Rough opening for a 48" X 80" closet door? - Chevelle Tech
Auto Insurance
Bench Racing Stories, cruising and more.
Old Feb 15th, 08, 9:13 PM
Alwhite00 Alwhite00 is offline
Default Rough opening for a 48" X 80" closet door?
Anyone happen to know the rough opening for a sliding closet door listed as a 48" x 80" ? - I want to do the rough framing but do not have the door & won't get it for 2 more weeks. I want to start the framing tomorrow. I looked on the website and it does not list the RO - Is it 48 x 80?
Thx.
LK
The only difference between No.One & No one. is where you put the period.
67
http://i925.photobucket.com/albums/a...7/DSCF9178.jpg
70 (SOLD)
http://i925.photobucket.com/albums/a...e/DSCF9111.jpg
Sea Ray
http://i925.photobucket.com/albums/a...0/DSCF6826.jpg
Old Feb 15th, 08, 9:23 PM
quikss quikss is offline
Jeff
Default Re: Rough opening for a 48" X 80" closet door?
If it's a typical door and frame, the rough opening would be approximately 50 1/2" x 81 1/2" I believe. It's been a while since my framing days.
Jeff
69 Chevelle 505 686 hp/ 663 ft lbs tq TKO600 12 bolt 3.73 Yup, it's a handful alright!!!
2007 Trailblazer SS 364CI LS2 475hp 4L70E AWD with 4.10's front and rear!!! Daily Drivin' grocery getter
2006 Cadillac CTS-V, Luxury, handling, power Does it get any better??
Old Feb 16th, 08, 12:28 AM
pdq67 pdq67 is offline
Guest
Paul
And have some long, sawed shims handy and you should be fine, imho.
pdq67
Old Feb 16th, 08, 8:14 AM
6t7gto 6t7gto is offline
Pre-Hung Door - Grand River Supply
The rough opening dimensions are normally 2" taller and 2" wider than the door. For example: The rough opening for a 2'-6" x 6'-8" door would be 2'-8" x ...
www.grandriverdoor.com/grs/prehungInfo.aspx - 44k - Similar pages
david
Old Feb 16th, 08, 8:36 AM
bochnak bochnak is offline
Matt
Thx.
LK
I replaced my sliding doors with bi-folds. You gain much more clear opening.
Is there anyway you can measure at the local store? They usually list the rough opening required on the product.
Matt
70' 350/Th350 - C6 wheels
  #6
Old Feb 16th, 08, 8:55 AM
Dales69SS Dales69SS is offline
Dale
52" X 82" you can use 3/4" x 3 1/2" ( 1x4 ) to take up extra space. Not all bi folds are the same. Also not all carpenters get things squared properly. This should keep you safe & allow for any errors without getting in trouble with any trim options.
Be sure to put the header board in first to adjust hieght first.
  #7
Old Feb 16th, 08, 9:03 AM
Dale
oh yeah carpet or tile ??
  #8
Old Feb 16th, 08, 9:25 AM
Guest
Paul
And I figure that you will need to trim the height at the bottom at least on one side or you will have a gap on one or the other side at the bottom if it 100 percent level up top.
As-hole didn't trim ours!!
pdq67
  #9
Old Feb 16th, 08, 9:43 AM
Thanks guys, I'm going to call & see if someone can actually look at them & figure out the RO
LK
67
70 (SOLD)
Sea Ray
  #10
Old Feb 16th, 08, 9:45 AM
Keith Tedford Keith Tedford is offline
Keith
Many years ago we had our house framed in then finished it ourselves. Believe me, things can be out of plumb, out of square, and out of level. There are probably more people out there building houses that don't quite know what they are doing than do. Give the opening the extra clearance to save possible aggravation later. I found that the foundation contractor was VERY poor on simple blueprint reading and the framers weren't a whole lot better. Time for some good apprenticeships in the building trades again.
You may not post new threads
You may not post replies
