gas gauge problem 72 chevelle - Chevelle Tech
Auto Insurance
Electrical & Wiring Troubleshooting electrical problems.
Old Mar 1st, 08, 5:27 PM
72SSdummy 72SSdummy is offline
Ronnie
Default gas gauge problem 72 chevelle
I have a 72 chevelle gas gauge worked properly when I purchased it sometime after filling it up I noticed the gauge went all the way to
3:00 and has stayed. I unpluged it at the rear of the car and put 12volts
to it ; it moved to 4:00 when took off voltage it returned to 3:00.
Please help.
Old Mar 1st, 08, 5:50 PM
Dave427 Dave427 is offline
Dave 383 now
Default Re: gas gauge problem 72 chevelle
Ground the sending unit wire it should go to empty, then leaving it open it should go over the full mark. This test checks the gauge in the dash.
Dave
Old Mar 1st, 08, 7:59 PM
Ronnie
Did what you said. Gauge went to E when I disconected it went back to 3:00 whats next?
Old Mar 1st, 08, 8:08 PM
Ronnie
around 1:00 would be full
Old Mar 1st, 08, 8:17 PM
Brucebodyman Brucebodyman is offline
Bruce
Double check the ground wire. I believe it is just sheetmetal screwed to underbody in front of tank. take it off clean area it attaches to and clean ring at end of wire & reconnect. The gauge on my ElCamino acted up & this fixed it.
  #6
Old Mar 1st, 08, 8:39 PM
Ronnie
thanks for your help I will try that and see if it takes care of the problem. I am a little sceptical since it went way past full without reconnect the sending unit
  #7
Old Mar 1st, 08, 8:56 PM
Dave Birdwell Dave Birdwell is offline
Chevelle Doctor
Send a message via ICQ to Dave Birdwell Send a message via Yahoo to Dave Birdwell
What's next?? How about some punctuation marks so we can understand what you said??
Here is what should happen. Disconnect the sender at the connector behind the license plate or where ever it is easy for you to get to. The Tan wire is what you're looking for. Take the wire, and ground it to the body. Your gauge should go to "E". If it goes back to 3:00 when you reconnect it, you have one of two problems. Either the ground for the sender is bad as mentioned above, or the sender in the tank has opened up the circuit.
Owner of Daves' Restoration, The cure for the common hoopty.
70 Chevelle L78/M21
00 Chevy Silverado 1500 4x4
06 Equinox
Wanted-1976 Nova SS.
  #8
Old Mar 2nd, 08, 7:05 PM
frankiblu frankiblu is offline
Team Member
vincent
would that be the same for a 66 my gauge is stuck on full. I unplugged wire of back of tank and nothing happened
  #9
Old Mar 2nd, 08, 9:15 PM
medina medina is offline
Nick Medina
Send a message via AIM to medina Send a message via MSN to medina
same thing on my 70
  #10
Old Mar 2nd, 08, 9:20 PM
red Chevelle SS red Chevelle SS is offline
Joel
I have the same problem, please keep me in the loop if you get it repaired. jstewart@nelbran.com
Thanks, Joel
  #11
Old Mar 3rd, 08, 6:50 PM
Chevelle Doctor
Here's how to test it, go out to the garage and get to work!
70 Chevelle L78/M21
06 Equinox
  #12
Old Mar 3rd, 08, 7:51 PM
ToocoolZ28 ToocoolZ28 is offline
Gold Founding Member
Ron
Mine did the same thing, after testing everything I replaced the sending unit. Works perfect now.
Ron
70 Chevelle SS396 (427) M21
69 Malibu convertible
95 Z28 Convertible T56
TC #54 Gold
69 - Top down
69 Top up
new wheels
70 side
On Gearz
  #13
Old Mar 4th, 08, 7:36 AM
dreis454 dreis454 is offline
Dan
I had the same problem......
I took out the sender & cleaned the 'lock ring' that holds the sender in (it had a tiny bit of rust on it) & it works fine now
72 ss 454 "W" code,w/cowl induction (how many left?)
matching # LS5 454+.060" 9.2 :1, 2.19/1.88 valves,Comp HR cam 289/295 234/240 .613/.613 110* (dyno'd @ 557hp @ 5400 & 583tq @ 4100)
matching # M22 w/CF dual friction clutch.
Holley 750 HPs dp(82751) on Weiand Stealth & MSD Pro billet HEI
Hedman Elite headers/Flowmaster exh. (w/super 40s)
TC#3095
Garage find parked from 1978-2004
http://macswebs.com/ls5registry/bal/bal.htm
http://www.chevelles.com/showroom/sh...0&ppuser=25834
http://ssregistry.macswebs.com/1972/1d37w2b_reis.htm
http://www.youtube.com/watch?v=YqZkVw6xMkM
  #14
Old Oct 26th, 14, 3:38 PM
shnort shnort is offline
where can I find a fuel gauge for a 1972 chevelle without the round gauge? Mine is to the right of the spedo and reads full on top to empty is down. Thanks Bucky
Chevelle Tech > Mechanical > Electrical & Wiring      Current Topic: gas gauge problem 72 chevelle
Human Verification
