Old May 24th, 08, 9:55 PM
85shorty496 85shorty496 is offline
Brad
Default Advice for a first time t-brake user?
Just hooked up the t-brake on my th400 last night and am going racing tomorrow. Any advice for a rookie you guys want to pass on? I read up on some threads and wired in a inline switch so it can't engage on the street with the switch turned off. I've heard that the brake won't engage in anything other than 1st on GM trannies. Any truth to that? I have the button on the t-handle of my B&M megashifter so I'll have to make a concious effort to keep my thumb away from the button during my run until I devise a way to mount it on my steering wheel.
1985 GMC shortbox
496/th400
13.68 at 100.2 w/454 ci
12.31 at 111 w/ 496
1.70 60 ft
www.cardomain.com/ride/330832
" Old Chevys never die, they just go faster!"
  #2
Old May 25th, 08, 12:10 AM
trmnatr trmnatr is offline
Butch
Default Re: Advice for a first time t-brake user?
You are correct, low gear only
When you let go of the button move your hand up in the air until shift time, It will take 12 passes to get the feel to get the leave good, You will be like WTH is it not going when im on the gas, your head will then say "let go of the BUTTON"
What tree, a pro tree or a .4 or what? Pro brake? What brake did you get?
1970 Chevelle, 331cid
1980 Camaro, 408cid (all 200hp )
Old May 25th, 08, 12:17 AM
Butch
If your not racing on a pro tree try this first
** pre stage
** stage push button and deck engine on chip
release trans brake button here
Hopefully your gone with a .010-.015
If you redlight doing this i suggest the following
** pre stage
** stage in between stage and first yellow deck engine on chip
your gone with a .010-.015 hopefully
If your using a pro tree brack release the trans brake button on the last yellow for starter and your R/T will tell you where to go from there - All this information is without a delay box
Old May 25th, 08, 12:28 AM
blue66 blue66 is offline
Brian Gooding
I will redlight if I leave any earlier than a brightly lit, 3rd yellow.
And it is a standard release, not pro-tree brake.
Have fun, you might become addicted........
66 Chevelle SS
496ci, Pump gas, no dominator, no spool, no electric fuel pump, no electric water pump, no big tires, full interior.
N/A
6.27 @ 109.0
9.92 @ 133.3
"Keep your hopes up and your pedal down"....Rowdy
TC showroom
http://www.chevelles.com/showroom/sh.../22028/cat/500
Old May 25th, 08, 12:32 AM
Butch
Dang Brian, Do you have a std button? When we leave on the middle buld we are a .520ish R/T with a bracket brake, that is on a .5 tree
  #6
Old May 25th, 08, 12:37 AM
Brian Gooding
I use the button on the shifter handle of the Cheetah SCS shifter. I have a switch and use the same button for linelock and transbrake.
No "actual" t-brake button.
66 Chevelle SS
N/A
6.27 @ 109.0
9.92 @ 133.3
TC showroom
  #7
Old May 25th, 08, 4:54 AM
Brad
.500 tree, JW tranny + brake. just tried it out before I loaded on the trailer tonite. The converter flashes to 3400-3500 instead of 2800-3200 like I ordered before I knew what I was doing, so I won't have to get it loosened after all. thanks for the help Butch and Brian. I'll let you guys know how I made out tomorrow night.
1985 GMC shortbox
496/th400
12.31 at 111 w/ 496
1.70 60 ft
  #8
Old May 25th, 08, 12:18 PM
winmon winmon is offline
Dave
Oh ya, for sure... You will love the launch! You might also want to put on a 2 Step set up. That way you can pay attention only to the tree and not have to also be trying to watch the tach.
'56 210 Post
502, AFR 305's, Straub spec'd Solid Roller Cam, 10.5-1 CR, N/A, Pump Gas
60' - 1.49
1/8 - 6.83 @ 100mph
1/4 - 10.73 @ 124
See my pics here..
http://s994.photobucket.com/albums/af65/Winmon1/
http://www.picturetrail.com/winmon
  #9
Old May 25th, 08, 12:22 PM
Brian Gooding
Or you just push the button and put your foot to the floor with no 2-step like I do
66 Chevelle SS
N/A
6.27 @ 109.0
9.92 @ 133.3
TC showroom
  #10
Old May 25th, 08, 1:44 PM
ricks_67 ricks_67 is offline
Team Member
Send a message via AIM to ricks_67
interesting video first time t-brake user. very expensive. vette on bumper
http://videos.streetfire.net/video/C...PER_162983.htm
  #11
Old May 25th, 08, 2:49 PM
FourEightyNine FourEightyNine is offline
Team Member
Brian
Send a message via AIM to FourEightyNine
Tighten your seatbelt all the way down. I tweaked my back the first time using it. And that was only with 1.60 60fts.
By the way I leave off the bottom amber coming on, and usually go about 20 red. I have the button on a little box mounted on the floor behind the shifter.
  #12
Old May 25th, 08, 6:26 PM
rustbucket79 rustbucket79 is offline
Doug
With a 3500 stall there is no need for a 2 step. If it was 5500+, that's a different story.
Deliberately push your head back against the head rest as you are staging, the last thing you want is whiplash from holding your head forward and having inertia and a heavy helmet snap your head back on the launch.
www.carsengines.ca
  #13
Old May 25th, 08, 6:48 PM
_Bear_ _Bear_ is offline
You are going to be so adicted LOL. You need on of these next year. Let us know how you make out. I am on the chip at 5500 and flash to 6500 on launch, what a rush.
1970 Chevelle street car, 454ci, Turbo 400
1972 Camaro Drag car "Mid-Life Crises", Alcohol injected 383ci , turbo 400
Pics of all my toys
You may not post new threads
You may not post replies
