turbo 400 2-3 shift problem - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Feb 17th, 08, 5:34 PM
jayss68 jayss68 is offline
Jay
Default turbo 400 2-3 shift problem
turbo 400 1-2 shift is fine,but will not go into third.I took the valve body out and did not notice anything wrong or out of place,but I am not the best at transmissions,guess its time to learn.got any ideas?
Go fast or drive a ford..
Old Feb 17th, 08, 10:58 PM
jetblue69 jetblue69 is offline
Josh
Default Re: turbo 400 2-3 shift problem
Try to wind it out in manual second then manual shift it into third. If it does shift eventually it's the modulator or the detent solenoid. Give me some more diagnosis data and maybe I can help you out. Personally it sounds like a stuck 2-3 shift valve to me.
Old Feb 18th, 08, 8:11 AM
Jay
Thumbs up Re: turbo 400 2-3 shift problem
Yes I already tried that and it didnt work. What happened was that I was at the drag strip I made 2 passes and on the third pass is when it started. Took it home unloaded it from the trailer went down the street and it worked fine. Few days later, I drove it again and again no 3rd gear.
Tranny is a raptor 400 about 3 years old but only 800 miles on it.Not a manual valve body.I currently have tranny out and on my workbench.
The valves in the valve body did seem like they may have been sticking.
While I have it apart any ideas you have will be helpful.I dont want to spend much money.I drive it on the street rarely mostly to car shows.Also run it at the drag strip just to out run my buddies and any ford that gets beside me.
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: turbo 400 2-3 shift problem
Human Verification
