Chevelle Tech General Tech Area
Please try and post in specific forums
Old Feb 19th, 08, 4:17 PM
aschmid aschmid is offline
Andy
Default For those of you lucky enough to have an LS motor in your chevelle...
but don't like how the coil packs look on top of your valve covers. Don't know if you have seen these VC from abearmotorsports but they enclose the coil pack inside the valve cover. I got mine anodized in red and custom engraved too, and man they came out awesome.
  #2
Old Feb 19th, 08, 4:19 PM
Andy
Default Re: For those of you lucky enough to have an LS motor in your chevelle
BTW, check out the brand new LS2 408 stroker with ported/CNC L92 heads that will be going in my chevelle.... can't F%#!@ wait!
Old Feb 19th, 08, 4:33 PM
Gokou Gokou is offline
Troy
That is a cool idea. I bet they sell a ton of them.
My only concern would be that the coils & drivers now sit in a "hot box" with no real air circulation. Probably won't get hot enough to cause problems though.
My 1969 Chevelle - TKO 5-speed, SC&C/ATS/SPC/GW suspension, C6 Brakes & hydroboost, crappy paint job.
Old Procharged 350: 88mph 1/8, 11.9 @ 125mph 1/4, full street trim on slippery 17's, 3950# with driver, ice chest, stereo, and tools, California 91 pump gas.
In progress: Twin Turbo LS2, going for a bigger ET/MPH mismatch at the 1/4.
Old Feb 19th, 08, 5:09 PM
pist0lpete pist0lpete is offline
Neal
Those are a slick idea and I have had the same concerns about them overheating. I really doubt its much of a valid issue especially in a street car. Relocating the coils under the dash or on the firewall is another option but then you have to run longer wires as well. By the way nice looking engine I see you are using the milodon pan. Surprisingly I haven't seen anybody use that in an A-body yet(me as well as many others use the stock f-body pan) but I think it should work great and make it easier to stab the engine and tranny.
1967 Chevelle
LS1 swap is completed!
www.fquick.com/pist0lpete
12.70 at 108.95mph
Old Feb 19th, 08, 5:20 PM
Joel642DRpost Joel642DRpost is offline
Joel
I would luv to put an LS motor in my 64 chevelle. I think you have to cut out some of the fire wall and tunnel. Looks awsome guys. Get-r-done!!
  #6
Old Feb 19th, 08, 6:24 PM
snydes snydes is offline
Team Member
Steve
The LS engines are amazing, you are going to have a blast!
  #7
Old Feb 19th, 08, 9:45 PM
wht64 wht64 is offline
Brad
hopefully will have the body work done soon, then will start the install...will post progress when i get to that stage..
  #8
Old Feb 19th, 08, 9:47 PM
Brad
saw an LS1 coil cooked in an oven at 400 degrees then installed on a running engine..worked without a hitch...it was a duarability experiment for situations like those valve covers...
  #9
Old Feb 19th, 08, 11:38 PM
Neal
Baking in an oven at 400 degrees is one thing having a coil exposed to 400 degrees for extended periods of time while firing the plugs for 30k miles is whole different animal. Those coils have a heatsink on the bottom of them for a reason. Even so, I don't imagine they will have a problem under those covers, would I run them on my car? no, but that doesn't mean they won't be fine.
1967 Chevelle
12.70 at 108.95mph
  #10
Old Feb 20th, 08, 1:29 AM
HMartin HMartin is offline
Team Member
Thumbs up Re: For those of you lucky enough to have an LS motor in your chevelle
What pulleys are you using? Looks awesome!
  #11
Old Feb 20th, 08, 11:03 AM
Andy
The pulley set is from synister products, and it is awesome! It is the only one I could find that was complete with everything, including water pump, alternator, power steering pump, ac compressor, etc.
http://www.synisterproducts.com/LS1-PST.htm
Valve covers are from abear motorsports, a little expensive, (over 700 for mine) but worth it in my opinion.
http://www.abearmotorsports.com/
  #12
Old Feb 20th, 08, 11:08 AM
Andy
This is from abearmotor sports, it has been brought up before:
"Have you had any of these out there that have been in constant use in a daily driver? We have. Our test vehicle was an Escalade used throughout the spring and summer of last year (still in use now actually). The vehicle was used daily as a commuter, and even towed a boat on the weekends. We had an unusually hot summer last year as well.
We get this question a lot so we will be posting some results from our coil testing in the next week or so. Without going into all the details I can say the coils withstood temperatures in excess of 350 degrees for over 30 minutes without malfunction. If an engine ever sees 350 degrees the coils are the least of your worries..."
  #13
Old Feb 20th, 08, 11:50 AM
69 Beaumont 69 Beaumont is offline
Rick
I'm jelous... I want to put an LS series engine in my 69. But I'm putting a holley mpi kit with a xfi comp, For now. GREAT looking covers and engine
  #14
Old Feb 20th, 08, 4:17 PM
Andy
thanks... did I mention this is going on a fully custom tube chassis with a Z06 frontend suspension and brakes? :-)
  #15
Old Feb 20th, 08, 5:38 PM
Jepprox Jepprox is offline
Since you have invested quite a bit thus far, you might consider having your exhaust manifolds or headers ceramic coated. It will add to the looks of your engine compartment and reduce the overall heat under the hood by half.
69 Chevelle - 700hp 509 c.i, TH400, narrowed 9-inch
http://www.chevelles.com/showroom/sh...0/ppuser/19836
You may not post new threads
You may not post replies
