th400 transbrake install - Chevelle Tech
Auto Insurance
Old May 28th, 08, 12:37 PM
10secBu 10secBu is offline
Default th400 transbrake install
We had our second MSRA race on Memorial Day and as soon as I got home, the car was on the stands to be ready to take the trans out.
The trans is now out and on the bench and I've begun the install process.
I've never worked on a th400 internally before, so I'm learning as I go. It's not near as bad to work on as I had thought all these years. I'm enjoying learning how to work on is as I intend to try and be able to maintence the transmission from here on out.
Anyway, all the parts came in and I should be able to button the trans up in about 2 hours or so.
I won't make it to test this weekend, but may try for the following.
Parts used during the install are:
- Griner Pro Start trans brake (internal solenoid)
- ATI forget/billet forward clutch hub
- ATI gasket/seal kit
- PTC 8" converter
- MSD 8735 3 step "Launch Control"
- Biondo "Double O" button
Old May 28th, 08, 12:55 PM
496malibu 496malibu is offline
Default Re: th400 transbrake install
i think its cool to take on a new challenge. hopefully the new converter will work out for you. Im using PTC and its been good to me so far.
http://i163.photobucket.com/albums/t...t/IMG_2095.jpg
68 chevelle 355 12.67@107
78 malibu 454 on E-85 9.79@ 131
http://i163.photobucket.com/albums/t...t/IMG_3115.jpg
Old May 28th, 08, 1:01 PM
trmnatr trmnatr is offline
Banned
Butch
They will probally have you set the clutch pack clearance up at .055"-.070"
Old May 28th, 08, 1:12 PM
JOHN WILSON JOHN WILSON is offline
Clueless TnTr
Send a message via AIM to JOHN WILSON
Say, where can I get me some of those nifty BettyCrocker parts containers?
Looks good, Todd!
Again..........more clutter please.
Old May 28th, 08, 7:44 PM
kirkwoodken kirkwoodken is offline
Ken
Here is a link to Jakeshoe's excellent rebuild article. Replace anything that is worn and blow everything off with the air nozzle before you put it in. You can put the pump together without the giant hose clamp, but having one makes it easier. With a TB, you will be throwing a lot of parts in the "save-for-future-projects" bin.
kirkwoodken
406 SB, Original Bill Thomas '63 Rochester FI
AFR 210, Lunati 501C2LUN, 255/263@.050", .628"
10:1, TH400, 3.31's, 4400 SS
"Life is too short to not run a solid roller cam."
"Nothing is impossible; if you don't know what you're talking about."
Kirkwoodken
  #6
Old May 28th, 08, 11:21 PM
  #7
Old May 28th, 08, 11:26 PM
Banned
Butch
Originally Posted by 10secBu View Post
Get the wheelie bars on order
Whats that transbrake run now, about $650 ?
  #8
No full rebuild this time around. This was basically a valve body swap and looking at the direct drum to see if the mods needed for the t-brake were done or not. The .063" bleed hole was already there, so I just installed the 16 heavy return springs and checked the clutch pack clearances. I also replaced the direct drum seals since I took the piston out.
Clutches and steels looked pretty darn good for 250+ passes, so for now it's going back together as is.
Over the winter I'll do a more in depth freshening, but for now I just wanted to get my feet wet so to speak.
Only parts thrown away were some seals, old softer return springs and the previous ATI reverse manual valve body. No other parts were removed/deleted as the ATI rev/man was setup identical to the Griner brake in terms of no case mods, intermediate band/servo deleted and rear servo accumulator seals deleted.
  #9
Old May 28th, 08, 11:28 PM
From ATI it's $749
I found it online for $595 + shipping, so total was $620.
When I spoke with Steve Griner a few years ago, this brake was $550 direct from him.
Car has had wheelie bars on since last fall. Looks like I may never be able to take them off.
  #10
Old May 28th, 08, 11:32 PM
Banned
Butch
From ATI it's $749
I think ATI is higher for us local guys
Did you run or replace the steel sealing rings with Teflon sealing rings ?
  #11
Old May 28th, 08, 11:33 PM
trans already had teflon rings. I got a seal gasket kit from ATI to have here while I was working on it and they give stinking steel rings with their kits.
  #12
Old May 28th, 08, 11:40 PM
Banned
Butch
Steel rings will allow the groove to blow apart in a failure, teflon rings will not
ATI is ATI and will always be ATI
  #13
Old May 29th, 08, 5:23 AM
BillyGman BillyGman is offline
hmmm....and here I was thinking that all trans brakes used an external solenoid. .....so here I am once again learning from Team Chevelle. Thanks Todd for sharing.
70 Chevelle SS clone (632 CI powered).
  #14
Old May 29th, 08, 8:17 AM
blue66 blue66 is offline
Brian Gooding
Nope, and some are actually a brake on the rear of the trans. Kind of like the parking brakes on some big trucks.
Looks good Todd!
I built myself a fixture for holding the trans, it is similiar to the Kentmoore piece a big "C" that goes into the case lugs, then I can hang it on my engine stand. If your gonna be tearing into this thing here and there it's worth buying or building one.
Here's a link to one on ebay.......I just built mine. Cheaper
http://cgi.ebay.com/ebaymotors/_Auto...m270240957236&
66 Chevelle SS
496ci, Pump gas, no dominator, no spool, no electric fuel pump, no electric water pump, no big tires, full interior. N/A.
1.37
6.21 @ 109.7
9.82 @ 134.9
9.87 pass/grudge match http://youtu.be/Au6Lq7rH9Ak
"Keep your hopes up and your pedal down"....Rowdy
  #15
Old May 29th, 08, 8:18 AM
bracketchev1221 bracketchev1221 is offline
Nope some companies have internal t-400 brakes. I had one in my old trans, but the Trans Specialties one has an external. I like the external because it's easier to know if it's working, I can hear it clicking from inside the car.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
Best pass so far 9.039 at 148.10, 1.266 60'
Chevelle Tech > General Tech Area > Performance      Current Topic: th400 transbrake install
Human Verification
