Lifter Clatter After Warm Up - Chevelle Tech
Auto Insurance
Old May 10th, 08, 12:31 PM
smitty454 smitty454 is offline
Default Lifter Clatter After Warm Up
Hi everyone. I went out to work on the chevelle today and noticed that after the engine warms up a bit I start getting a clatter in the valvetrain from both sides, but it only starts after the engine has been warmed up for a couple of minutes. Its a new engine I built myself, doesnt have any miles on it. It runs great, sounds smooth, great oil pressure. It has rhoads lifters which ive been told are noisy but I dont think that they are supposed to be this noisy. I also have pro comp 1.7 roller rockers, and a hydrallic comp cams XE 274 552 int 555 ex. Any suggestions would be great thanks.
Old May 10th, 08, 12:37 PM
Kevin R Kevin R is offline
Default Re: Lifter Clatter After Warm Up
Its just a noisy cam. I had the XE 274 in my 396 and had the same noise.
Old May 10th, 08, 2:50 PM
SWHEATON SWHEATON is offline
Team Member
Smile Re: Lifter Clatter After Warm Up
Rhoads lifters are ALWAYS NOISEY BY DESIGN after the motor/oil warms up .
That's becasue they have faster bleed rates to lower the cam duration/lift a little at idle & lower engine speed,then as rpm increase the higher oil pressure overcomes the faster bleed rate and then the full duration/lift is restoerd fr full perfornamce.
These fast bleed/variable duration lifters are designed to be used in motors with lrg cams so they bleed down a little at idle & lower engine speeds when oil pressure is lower (esp when hot) to effectively lower duration a few deg to smooth out the motor some & increase the int vacuum a little too.
If your running lighter oil like 10w-30 in the new motor you could try some 15w-40 chevron delo or even Valvoline VR1 or NSL 20w-50 if the motor has clearances to handle the thcker 20w-50 oil and sometimes that will quiet the fast beeld lifters down a little bit but dont expect miriclas,they are noisy lifters even with heavier oil.
But as already stated an aggresive cam lobe profile can aslo add to your noisey valvetrain making it even worse.
Scott
SCOTT
1969 CHEVELLE SS396,ORIGINAL #'S MATCH,GOT IN 1978,(In 2001 rblt/bored original 396 .030 to 402)/M20/12BOLT/3:31'S
2006 YAMAHA 1700 ROADSTAR SILVERADO (1 owner ,GOT in 2009,4,700 miles/WK end fun)
1977 KAWASAKI KZ1000 (AM ORIGINAL OWNER ,GOT IN 1977,NOW has 29k miles/WK end fun)
2002 MAXIMA (DAILY DRIVER/1 owner,GOT 3/2013 w-44k miles)
Old May 10th, 08, 5:41 PM
John D John D is offline
Team Member
John
2nd that! I've been running Rhoads in my 383 for 15 years now... and yes, after it's warm it sounds like a mech. flat tappet cam is in the thing. I don't know how many times I've 2nd guessed myself on valve adjustment with these things! If you've followed the correct adjustment procedure just leave 'em alone... they clack.
'65 El Camino - LT1/4L60e
Member - Northstar Chevelle Club
Northstar Chevelle Forum
"Think you used enough dynamite there Butch??"
Old May 11th, 08, 3:55 AM
Thanks for the replies. I took the chevelle for its first cruise tonight and it ran great. Drove it around for a couple of hours with no problems!
  #6
Old May 11th, 08, 1:46 PM
Hi-po SS 454 Hi-po SS 454 is offline
Richy Rich
Send a message via AIM to Hi-po SS 454
I noticed the same noise after installing Comp pro magnum roller rockers, its like a solid lifter type noise.
Readjusted lifters many times to be sure. Still there, and many WOT miles have passed.
Rich
71 SS MJ 468" 570 HP 608 Torque Hyd Roller M22W (autogear) Muncie 4 sp 12B 3.55 posi...
76 trans Am
01 HD Deuce
My Showroom
Walk around vid:
https://www.youtube.com/watch?v=VzkB7RTVDUc
  #7
Old May 13th, 08, 10:07 AM
Richy Rich
Yes Really !!!!!!!!!!
Rich
76 trans Am
01 HD Deuce
My Showroom
Walk around vid:
  #8
Old May 13th, 08, 12:38 PM
gibbons gibbons is offline
Yup, Rhodes lifters are noisey. I think they sound cool. And they work. I have a 248/238 cam in my car. When I have to do emissions testing, I go from the 20w50 oil to 10w30 to bleed faster, which reduces the cam overlap. It passes! There's no way with the 20w50.
68 SS front, 68 SS rear
zz502 and Hydroboost, Underside TKO,
Short stick console
YouTube video
I'm not a car guy but did all the mech/elec work... and everything started with a dumb question
Chevelle Tech > Mechanical > Engine      Current Topic: Lifter Clatter After Warm Up
Location
*REQUIRED*
Insurance
First Name
Human Verification
