BBC 496 Hyd. Roller, Patriot or 781 Heads? - Chevelle Tech
Auto Insurance
Old Apr 7th, 08, 1:01 PM
Badrat496 Badrat496 is offline
Mark
Default BBC 496 Hyd. Roller, Patriot or 781 Heads?
I need advice please! I have a stroker 496 bbc in a 70 Nova approx. 3300 pounds weekend street strip toy. I have a set of 781 oval ports or maybe buy some new patriot 320cc heads. The oval ports would be with the larger 2.19 / 1.88 valves without any porting if I have them redone. Or just get the new Patriots? I need a hydraulic roller cam, heads, and intake advice. Any videos with Bbc hyd. roller cams at idle would be great! Thanks.
10.5 comp. forged pistons
2 1/8 super comp headers
850 Demon
Th400 3500 Stall
4.11 9 Inch
Old Apr 7th, 08, 1:06 PM
wildman926 wildman926 is offline
Team Member
Walter
Default Re: BBC 496 Hyd. Roller, Patriot or 781 Heads?
Why hydraulic roller? Why not solid ft? Just as much or more power, lighter valvetrain to rpm quicker. Good polylocks, check lash once in a while, and you are good to go.
Patriots, if you had the 781's already done, then I would use them. If you are spending money, then I would go Patriots.
69 Chevelle SS
10.5-1 496/AFR 305's/Voodoo 60234 Solid Roller/TH400 4000 Stall/4.11 12 Bolt
Old Apr 7th, 08, 1:42 PM
Mark
They are cheaper. But all I hear are horror stories about wiped lobes and destroyed lifters due to todays oils. Am I wrong?
Old Apr 7th, 08, 1:46 PM
Stokerboats Stokerboats is offline
Dan
Patriots will be an investment and give you future upgrade ability. The 781's are good if fully worked but will have their limit at a point when you could still use the patriot. At this time I am also NOT a fan of the hydraulic roller.
Old Apr 7th, 08, 1:48 PM
Mark
You have a badass Chevelle by the way. Do you think that you can still run flat tappet cams without problems?
  #6
Old Apr 7th, 08, 2:06 PM
67RS502 67RS502 is offline
About the same set up I run... 3300lbs 500cubes.
Go with a hyd. roller around 250-260 duration.
good single plane
headers are a bit large.
Dont forget the fuel and exhaust system!
67 camaro:
420 - 641hp HRcam 1.39, 9.79 @ 137.5
502 - 626hp 252/263HRcam 1.44, 10.08 @ 132.7
62 Nova
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
69 chevelle 350, 200-4R 411s 12.31@110.6 (sold)
http://www.cardomain.com/ride/709320
  #7
Old Apr 7th, 08, 2:27 PM
Mark
Do you have any part number in mind? I seen your Camaro in the magazine, awesome car. Thanks for the reply. Also how much work did you have to put into you heads?
  #8
Old Apr 7th, 08, 3:04 PM
71 chevy 71 chevy is offline
how about a solid roller? cheaper than the hydraulic and more power
  #9
Old Apr 7th, 08, 3:07 PM
Mark
More upkeep and failures from what i've read?
  #10
Old Apr 7th, 08, 3:17 PM
i dont think it should be that bad in a weekend toy.
I would keep the 781s if they are already worked. maybe spend a few dollars flow testing them to see what they are really capable of.
  #11
Old Apr 7th, 08, 3:45 PM
Team Member
Walter
Thank you for the compliment.
I run a solid ft in my truck, no problems what so ever. I have not touched the lash in over a year. I am putting a solid roller in the Chevelle, taking all precautions such as a rev kit, healthy springs, and Isky Red Zone lifter with EZ roll bearing.
Any issues after this, I will go to a solid ft, and would not hesitate to. Today's oils are not that bad off. The last few threads about this issue state that. I just add some STP to my oil changes using either Shell Rotella or Chevron Delo 400 (was last used), and running EDM hole lifters.
69 Chevelle SS
  #12
Old Apr 7th, 08, 3:46 PM
Mark
They are not worked. Just dont know if 10.5 comp. will give me detonation problems with the 781's also wonder if just larger valves would be enough for a 496 with a max rpm of 6500.
  #13
Dan
I'm running a solid flat tappet, I drive the car all over the place, I've been on this cam for two years, the car is 3860 with my fat @ss in it and I just ran a 10.63 1/4 last week. There is nothing wrong with a solid flat tappet. Just break it in correctly and use the EDM lifters.
  #14
Old Apr 7th, 08, 3:52 PM
Team Member
Walter
VERY cool to hear!!
69 Chevelle SS
  #15
Mark
You are making me think solid f/t any suggestions?
Chevelle Tech > General Tech Area > Performance      Current Topic: BBC 496 Hyd. Roller, Patriot or 781 Heads?
Human Verification
