPS fitting. If you guys know of a place to find this type of fitting please chime in. I hate to try and use the NPT fitting and screw up a $1400 set of heads. AFR said use a 3/8 x 18 NPS so I'm going to call a speed shop on Monday and see if they have them. Wish me luck. If anyone is using the eliminator heads and have plugged these holes please let me know what you used. thanks guys for the help.
  #6
Old Jul 3rd, 08, 10:31 PM
TerribleTom II
I don't think there is any such thing as an NPS fitting. It would leak anyway, nothing to tighten it up against or into. Call AFR and ask them to send you some non-leaking NPS fittings, see what they say. I'll bet it's not "Sure, we'll send a few right out."
GO back to the hardware store and buy a 3/8" NPT tap. Tap the holes out 2 threads at a time till whatever you're screwing in goes in as far as you want.
Tom
  #7
Old Jul 3rd, 08, 10:44 PM
TerribleTom II
Ah jeez, worse than I thought. NPS = Nominal Pipe Size, it doesn't refer to a type of thread. See http://en.wikipedia.org/wiki/Pipe_(material)
Tom
  #8
Old Jul 3rd, 08, 11:10 PM
Wolfplace Wolfplace is offline
Mike
Forget trying to find an NPS fitting, NPS is straight & has to have a washer or jam nut to seal.
NPS is the same pitch as NPT just not tapered so if it is not tapped deep or they are in fact using the NPS tap to make machining easier just take a 3/8NPT tap & chase the threads, this is not a big deal I have to do it in all Dart blocks
Annoying,, a bit but not the end of the world
Mike (Wolfplace)
VISIT US AT
+4axis CNC block machining+
Welcome to the internet,,, "Experts" made daily
"Life is tough.,, Life is even tougher if you're stupid."
----John Wayne----
  #9
Old Jul 3rd, 08, 11:45 PM
TerribleTom II
Mike,
any idea why they would be doing this? I mean why would Tony@AFR be shipping thousands of heads that you can't screw the temp sensor into? How could straight threads be that much cheaper that tapered?
Tom
  #10
Old Jul 4th, 08, 12:14 AM
Mike
Originally Posted by Tom Mobley View Post
Mike,
Hi Tom,
I do not know for a fact they are using an NPS tap but the reason it would be used in CNC work is they are easier to control
You do not end up with a too deep NPT taper which is much worse than too shallow, really sucks to fix a too big hole
As you know Dart does it & it is a pain in the ass if you don't know about it ahead of time
Really sucks to find out after the short block is assembled that you have to retap all the pipe threads,,,
Mike (Wolfplace)
VISIT US AT
----John Wayne----
  #11
Old Jul 4th, 08, 8:37 AM
tgw323 tgw323 is offline
Any recent CNC machine, which with their recent expansion they should have,uses rigid tapping. This means the tap is solidly mounted in its holder like a drill, unlike previously, where a spring loaded holder was used to prevent breakage. This means that they should be able to control the depth to thousandths of an inch. In aluminum, a good tap should last hundreds of holes. This means that they are just transferring a PITA down the line, a practice all too common in the speed industry.
  #12
Old Jul 4th, 08, 12:13 PM
the heads are on the motor and it has been primed and is ready to go in. Heck it's attached to the tranny and on the cherry picker ready to go. Could I tap it as is or would I need to take the heads off. I'm thinking about just putting some teflon tape on the NPT fitting and running it in there a few threads and calling it good. What do you guys think?
  #13
Old Jul 4th, 08, 12:44 PM
Mike
People are making to big of a deal out of this
How many threads does your fitting screw in by hand or with light pressure?
Yes, if necessary you can just run a tap into the hole with no issues what so ever, you are not taking enough metal out to hurt anything but if you put some grease on the tap & almost all of the metal cut will stick to & come out with the tap if you are concerned.
Clean the hole & you are done
This is really an easy fix assuming a fix is necessary
Mike (Wolfplace)
VISIT US AT
----John Wayne----
  #14
Old Jul 4th, 08, 12:47 PM
blumont blumont is offline
Team Member
Jerry
Heck, I just put a bit of sealer on the plugs and screwed them in. They don't sit quite flush but they are fine and don't leak.
Jerry
65 Beaumont
496ci, Afr 290 ovals
Wolfplace forged rotating assembly
Cstraub hydr.roller
PS 1000HP
TKO 600, 3:73's
http://www.chevelles.com/showroom/da...e_Rims_014.jpg
  #15
Old Jul 4th, 08, 12:48 PM
3V Performance 3V Performance is offline
Tom
Mike, how does it go....
you can lead a horse to water but you cant make him drink......
Tom
ENGINES WITH AN ATTITUDE
704-966-1030
www.3vperformance.com
You may not post new threads
You may not post replies
