| Chevelle Tech Current Topic: Correct turbo 400 vacuum line routing at intake | ||
| Register | Photo Ads | Blogs | FAQ | User List | Social Groups | Calendar | Chat | Search | Today's Posts | Mark Forums Read |
| Restoration Corner Where originality comes first. |
I am restoring a 1970 SS L34/M40 car and I have a question about the proper routing of the steel vacuum line that goes from the intake to the vacuum modulator. I am not sure which port it should connect to on the intake. My car is equipped with power disc brakes, cowl induction, and A/T so it has three ports on the intake fitting. I figured the pointed end of the line was suppose to fit inside the intake fitting but when I do this the air cleaner crankcase breather elbow hits on it and won't let the air cleaner seat properly.
If someone could post a picture of the correct vacuum line orientation on the intake for a 1970 L34/M40 car that would be great. The vacuum line I am using is not the original because the original line broke at the bracket that attached it to the trans and I threw it away many years ago (DA) but I purchased a used one and it was suppose to be taken off of a 70 SS. I looked in the assembly manual but it doesn't show a good picture. I could post a picture of mine but I am not sure how to do it. Thanks for your help! Mark |
| Sponsored Links | |
Advertisement | |
#2
Mark,pm sent..hope it helps
Some of my cars: 1970 SS454 LS6 12.55@108 MPH w/3.31 gears thru the exhaust 1972 Buick GS 455 convertible I'd post a picture of my 87 Grand National,but they all look the same.. |
This is the fitting you need (Unless you have A/C too)
http://www.ss396.com/mm5/merchant.mv...NEDETAILINGIGN
Owner of Daves' Restoration, The cure for the common hoopty. ![]() 99 GMC Sierra C2500 Trailer puller 00 24' Haulmark enclosed trailer 01 GMC Sierra SLE 06 Cobalt LTZ Wow, I'm down to 3 vehicles.... Wanted-1976 Nova SS. |
Does anyone have a picture of the vacuum modulator tube where it connects to the intake manifold fitting on a 70SS with cowl induction?
| Display Modes | |
