TH350 kickdown cable install - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Mar 5th, 08, 12:26 PM
Chevallier Chevallier is offline
jml
Send a message via MSN to Chevallier Send a message via Skype™ to Chevallier
Default TH350 kickdown cable install
I have the lower plastic base of my kickdown cable broken (on the transmission side) so I have to remove it and get a new one.
I removed the screw (attachcing the cable base to the transmission block) and see the inner cable going inside.
but I don't know what should I do next?
Do I have to remove the pan to free up the cable end in side the trans?
Anybody has a step by step for this?
Thanks in advance.
Old Mar 5th, 08, 5:24 PM
mino65 mino65 is offline
Team Member
mark
Default Re: TH350 kickdown cable install
pull up on the cable and you will see the loop end of the cable hooked over what looks like a peice of wire,just unhook and rehook the new one on and thats it.
Old Mar 5th, 08, 5:29 PM
jml
okay thanks I'll try that.
jml
Old Mar 5th, 08, 5:34 PM
von von is offline
Lifetime Founding Member
Von
Use some needle nose pliers. It's a PITA but can be done without removing the pan, unless you drop the broken piece in there.
von '69 300 Dlx SS '69 Malibu TC #15 ACES #1575 HSCA #5
http://www.chevelles.com/showroom/da...m/DSCN1135.JPG
[img]
http://www.chevelles.com/showroom/da...m/DSCN1397.JPG
Old Mar 6th, 08, 1:54 AM
jml
worked well thanks,
I am still not sure how to tune the cable position at the carburator end.
Is there a way to determine how to adjust the tension on the cable so that the kick works best?
  #6
Old Mar 6th, 08, 7:27 AM
von von is offline
Von
The kickdown cable should be adjusted so that full extension of the cable (and valve in the trans) is reached at the same time the carb reaches WOT.
[img]
  #7
Old Mar 6th, 08, 10:40 AM
befair befair is offline
Bill
This should help you some:
http://www.autozone.com/az/cds/en_us...es.htm#hd1-1-3
....just scroll down to the TH350.
HTH
-Bill-
"Sometimes I think life is just a rodeo,
the trick is to ride and make it to the bell."
-John Fogerty
Weirton Speed and Marine
1979 Malibu Spt. Cpe., (Formerly a 41K Granny car) - ZZ502, TH400, 3.70/FxxD 9".
  #8
Old Mar 6th, 08, 5:36 PM
jml
Thank you guys, this is exactly the information I needed
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: TH350 kickdown cable install
Human Verification
