| Chevelle Tech Current Topic: Water Injection, is it used anymore? | ||
| Performance Our High Performance area |
When I built my first 11 to 1 compressed 327 sbc, I ended up putting water injection on it. It worked great, all I had to do was check the water and pump now and then. I used it for over 10 year and when I tore the engine down, it was still in good shape. Back in the late 60's, I knew of several cars that used it. Today, I never even hear about it, nor in any of the mags. I'm curious, why was it discarded? I can understand it not being used on the newer programmable systems, but the cars before 1985 that have been built?
Thanks, Fred.
Blue 1969 Chevelle SS 396 375hp 4 speed. Only the dead have seen the end of war. - Plato. |
#2
Fred,
I'm glad you asked,as I've been wondering the same thing.They used to be all over the magazines.As far as I know the only down side is keeping the bottle full.What about long term corrosive effects?Think I read about making a homemade one out of a windshield washer pump and a switch on the throttle, years ago.
John 71 El Camino 406 SBC M21 3.31 12 bolt |
WHat is it? A cooling system?
1971 Chevelle SS clone cammed ls1, 4l60e, 3.42 12 bolt http://members.cardomain.com/thunderstruck507 |
I'm wondering the same thing. I've never heard of water injection before. Can you guys inform us who don't know?
1971 malibu<br />333cu in<br />Th350 <br />1/4....don't know yet. |
Years ago there were several water injection systems on the market. I used to use on also.Injectronic was one of the earlier ones.Edelbrock and Holley both offered system , Edelbrock also offered a Vapor Injection. Clifford Research even offered one.The Water Injection systems were really designed for lower vacuum use when standing on the throttle... the Vapor Injection was more designed for part throttle use.... The Vapor Injectors were origionally used by the Canadian government trucks in the northern area where due to the extreme cold their trucks were run 24 hours a day non stop....Too cold to restart... The Vapor Injectors used an alchol / water mix that sort of acted like an antifreeze ... the vapor when in the combustion chambers turned into steam and cleaned excess carbon off the chambers and pistons... without the vapor injection these engines would " load up " badly..... With the Vapor Injection they ran much smoother..... didnt foul plugs as bad either.
During the 70's when they took out the Tetraeythel lead out of the gas and lowered the octane from 95-96 area to 91/92 the still commonly seen 11-1 compression engines were really suffering.... Even the 10-1's were rattleing ... People were doing all kinds of crazy things...More jetting , Less ign timing , Lower temp thermostats ... mixing raceing gas with pump gas , cooler heat range plugs..... anything to stop the pinging.... Water / Vapor Injections were one of the semi popular methods of pulling heat out of the combustion process and for many people it worked. Many people during those days used them on new cars... Detroit had no clue what they were doing then..The Government mandated to take the lead out to use the Cat Cons.... So they lowered the compression ratios ... lets leave the pistons oh say .025down the hole witch worked good with an .022 steel head gasket... but no they started to use .038 / .042 head gaskets in those years also.. Too much deck... results lower compression but they pinged... so to help that they retarted the cam timing... producing less sylinder pressure... but they leaned the carbs down.... lets then put 190 deg T stats in them... less emmissions... but they pinged.... so EGR was used to lower combustion temps and reduce Nox...They discovered that the once common 2700 - 3400 RPM when cruzing the freeways was hard on gas and emmissions they reasoned that less RPM meant less emmissions so they put 2.29 , 2.43 , 2.56 and 2.73 gear sets in them... that loads an engine harder while trying to leave from a start.. the results .. you guessed it .. it pinged... Those years sucked for performance minded people. And Water Injection was one desprate methods that was used to cope with it.
Al. 1969 El Camino 1969 LS-1 engine is a 427/335HP BBC passenger car mill..( mine is slightly modified ). |
#6
Try this for a good read on the subject of water and fuel mixtures, (i.e., emulsions)..
http://www.rbbi.com/folders/fuel/a-21.htm PuriNOx http://www.epa.gov/otaq/models/p02007.pdf and A-55 http://www.dieselnet.com/news/0001a55.html are both in on this too. pdq67 |
#7
There's a few guys in the Syclone and Typhoon world that use this setup.From what I heard,it's good to use on a turbo application.
69 SS396 Chevelle Prostreet 69 SS396 Chevelle-sold 92 GMC Typhoon-sold 2007 Trailblazer SS Reading,PA Webshots Photo Album |
#8
Check with the turbo guys. Here's a link for DIY Alcohol injection.
http://members.cox.net/stevemonroe/AlcoholInjMod.html Steve
66 327 Malibu RIP 86 Cutlass 94 Cadillac STS ME LaZerte Mechanics Teacher |
#9
Wow. This is totally new to me, and very interesting. Thanks for the explanation and links guys!
