Art Morrison "Max-G" Chassis - Chevelle Tech
Auto Insurance
Pro Touring Todays performance with classic style
Old Feb 6th, 08, 4:57 PM
Malli383 Malli383 is offline
Default Art Morrison "Max-G" Chassis
I have a '66 SS under the knife and was considering this chassis as the base of my project. The company tells me that it's great but I thought I'd look for some real life opinions. Any help?
Old Feb 6th, 08, 5:42 PM
1966_L78 1966_L78 is offline
Tony
Default Re: Art Morrison "Max-G" Chassis
No opinions, but... a few questions to ponder...
1) What are your intentions for the car? Cruiser with spirited driving? Auto-cross? Some track/road course events? Hardcore track car (maybe still streetable)? Really care about having a cool frame under your car to show off?
2) Does the chassis affect handling much, by itself? i.e., does a stiff chassis help alot? On a racecar, sure, but for the street (or the way you will drive the car) is it significant?
3) Does the Max-G chassis have "stock" suspension pickup points? Use "stock" suspension pieces? Is there a "suspension geometry" reason to use it?
4) Does the max-G chassis weight more or less than a "stock" frame?
Once you go RAT, you never go back...
TC #1366
'70 Chevelle 427 Stroker
'66 Convertible Sold
Dual Quad 396 & Conv Int
'66 SS L78
Old Feb 6th, 08, 5:53 PM
Derek69SS Derek69SS is offline
"The Stig"
The Max-G is fully custom, and I believe uses 'vette front suspension... unfortunately, it's not just a simple bolt-on frame. You will need to either modify your floors, the frame, or both to make it fit.
IMHO, you can do a LOT with a stock frame with bolt-ons... anything more is overkill for the street.
Derek Kiefer, member of Minnesota's Northstar Chevelle Club
69 Malibu Pro-Touring stroker LS1-383/T56 - 69 Chevelle SS396 325/3spd
Old Feb 6th, 08, 7:04 PM
Yeah. They offer a corvette front end or their own set up. The floor modifications are not really modifications but rather a replacement. I need to repair a large portion of my floor and trunk floor so in my case it's kind of a wash on labor time.
Old Feb 6th, 08, 7:32 PM
Gokou Gokou is offline
Troy
The Max-G chassis is really nice. I like it even more now that they offer a 3-link rear suspension.
You basically slice out your floor, weld it up even with the bottom of the rockers, and start over.
It is expensive though... about $11K with the rear end housing & rear suspension, you bring your own C5 stuff to the table. I looked into it about a year ago and dismissed it due to price.
My 1969 Chevelle - TKO 5-speed, SC&C/ATS/SPC/GW suspension, C6 Brakes & hydroboost, crappy paint job.
Old Procharged 350: 88mph 1/8, 11.9 @ 125mph 1/4, full street trim on slippery 17's, 3950# with driver, ice chest, stereo, and tools, California 91 pump gas.
In progress: Twin Turbo LS2, going for a bigger ET/MPH mismatch at the 1/4.
  #6
Old Feb 7th, 08, 12:51 PM
envmyss envmyss is offline
Adam
Don't forget the Roadster shop.
Got to look at this frame at SEMA and asked lots of question.
You will not have to cut up your floor for this chassis.
The front suspension is from DSE if I remember correctly. So no easy to get C5 parts.
http://www.rsperformanceconcepts.com/
  #7
Old Feb 7th, 08, 4:48 PM
I looked at that chassis as well. It looks great but the price is about $7000 more. Ouch.
  #8
Old Feb 7th, 08, 5:52 PM
Beaux Beaux is offline
11 grand is my suspension, brakes and rear end. no way I can justify a new frame removing all that when the stocker can be worked over and be more than enough for track and street.
Now, if I just had that coin laying around and wanted something to blow it on then, HELL YEAH I would do it. But I dont, so I cant....maybe one day
"I know a lot about cars, man. I can look at any cars headlights and tell you exactly which way its coming." - Mitch Hedberg
  #9
Old Feb 7th, 08, 11:14 PM
andrewb70 andrewb70 is offline
Andrew
Here is a great alternative for a replacement frame for A-bodies:
http://www.chevyhiperformance.com/te...sis/index.html
http://gmachinechassis.com/
Andrew
1970 GTO Version 2.0 in progress
V8TV Feature video
Popular Hotrodding feature
Car Craft feature
1967 Cougar LSx build
"You were the gun, your voice was the trigger, your bravery was the barrel, your eyes were the bullets."
  #10
Old Feb 8th, 08, 7:45 AM
MakMetalFab MakMetalFab is offline
Mike K.
Send a message via AIM to MakMetalFab
Those welds look lie a bird **** on it! on the schwartz chassi.
Owner of Mak Metal Fabrications
Specializing in restoring the Unrestorable
http://s230.photobucket.com/albums/ee83/MakMetalFab/
  #11
Old Feb 10th, 08, 3:13 PM
Dave Hopkins Dave Hopkins is offline
Dave
Disliking "front steer" or "revese Ackerman" steering as Chev stuck us with if I where building a chassis the first goal would be a rack & pinion behind the cross mamber even if it meant a custom pan.
The design where he uses a large retangle tube layed sideways to run a Nascar style exhaust out in front of the rear wheels scares me. The entire rear end is located buy the long sheet metal runs of that rectangle tube. May work until someone takes it to the Drags.
I have not studied the Morrison deal but his back ground is Drag Race componants, I would expect it to be quite nice. I whatched one of the Boyd Coddington shows a while back where they used a AM chassis
  #12
Old Feb 12th, 08, 7:39 PM
If you had 11 grand to spend on the susp. of your car you could have spent 13 and put one of these under the thing. to each his own I guess.
  #13
Old Apr 29th, 08, 9:20 AM
CraigMorrison CraigMorrison is offline
Craig
Malli383- Right now, our chassis is not a direct bolt-on, but that will be changing by the end of the year. We have a few different Chevelle chassis in the shop right now and are starting to take initial measurements for a complete replacement frame.
The frame we have now is pretty cool in that we set it up for the ride height that you want, for the tire and wheel package you are going to use and can offer it with C6 or IFS front and Tri 4-bar, 4-bar or 3-link rear, all with coil overs or shockwaves. The biggest downside is that there are floor mods required since the footwells dip down on these cars. Give and take.....
Anyway, that's what we have, and that's where we are going. Hope this helps with your decision.
  #14
Old Apr 29th, 08, 5:04 PM
gearheads78 gearheads78 is offline
I just saw a Swartz chassis on either lateral g or pro touring in the last week that was for sale. I think someone bought a bunch parts and they are abandoning the project. You might check that out to save some $$
66' Cutlass 330 TKO 600 C6 brakes ect (see it come together here) comming soon 455
If only the damn trees weren't so addicted to that poisonous gas Carbon Dioxide.
Chevelle Tech > Specialty > Pro Touring      Current Topic: Art Morrison "Max-G" Chassis
Location
*REQUIRED*
Insurance
First Name
Human Verification
