Tie Rods vs Sway Bar - Chevelle Tech
Auto Insurance
Pro Touring Todays performance with classic style
Old Apr 12th, 08, 6:06 PM
Yelcamino Yelcamino is offline
Herb
Default Tie Rods vs Sway Bar
I finally got around to installing the front sway bar on the Chevelle and I ran into a little problem... the sway bar is hitting the outer tie rods.
I thought I had plenty of ground clearance but apparently my car sits too low with the SPC LCA's and shorter coil springs.
Have any of you run into this issue? I guess I'm going to have to get a new set of front coils to raise it up some. So much for the perfect stance!
Herb
ridetech Shock Specialist
herb@ridetech.com
1966 El Camino
1966 Chevelle
1963 C10
PHR CHP CHP Youtube
Old Apr 13th, 08, 12:56 AM
Chevello Chevello is offline
KeithD
Default Re: Tie Rods vs Sway Bar
Looks to me like you just need longer end links.
K
"You laugh because I am different. I laugh because you are all the same."
72 Chevelle, Aluminum 5.3 LM4 Complete for UNDER $3k
http://www.chevelles.com/forums/album.php?albumid=1002
http://www.chevelles.com/forums/showthread.php?t=622242
Old Apr 13th, 08, 10:25 AM
BillsCamino BillsCamino is offline
Gold Founding Member
"Wild Bill"
Send a message via AIM to BillsCamino
I've run into this before.
The caster needs to be set correctly...too negative...get an alignment.
1972 GMC Sprint
^^^ On my "To Do" list for heart transplant
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
Old Apr 13th, 08, 11:19 AM
Herb
I definately need an alignment. I didn't want to have that done if I was going to have to get taller springs and end up having to align it again.
K
I'll get the alignment done first and see if longer links are still needed.
Thanks.
Herb
herb@ridetech.com
1966 El Camino
1966 Chevelle
1963 C10
PHR CHP CHP Youtube
Old Apr 13th, 08, 1:06 PM
clean7t clean7t is offline
Tom
Send a message via Yahoo to clean7t
Herb it looks like and alighnment and slightly longer links should take care of your issue.
70 Chevelle 406/700R4
69 Camaro SS
71 Nomad Wagon 250 ci.
  #6
Old Apr 13th, 08, 1:57 PM
Smittie Smittie is offline
Gary
Beautiful though!!
69 Chevelle Triple Black
http://i118.photobucket.com/albums/o...ps0210c6ca.jpg
  #7
Old Apr 14th, 08, 2:07 PM
Gokou Gokou is offline
Troy
Actually Bill, more negative caster tips the spindle past vertical and more towards the front of the car, which would lower the steering arm & tie rod and provide more tie rod to sway bar clearance. However negative caster is not what you want for driveability!
The more positive caster you run, the further the spindle is tipped back which raises the steering arm & tie rod.
Looks to me like slightly longer end links are the fix... although the angular relationship between the end link & the lower control arm right now looks a bit excessive.
My 1969 Chevelle - TKO 5-speed, SC&C/ATS/SPC/GW suspension, C6 Brakes & hydroboost, crappy paint job.
Old Procharged 350: 88mph 1/8, 11.9 @ 125mph 1/4, full street trim on slippery 17's, 3950# with driver, ice chest, stereo, and tools, California 91 pump gas.
In progress: Twin Turbo LS2, going for a bigger ET/MPH mismatch at the 1/4.
  #8
Old Apr 14th, 08, 2:30 PM
CDN SS CDN SS is offline
Gold Member
Bill
I just went throught this same thing .aftermarket control arms and coilovers , aftermarket sway bar etcetc ......ended up pitching the end links and getting adjustable heim end links made up to get angle and length correct .....sway bar end still needs to be parallel to ground
Right or wrong I had alignment done before swaybar mounting ??
66 CDN Malibu SS A51,L34,M20 Aztec Bronze
Now 439ci Straub Solid Roller Brodix RR ,Tremec by Liberty
10.97/ 124.31 1.41 60ft
Crusin / Track video http://www.youtube.com/watch?v=fhvDGOO4JAI
Engine
  #9
Old Apr 16th, 08, 10:18 AM
Herb
Did you put the heim end links together yourself or does someone make them for our application?
Herb
herb@ridetech.com
1966 El Camino
1966 Chevelle
1963 C10
PHR CHP CHP Youtube
  #10
Old Apr 16th, 08, 11:50 AM
Gold Member
Bill
Yes made the link myself ......sorta, Mike at TRZ who made my control arms added the tabs to the control arms after that just some alum 1/2'"bar stock threaded to make up the links
Engine
  #11
Old Apr 16th, 08, 1:53 PM
69-Chevelle 69-Chevelle is offline
You may have stated this earlier but what sway bar are you using? It looks like a 68-72 a-body sway bar.
69 Chevelle Malibu
Big Block (Go Big or Go Home)
  #12
Old Apr 16th, 08, 3:26 PM
Herb
It's the sway bar that was on the car when I got it so I assume it's for a 66. Of course, since I had it powder coated it's probably the wrong one!
I will say prior to removing it for the SPC/ATS upgrade, there was no interference that I noticed with the stock suspension components.
Herb
herb@ridetech.com
1966 El Camino
1966 Chevelle
1963 C10
PHR CHP CHP Youtube
  #13
Old Apr 16th, 08, 10:42 PM
mcmlxix mcmlxix is offline
Rich
What if you fliped the sway bar... So the curved end slips under the tie rod then use shorter end links...You'll have to check suspension travel... But if you have some stiff springs it may be OK.. Or add a limiting strap.... Just a thought.. may not work.. but I will be running into the same situation shortly....
Rich --- accepting PayPal donations to Chevelle_1967@hotmail.com
Las Vegas
1967 Chevelle * Pro-Touring *
http://i70.photobucket.com/albums/i9...g?t=1232947887
LS376/480hp * T56 * AFX * Kore3 * SC&C * Varishock QS1 * Currie * Moser
  #14
Old Apr 16th, 08, 11:38 PM
MJRIBEIRO MJRIBEIRO is offline
Mike
Herb - I had the same problem - I switched up to a 2 7/8" end link - no more problem.....
  #15
Old Apr 17th, 08, 7:54 AM
Herb
I started on the alignment yesterday but didn't finish it. Once that's done, I'll take a closer look at the end links.
Herb
herb@ridetech.com
1966 El Camino
1966 Chevelle
1963 C10
PHR CHP CHP Youtube
Chevelle Tech > Specialty > Pro Touring      Current Topic: Tie Rods vs Sway Bar
Human Verification