-Ben
#10
Hey John,
I remember that article, and a few more. I set mine up with two vacuum switches on the intake. One at 7 in. and one at 2 in. The 7 in switch would turn the pump on at half speed (because of an inline resistor), while the 2 in. switch would turn it on a full speed. The adjustable feeder controlled the spray. I can also remember guys mixing all kinds of stuff with the water. My pump was nothing more than a windshield washer pump. I will say one thing, I could have never keep the 11 to 1 on the road without it. Fred.
#11
yes, its popular in the turbo world, very effective at reducing detonation. Heres some links:
http://www.turbobuick.com/forums/for...c54&forumid=14 http://www.turbomirage.com/water.html http://www.h20injection.com/forum/phpBB2/ http://www.alkycontrol.com/?ref=turbobuick http://www.rbracing-rsr.com/waterinjection.html
www.turbodaves.com turbodaves@verizon.net 214-208-4018 Precision Turbo-Borg Warner/Airwerks Forced Inductions--Garrett Performance CSU Carbs - EV Carb Hats JGS Precision Turbo - Turbonetics 358c.i. sbc 721rwhp@10/lbs boost pump fuel only |
#12
Didn't the original Turbo Buick come with water injection from the factory??
#13
Al,
Thatwas a great explenation and overview on water injection. Fred, Nice system you fabbed up.I never got around to putting one in my Chevelle.If I couldn,t get some Sunoco,I'd just dump a can of 104+ in there and go. This may end up being a timely subject if the other gas co's follow Sunoco's cutting of 94 octane gas.
#14
I use water injection on my car, mostly as insurance. I tuned the car to run detonation-free without the water injection (so I wouldn't ping the thing to death should the pump ever give out at an inopportune time), but the water injection just adds a little bit of a "cushion" plus steam cleans the motor every time I get into it. I could easily run more boost and more timing and make more power tuning the car to run with the water injection, but then I'd be in for detonation should anything ever go wrong with the system.
I'm running a diaphragm pump I picked up from Northern Tool which sucks from the washer tank through a filter. The pump is controlled via a progressive pump controller (the pump speed increases with boost) from a friend of mine, Julio Don. I rigged up plumbing using nylon tubing and push-to-connect fittings and the atomizing nozzles came from McMaster-Carr. I only run distilled water, as I'm mainly going for the cooling effect to suppress detonation. Alky works great too, but I don't like the corrosive side effects-- so pure water for me. Carroll Supercharging makes a ready to go kit, as does Aqua Mist and SMC Enterprises, but most are tailored for boosted applications and use a certain amount of boost to turn on the system. You could easily use it on a naturally aspirated motor by swapping the pressure switches for vacuum switches. Will they help with detonation? Undoubtedly. I'm just the kind of person who would rather correct the real cause of the problem rather than add a "crutch" to cover it up. Also, if you tune the car to require the water injection to run detonation-free you're setting yourself up for trouble should the water injection system ever fail on you. A lot of people tune their cars this way and have zero problems, but I like to play it safe and sacrafice a few HP with a more conservative tune-- too much money on the line to tune the car to *need* the water injection to run safely. Troy
My 1969 Chevelle - TKO 5-speed, SC&C/ATS/SPC/GW suspension, C6 Brakes & hydroboost, crappy paint job. Old Procharged 350: 88mph 1/8, 11.9 @ 125mph 1/4, full street trim on slippery 17's, 3950# with driver, ice chest, stereo, and tools, California 91 pump gas. In progress: Twin Turbo LS2, going for a bigger ET/MPH mismatch at the 1/4. |
#15
Digging up an old post......
I am seriously considering using a water injection setup with my Jimmy as the stock low compression 350 pings now under heavy load, especially when its 100+ degrees outside and/or I am towing. I now have a rebuilt 355 with alittle more compression (and more cam) and thought water injection might be a good piece of mind. I have a question though. Does water injection decrease HP/TQ on a N/A powered engine? Thanks guys!!
-Cable -Datsun 280z 'LSZ' 6.0 LSx/4L60e: 2005 LQ4, 2004 GTO 4L60e trans/converter, Lunati Voodoo 60511 cam, Sanderson 1.75" coated headers, 2.5" dual exhaust, welded R200 diff w/3.54 gears, 2800 lbs w/me -1965 Chevelle SS (basketcase project) |
| Display Modes | |
