72 402 Block With 3999289 Casting # ????? - Chevelle Tech
Auto Insurance
Tag Team De-coding cowl tags and vin numbers.
Old May 6th, 08, 9:27 PM
supersport6667 supersport6667 is offline
Default 72 402 Block With 3999289 Casting # ?????
Just bought a 1972 454 block, casting # 3999289. The guy told me it was a 402 and gave me the casting # 3999289 (72-75 454), not the 1972 402 casting # 3999290. I got there looked at the casting# 3999289, then the date JUNE-72, then looked at bottom side it was cleared for 4" 454 crank, looked at the deck and it was stamped CTB 402 240HP, I then miced the block, the guy said he just bored it .030 over and the bore was 4.155 a .030 over 402 bore. Has anyone ever seen a 454 block with a 402 4.125 bore?????
67 Chevelle SS Marina Blue, Canadian 66 MalibuSS 396 (middle of resto), 66 Malibu (soon to be SS 375HP clone), 67SS Royal Plum survior
Old May 7th, 08, 10:41 AM
DaleM DaleM is offline
Gold Founding Member
Dale
Default Re: 72 402 Block With 3999289 Casting # ?????
Bore definitely too small for a 454. Maybe Tonawanda just used a 454 casting and bored it for a 402 application. Apparently the suffix code bears this out. Odd...
TC Gold #92 ~ August 1998
* Ever stop to think, and forget to start again?
* ChevelleStuff - Decoding info for 64-72 (For Sale)
* 1966/1967 Chevelle Reference CD/1970 Build Sheet Decoder CD
* Chevelle Registeries
* Build Sheet Data Collection
Old May 8th, 08, 7:21 AM
arkitekt1 arkitekt1 is offline
Team Member
John
My '69 SS has a 454 block with the 3999289 casting number. It is bored .030 over.
Where on your block did you find the JUNE 72?
John
'69 Chevelle SS, Olympic Gold/Black
TC #3666
ACES #7801
Chevelle Club of Michigan
Old May 8th, 08, 9:53 AM
WILD72 WILD72 is offline
You must nave a 402 and not a 454...
CTB = 402
CTB 1972 396 240 Camaro LS-3 AR
CTB 1972 402 240 Camaro LS-3 AR
CTB 1972 402 240 Chevelle LS-3 AR
CTB 1972 402 210 Chevrolet LS-3 AR
CTB 1972 396 210 Chevrolet LS-3 AR
CTB 1972 396 240 Chevelle LS-3 AR
Old May 8th, 08, 9:58 PM
Dave Birdwell Dave Birdwell is offline
Chevelle Doctor
Send a message via ICQ to Dave Birdwell Send a message via Yahoo to Dave Birdwell
Bore it another tenth and make it a 454!
Owner of Daves' Restoration, The cure for the common hoopty.
70 Chevelle L78/M21
00 Chevy Silverado 1500 4x4
06 Equinox
Wanted-1976 Nova SS.
  #6
Old May 9th, 08, 11:11 PM
The block is a 454 block according to the casting number, but it left tonawanda as a 1972 402 or it wouldnt have been stamped with the CTB code and the block has a vin # on the deck. The guy I got it from said it was STD bore (4.125) when he got it and he rough bored it to 4.150. Its just odd they used the #289 casting block for the 402 instead of the correct #290 casting block. The casting date is on pass side backside of block. If this block left the plant this way I'm sure there were others. Imagine having an original 69 396SS chevelle with a #512 block instead of a #272 block, would have a hard time trying to prove block wasnt a restamp.
  #7
Old May 12th, 08, 6:58 PM
Diamond Judge1 Diamond Judge1 is offline
Jeff
This is not the first time I have run into engines with casting numbers that were built as something other than their intended purpose. Friend of mine has a 71 #512 block that is also 402 standard bore and a 402 Suffix code. Oviously a factory mistake, anomoly, whatever word you want to call it, but it did happen. Also goes back to the fact that casting numbers were really only used to identify parts before they were machined. Afterwards, they were ID'd by the production stamp or part number of the part. Casting number is now no longer used by them as a reference, since it can be machined different ways i.e.... Can be made into a 2- bolt, or 4-bolt block. Casting numbers are a great reference for us to use, but the part must always be checked to see if it was machined to that application, or used for something different.
Jeff Dotterer
Dated Components
Diamond Restored Judge
  #8
Old May 12th, 08, 7:56 PM
Team Member
John
The big block ID list on nastyz28.com shows 3999290 as a '72 402. Could it be the block was stamped incorrectly?
John
TC #3666
ACES #7801
  #9
Old May 12th, 08, 11:39 PM
Block is a 454 block, it just wasnt bored 4.250 from factory it started life at 4.125. I am going to bore block again to 4.250 as I have some std 454 pistons been wanting to use for sometime and dont really feel the block as any collector value.........
Chevelle Tech > General Tech Area > Tag Team      Current Topic: 72 402 Block With 3999289 Casting # ?????
Location
*REQUIRED*
Insurance
First Name
Human Verification
