BBC both cam/crank gear timing marks at 12:00, correct? - Chevelle Tech
Auto Insurance
Old Apr 19th, 08, 2:11 AM
SUNOCO70 SUNOCO70 is offline
Pat
Default BBC both cam/crank gear timing marks at 12:00, correct?
Hi I just joined this great group, I am just getting back into the street machine scene after 15 years (kids) anyway I just purchased a 427 long block on Ebay and I am going to swap out the Elgin mystery cam for a #60204 Lunati Voodoo, the current cam and crankshaft gears timing installation dots are both at the up 12:00 position, is this correct? do I install the Lunati cam the same way? having replaced a bbc cam in the early 80"s I thought it was 12:00 crank gear dot and 6:00 cam gear dot facing each other, thanks its been a while!
Old Apr 19th, 08, 3:30 AM
nakamura_racing_sports nakamura_racing_sports is offline
Default Re: BBC both cam/crank gear timing marks at 12:00, correct?
It really doesn't matter until you want to put the distributor in. If you turn it over to get the cam gear to 6, the crank gear should be at 12 if they are both dead on at 12 now. Cam gear revolves once for every 2 revolutions of the crank gear. I would just get it to 6 and 12, then set in your distributor where you want it.
Jay Nakamura
Race Cause You Love It
Amsoil Authorized Dealer
Check out my website: http://www.synthetic-oil-tech.com/1483414
1970 Chevelle "Green Bean"
Http://www.nakamuraracingsports.com
Old Apr 19th, 08, 12:10 PM
Wolfplace Wolfplace is offline
Mike
Much easier to line up if they are at 6 & 12 as they are together
In this position you are on #6 firing, #1 overlap
One turn of the crank puts you at #1 firing with the dots at 12 & 12
Mike (Wolfplace)
VISIT US AT
+4axis CNC block machining+
Welcome to the internet,,, "Experts" made daily
"Life is tough.,, Life is even tougher if you're stupid."
----John Wayne----
Old Apr 19th, 08, 1:50 PM
Pat
Thanks for the answers, very much appreciated!!!!
Old Apr 19th, 08, 4:56 PM
Kevin R Kevin R is offline
Mike is correct Yep this gets messed up all the time.
  #6
Old Apr 19th, 08, 7:55 PM
Pat
Thanks Kevin, pretty basic stuff that I could not find out with a Google search, also Kevin your photobucket video helped me decide which cam to run (besides the specs which were perfect for my motor) it really has a great sound!!!!
  #7
Old Apr 19th, 08, 7:58 PM
Augustboy2009 Augustboy2009 is offline
Good choice on cam. I like mine now with the proper springs and pressures!
Chevelle Tech > Mechanical > Engine      Current Topic: BBC both cam/crank gear timing marks at 12:00, correct?
Human Verification
