Long vs. short water pump on big block 454 - Chevelle Tech
Auto Insurance
Old Jun 18th, 08, 10:37 AM
keetes keetes is offline
Bob
Cool Long vs. short water pump on big block 454
Hey Folks,
I have no idea if I have a long water pump or a short one. What's the easiest or best way to distiguish the difference? I'm in need of an altenator bracket for some pulleys I ordered over two years ago. I'd check the invoice of that order but it was an online order and hence the info is now gone.
Thanks,
Bob
1970 SS hotrodded
12 bolt, 4:11 Eaton posi rear
M-20 4 speed with Lakewood scattershield
454 400HP, 500 FT LBS torque
Smoothed firewall, Dynomax ceramic coated headers
4 inch fiberglass hood
Aluminum radiator w/twin electric fans
Aluminum "Black Mountain Precision" pulleys with 2inch cog belt
1 fine lady sitting shotgun
Old Jun 18th, 08, 10:50 AM
dreis454 dreis454 is offline
Dan
Default Re: Long vs. short water pump on big block 454
A long pump will have some space between it & the timing chain cover (enough to put your fingers between)
a short WP will not
72 ss 454 "W" code,w/cowl induction (how many left?)
matching # LS5 454+.060" 9.2 :1, 2.19/1.88 valves,Comp HR cam 289/295 234/240 .613/.613 110* (dyno'd @ 557hp @ 5400 & 583tq @ 4100)
matching # M22 w/CF dual friction clutch.
Holley 750 HPs dp(82751) on Weiand Stealth & MSD Pro billet HEI
Hedman Elite headers/Flowmaster exh. (w/super 40s)
TC#3095
Garage find parked from 1978-2004
http://macswebs.com/ls5registry/bal/bal.htm
http://www.chevelles.com/showroom/sh...0&ppuser=25834
http://ssregistry.macswebs.com/1972/1d37w2b_reis.htm
http://www.youtube.com/watch?v=YqZkVw6xMkM
Old Jun 18th, 08, 10:51 AM
kettbo kettbo is offline
George
about a 95% chance you have a long water pump.
As far as I know, only the 70-74 454 Vette and some trucks had the short water pump.
How to ID?
the short waterpump's backside is nearly touching the timing cover
long waterpump has a gap of approximately .60"...you can get the end of your finger between the timing cover and the back of the WP
George Kettler
o 70 Elky 496 build continues #074 AL heads
$2000 low buck 454 is broken, ran well for a 3995# all-up wt.
1.631 11.727 113.37 91.47 midtrack 1.647 11.729 113.49 91.58 mph mid track
Bests 1.620 60 ft 91.60 best mph
o 68 Vette 427/M-20/3.36 23 year owner
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
George
dammit Dave, you barely beat me to the punch!
Edit:
DAN, DAN, DAN, DAN, DAN, DAN, DAN, DAN, DAN, DAN, DAN, DAN, DAN, DAN, DAN, DAN, DAN, DAN,
George Kettler
Old Jun 18th, 08, 10:52 AM
Dan
Ummmm its DAN!
& I had you by a whole minute!
sleepin @ the tree again eh?
TC#3095
  #6
Old Jun 18th, 08, 10:53 AM
gibbons gibbons is offline
Didn't 68 and down big blocks have shorts? I had to get a long pump to used a March pulley system.
68 SS front, 68 SS rear
zz502 and Hydroboost, Underside TKO,
Short stick console
YouTube video
I'm not a car guy but did all the mech/elec work... and everything started with a dumb question
  #7
Old Jun 18th, 08, 10:54 AM
George
Dammit Dan, I know that!
Maybe too much coffee this morning...will fix my errors AND knock out some push-ups
George Kettler
  #8
SWHEATON SWHEATON is offline
Team Member
Smile Re: Long vs. short water pump on big block 454
Since You Have A 70 Chevelle In Your Sig and you stated you recently Ordered The W/pump For your 70 Chevelle BBC It Will Automatically Be by application A Long Pump because the bbc Used The Long Pumps From 69 & Up In Full Size Pass Cars.
Scott
SCOTT
1969 CHEVELLE SS396,ORIGINAL #'S MATCH,GOT IN 1978,(In 2001 rblt/bored original 396 .030 to 402)/M20/12BOLT/3:31'S
2006 YAMAHA 1700 ROADSTAR SILVERADO (1 owner ,GOT in 2009,4,700 miles/WK end fun)
1977 KAWASAKI KZ1000 (AM ORIGINAL OWNER ,GOT IN 1977,NOW has 29k miles/WK end fun)
2002 MAXIMA (DAILY DRIVER/1 owner,GOT 3/2013 w-44k miles)
  #9
Old Jun 18th, 08, 10:55 AM
Dan
yes, but who knows whats been changed in the last 38 years.
TC#3095
  #10
Old Jun 18th, 08, 10:58 AM
George
yes Gibbons, you are correct.
The question was 454 so 1970 SS hotrodded in posters info is what were're going by
and as you know, 1st 454 was in the 70 model
George Kettler
  #11
Old Jun 18th, 08, 11:06 AM
cheveezies cheveezies is offline
tommy
if the backing plate nearly touches the timing chain cover , it's a short water pump . if their's a larger space , roughly big enough to slide your hand in between the timing chain cover and water pump , it's a long water pump .
  #12
Old Jun 18th, 08, 9:54 PM
Bob
Wow I'm impressed by all the responses. There is a gap between timing cover and water pump. The 454 I'm using is from a 1978 truck for those who were wondering. Thank you for all your help. You've made my day.
Bob
1970 SS hotrodded
Chevelle Tech > Mechanical > Engine      Current Topic: Long vs. short water pump on big block 454
Location
*REQUIRED*
Insurance
First Name
Human Verification
